GS 450H Web Interface
- Been thanked: 12 times
Can the GS450H VCU Web interface with all the Parameters be access using Version V3_user.ino Software?
- Has thanked: 10 times
- Been thanked: 335 times
Re: GS 450H Web Interface
As explained in the video all except current and power are functional as these would require the isa shunt to provide this data.
Thanks for the reply,
But I must be asking the wrong question.
I see in other videos where You and Johannes changes settings. Where you adjust offsets, Charge currents, etc.
Are those setting/parameter available for the GS450H VCU?
I hope i make sense.
Quote from the wiki :
