Just started a new Instagram account: https://www.instagram.com/p/CJfB11vBamG ... auekto8359
I have a rather large project in the coming.
My BMW 523i E61 is going to have a new Power plant and battery, the car should become a sleeper.
Tesla brakes, but the cars interior and instrument should stay original, My Maxecu sport controller has full control over e6x canbus. My thought is to use original buttons and rpm/fuel/gpm meter and replace vinyl with new scale.
Next weekend the drive-line of the e61 will be removed.
At first i will add some photos to summarize the thread
This is the donor car, bmw 523i with bad engine, zero comp on 3/6 pistons
This is the Tesla model 3 battery, Longrange 75kwh approx mileage 1000km
This unit is going to be placed under te floor,
I am very curious about the release of the control unit for Tesla model 3 pcm and bms
Keeps my fingers crossed that they will soon be for sale
This i the Tesla LDU sport, Newly cleaned
Disassembly of inverter and replace pcb,
Simple testing bench build, Works very good, i use the original cabling, change encoder cable pins.
At first test i heard a light "vining" noise, Probably some bad bearing i suppose, time to tear apart.
All gears look fine, the bearing at rotor was fine but at first axle the bearings was very bad,
They have tried to use standard steel bearing, not a very great result unfortunately, eaten by currents.
The new bearings will be hybrid, aka ceramic balls.
The rest of the bearings in gearbox is fine but it is simple to replace so i change them all.
Problem was to find internal seals, after 1 month of research i luckily found it at an Chinese Tesla supplier
This is the new controller that should make my life easier, Maxecu Sport, Canbus ready.
This is just the first sample, may soon be edited,
