- Has thanked: 550 times
- Been thanked: 53 times
I would say yes, but I haven't uploaded latest version
Thanks for the reply look forward to hearing your progress on charging and maybe YouTube video of it.
My gen2 inverter settings running a toyota mgr. I have looked for Damiens settings for the gen2 from the tuning video which he said he was going to post but cannot find them as I was going to post there.
- GEN2MGRBENCH1.json
- (1.25 KiB) Downloaded 309 times
Throttle pedal can accelerate but not decelerate.
When I press down no my pedal, the motor starts up but stay at a particular speed and will not shutdown until I stop the inverter.
Has anyone come across this?
4.94.R-FOC
Hear are my parameters for my Gen 2 inverter Gen 3 Transaxle.
"curkp": 32,
"curki": 20000,
"curkifrqgain": 50,
"fwkp": -100,
"dmargin": -2000,
"syncofs": 10200,
"polepairs": 4,
"respolepairs": 2,
"encmode": 4,
"fmax": 500,
"numimp": 256,
"dirchrpm": 2000,
"dirmode": 4,
"snsm": 16,
"pwmfrq": 2,
"pwmpol": 0,
"deadtime": 63,
"ocurlim": 100,
"il1gain": 3.06,
"il2gain": 3.06,
"udcgain": 6.15,
"udcofs": 0,
"udclim": 540,
"snshs": 0,
"pinswap": 5,
"bmslimhigh": 50,
"bmslimlow": -1,
"udcmin": 0,
"udcmax": 520,
"idcmax": 5000,
"idcmin": -5000,
"tmphsmax": 150,
"tmpmmax": 300,
"throtmax": 100,
"throtmin": -100,
"chargemode": 0,
"chargecur": 0,
"chargekp": 80,
"chargeki": 10,
"chargeflt": 8,
"chargemax": 90,
"potmin": 600,
"potmax": 4059,
"pot2min": 0,
"pot2max": 0,
"potmode": 0,
"throtramp": 0.43,
"throtramprpm": 20000,
"throtcur": 1,
"brknompedal": -20,
"regenramp": 1,
"brknom": 20,
"brkmax": -15,
"brkcruise": -15,
"brkrampstr": 10,
"brkout": -50,
"idlespeed": -100,
"idlethrotlim": 50,
"idlemode": 3,
"speedkp": 0.25,
"speedflt": 5,
"cruisemode": 2,
"udcsw": 0,
"udcswbuck": 540,
"tripmode": 0,
"pwmfunc": 0,
"pwmgain": 100,
"pwmofs": 0,
"canspeed": 1,
"canperiod": 0,
"manualiq": 0,
"manualid": 0
Thanks in advance
4.94.R-FOC
"curkp": 32,
"curki": 20000,
"curkifrqgain": 50,
"fwkp": -100,
"dmargin": -2000,
"syncofs": 10200,
"polepairs": 4,
"respolepairs": 2,
"encmode": 4,
"fmax": 500,
"numimp": 256,
"dirchrpm": 2000,
"dirmode": 4,
"snsm": 16,
"pwmfrq": 2,
"pwmpol": 0,
"deadtime": 63,
"ocurlim": 100,
"il1gain": 3.06,
"il2gain": 3.06,
"udcgain": 6.15,
"udcofs": 0,
"udclim": 540,
"snshs": 0,
"pinswap": 5,
"bmslimhigh": 50,
"bmslimlow": -1,
"udcmin": 0,
"udcmax": 520,
"idcmax": 5000,
"idcmin": -5000,
"tmphsmax": 150,
"tmpmmax": 300,
"throtmax": 100,
"throtmin": -100,
"chargemode": 0,
"chargecur": 0,
"chargekp": 80,
"chargeki": 10,
"chargeflt": 8,
"chargemax": 90,
"potmin": 600,
"potmax": 4059,
"pot2min": 0,
"pot2max": 0,
"potmode": 0,
"throtramp": 0.43,
"throtcur": 1,
"brknompedal": -20,
"regenramp": 1,
"brknom": 20,
"brkmax": -15,
"brkcruise": -15,
"brkrampstr": 10,
"brkout": -50,
"idlespeed": -100,
"idlethrotlim": 50,
"idlemode": 3,
"speedkp": 0.25,
"speedflt": 5,
"cruisemode": 2,
"udcsw": 0,
"udcswbuck": 540,
"tripmode": 0,
"pwmfunc": 0,
"pwmgain": 100,
"pwmofs": 0,
"canspeed": 1,
"canperiod": 0,
"manualiq": 0,
"manualid": 0
Thanks in advance
- Has thanked: 369 times
- Been thanked: 1542 times
If manualid causes rotation you haven't set up syncofs correctly. Also set deadtime to 0.
Yes I have and as Johu suggested, syncoff is incorrect.
Thanks for your suggestions guys, I think I've made some progress, but still having strange problems.
After a certain level of acceleration, the motor looses control and can only be stopped by stopping the inverter. I can now control the motor speed at very low RPM with the throttle pedal however this as at a very low, slight amount of pressure on the throttle.
Yup, syncoff setting is still not correct. I presume you have watched Damien's video on the subject, it REALLY explains the idea well.vin wrote: ↑Tue Nov 17, 2020 5:55 pm Thanks for your suggestions guys, I think I've made some progress, but still having strange problems.
Have you upgraded to the latest software? We had this problem when testing the motor in reverse. As a test try setting fwkp=0
Thanks Johu
Just to say, With regards to the setting of Syncofs, I did not realise that there could be multiple troughs, and was fooled into thinking I had the right one. I'm making some progress.
