[DRIVING] 1993 FD Rx7 with Tesla LDU and ElectricGT Batteries
rjmcdermott81
Re: 1993 FD Rx7
Post by rjmcdermott81 »
I mounted and wired in an engine start button from a Honda s2000 to send the start signal. I'm sure I overpayed by using one from an s2000 but I have nostalgia because it was my first real sports car.
This mounted in the cigarette lighter hole really easily. I just had to dremel out a few grooves so it would slide in. Wiring was easy as well, I used the existing pos/neg from the cigarette lighter since it is already switched power. Then when pressed it sends 12v out.
rjmcdermott81
Re: 1993 FD Rx7
19mm coolant adapter from zeroev mounted on the drive unit. Nicely machined part.
rjmcdermott81
Re: 1993 FD Rx7
Waterpump mount done and wired in.
Zapatero
Has thanked: 27 times
Been thanked: 58 times
Re: 1993 FD Rx7
Post by Zapatero »
I'm already in love with this RX7!
As a big fan of japanese cars i think one does see them way to rarely to be considered for electric conversions!
I love driving my Toyota GT86 EV - it's absolutely awesome (project threat is on here, too). I'm sure you will have the same fun with your RX7!
Also it's great how you involve your Kids :)
rjmcdermott81
Re: 1993 FD Rx7
Zapatero wrote: Wed Feb 03, 2021 7:58 pm I'm already in love with this RX7!
Thanks! I've gone through your entire build and it's helped me a bunch along the way. Love the GT86.
rjmcdermott81
Re: 1993 FD Rx7 with Tesla LDU and ElectricGT Batteries
J1772 connector is mounted (the label is upside down because I had to swap the door to the other side...I'll cover this up later). It was much easier than I expected. I just needed to alter the angle so the charging connector wouldn't hit the body.
One more thing down...
rjmcdermott81
Another small update, working on the details. I created a design to hold the 2/00 high voltage wires. I'll adapt the design based on placement after I get the batteries.
FJ3422
Has thanked: 13 times
Re: 1993 FD Rx7
Post by FJ3422 »
Good work ! Nice 3D printing work !
rjmcdermott81 wrote: Wed Feb 03, 2021 3:30 am waterpump pic 1.jpg
Do you use this Bosch PAD-12V pump for just a partial coolant circuit, or for the complete (inverter-motor-charger-batteries) coolant loop ?
Where the Bosch PAD's can create a differential pressure of around 0,1-0,15bar (at around 1 Amp), the usual 'Tesla'-pumps are spec'd around 0,5-0,7bar (at around 7 Amps). When you have a large / complex loop with a high flow resistance, you might have to consider a more powerful pump.
rjmcdermott81
Re: 1993 FD Rx7
FJ3422 wrote: Tue Feb 16, 2021 4:25 pm Good work ! Nice 3D printing work !
You are 100% right. I looked over at Boxster EV's build thread and he is using a Davies Craig pump so I just ordered one. Much much higher flow rate.
muehlpower
Been thanked: 188 times
Re: 1993 FD Rx7
Post by muehlpower »
rjmcdermott81 wrote: Mon Feb 22, 2021 3:37 am
I use Bosch PCE pumps. They have more power and can be controlled via PWM. Without PWM they run at 100%. A dry run protection is also integrated.
They are easy to get because they are used in many VW models, but the VW version has a different plug and pin assignment.
I paid € 30.- each
Bosch PCE.pdf
(221.35 KiB) Downloaded 308 times
rjmcdermott81
Progress update. I took a break but getting back in it now.
Starting to work on the high-voltage box and mounts for each part - resistors, contactors, etc. These are not the final wires...just for testing.
rjmcdermott81
BMS and charger are here
rjmcdermott81
Taking a break to do the axles and wheel-bearings on the e30
rjmcdermott81
Batteries are here!! (2 more on the way but this is what I need to start building the box)
rjmcdermott81
Arranging the batteries in the way they will fit in the car.
rjmcdermott81
Working on a battery holder template and then getting it back from Sendcutsend.com. So easy and such nice delivery.
rjmcdermott81
Now that I have the first one dialed in, ordering the holder plates for all the batteries
Boxster EV
Has thanked: 57 times
Been thanked: 50 times
Post by Boxster EV »
Loving this build. Thanks for sharing such a comprehensive write-up.
You might want to mount the pre-charge resistors on a metal plate. They will get warm and could melt the plastic.
rjmcdermott81
Boxster EV wrote: Fri Apr 23, 2021 1:12 pm Loving this build. Thanks for sharing such a comprehensive write-up.
Thanks - I appreciate feedback like this. I think now that I have the file and design dialed in I will send it out to have it 3d printed in metal. Good excuse to try that for the first time.
rjmcdermott81
Battery mounts and steel square tube are in to make the battery box. I plan to build it one battery section at a time test fitting in the vehicle to squeeze it all in.
These brackets will hold the chill plates on the single batteries
Here is a section of three batteries with chill plates sandwiched in between
Here it is with the square tube on the side. I will cut, drill and then mount to this.
Also, at Walmart I saw the new Mustang E parked at the charger. I've been totally excited after reading about it in magazines but seeing this one...man I hope they don't all look like this. It's probably the ugly wheels or something but it did not look good.
celeron55
Has thanked: 39 times
Been thanked: 136 times
Post by celeron55 »
The Mustang Mach E looks weird in my opinion too, but I hear they put some nice tech into it. Now, let's just hope someone safely crashes one and puts the parts up on Ebay...
rjmcdermott81
My neighbor caught me working on the battery base the other day...
rjmcdermott81
k, progress on the battery mount has been slow. The first design had the batteries sitting too high so now I have a steel base that will mount directly to the subframe.
Base on subframe
Batteries mounted to base (this is upside down)
Base in car
Testing with batteries
Now with bracket on top batteries
Test fitting other 6 batteries
Clearance under the hood
rjmcdermott81 wrote: Thu May 13, 2021 11:07 am My neighbor caught me working on the battery base the other day...
Thats what is great about working outside :)
Nice work.
rjmcdermott81
Boxed out the lower section of the battery box.
