https://github.com/jsphuebner/stm32-template
It lets you build an application using proven hardware abstraction and libopencm3. When using the provided facilities you automatically have OTA (update via web interface) and the known parameter and spot value display of the esp8266 web interface (either Dimas or mine). Also the CAN mapping is tied right in. As opposed to Arduino you are not limited in the number of CAN messages you can send.
EDIT: I should add: I even added some comments to tell you what to do
The project is intended for any variant of the STM32F1. The differences in page size must be accounted for. E.g. the STM32F103 has 1kb page size and the STM32F105 has 2kb page size. This must be changed in the boot loader and also in the application (hwdefs.h). Also the addresses where CAN map and parameters are stored must be moved 2kb apart in that case.
Let us know what you do with it