Looks much better
That is a VERY good point and you are right! I thought 22k was "it", until I re-ran everything and ended up at about 1/2 of that, 10975.
Inverter Shuts Down When Under Load.
When apply throttle without a load, the motor spins up and can get up to 6000+ RPM. However if I apply load to the motor very gently, I get movement, however if I apply the slightest jerk of energy to the throttle, the inverter goes into Opmode OFF.
Any help would be appreciated.
My parameters are as follows.
curkp": 32,
"curki": 20000,
"curkifrqgain": 50,
"fwkp": -100,
"dmargin": -2000,
"syncofs": 55000,
"polepairs": 4,
"respolepairs": 2,
"encmode": 4,
"fmax": 500,
"numimp": 256,
"dirchrpm": 2000,
"dirmode": 1,
"snsm": 13,
"pwmfrq": 2,
"pwmpol": 0,
"deadtime": 0,
"ocurlim": 100,
"il1gain": 3.06,
"il2gain": 3.06,
"udcgain": 6.15,
"udcofs": 327,
"udclim": 540,
"snshs": 0,
"pinswap": 5,
"bmslimhigh": 50,
"bmslimlow": -1,
"udcmin": 0,
"udcmax": 520,
"idcmax": 5000,
"idcmin": -5000,
"tmphsmax": 150,
"tmpmmax": 300,
"throtmax": 100,
"throtmin": -100,
"chargemode": 0,
"chargecur": 0,
"chargekp": 80,
"chargeki": 10,
"chargeflt": 8,
"chargemax": 90,
"potmin": 1200,
"potmax": 2600,
"pot2min": 0,
"pot2max": 0,
"potmode": 0,
"throtramp": 40,
"throtcur": 1,
"brknompedal": 0,
"regenramp": 0.28,
"brknom": 20,
"brkmax": -15,
"brkcruise": -15,
"brkrampstr": 10,
"brkout": -50,
"idlespeed": -100,
"idlethrotlim": 80,
"idlemode": 3,
"speedkp": 1,
"speedflt": 5,
"cruisemode": 0,
"udcsw": 0,
"udcswbuck": 540,
"tripmode": 3,
"pwmfunc": 0,
"pwmgain": 100,
"pwmofs": 0,
"canspeed": 1,
"canperiod": 0,
"manualiq": 0,
"manualid": 0
curkp": 32,
"curki": 20000,
"curkifrqgain": 50,
"fwkp": -100,
"dmargin": -2000,
"syncofs": 55000,
"polepairs": 4,
"respolepairs": 2,
"encmode": 4,
"fmax": 500,
"numimp": 256,
"dirchrpm": 2000,
"dirmode": 1,
"snsm": 13,
"pwmfrq": 2,
"pwmpol": 0,
"deadtime": 0,
"ocurlim": 100,
"il1gain": 3.06,
"il2gain": 3.06,
"udcgain": 6.15,
"udcofs": 327,
"udclim": 540,
"snshs": 0,
"pinswap": 5,
"bmslimhigh": 50,
"bmslimlow": -1,
"udcmin": 0,
"udcmax": 520,
"idcmax": 5000,
"idcmin": -5000,
"tmphsmax": 150,
"tmpmmax": 300,
"throtmax": 100,
"throtmin": -100,
"chargemode": 0,
"chargecur": 0,
"chargekp": 80,
"chargeki": 10,
"chargeflt": 8,
"chargemax": 90,
"potmin": 1200,
"potmax": 2600,
"pot2min": 0,
"pot2max": 0,
"potmode": 0,
"throtramp": 40,
"throtcur": 1,
"brknompedal": 0,
"regenramp": 0.28,
"brknom": 20,
"brkmax": -15,
"brkcruise": -15,
"brkrampstr": 10,
"brkout": -50,
"idlespeed": -100,
"idlethrotlim": 80,
"idlemode": 3,
"speedkp": 1,
"speedflt": 5,
"cruisemode": 0,
"udcsw": 0,
"udcswbuck": 540,
"tripmode": 3,
"pwmfunc": 0,
"pwmgain": 100,
"pwmofs": 0,
"canspeed": 1,
"canperiod": 0,
"manualiq": 0,
"manualid": 0
My last saved are below as a reference, Prius Gen2 + Lexus MGR. I will try and highlight what I think might be any important differences.
"curkp": 32,
"curki": 20000,
"curkifrqgain": 50,
"fwkp": -100,
"dmargin": -2000,
"syncofs": 9700,
"polepairs": 4,
"respolepairs": 2,
"encmode": 4,
"fmax": 400,
"numimp": 16,
"dirchrpm": 50,
"dirmode": 1,
"snsm": 14,
"pwmfrq": 1,
"pwmpol": 0,
"deadtime": 0,
"ocurlim": 50,
"il1gain": 3.15,
"il2gain": 3.15,
"udcgain": 3.75,
"udcofs": 327,
"udclim": 250,
"snshs": 0,
"pinswap": 5,
"bmslimhigh": 50,
"bmslimlow": -10,
"udcmin": 6,
"udcmax": 320,
"idcmax": 10,
"idcmin": -40,
"tmphsmax": 120,
"tmpmmax": 100,
"throtmax": 100,
"throtmin": -5,
"chargemode": 0,
"chargecur": 0,
"chargekp": 80,
"chargeki": 10,
"chargeflt": 8,
"chargemax": 90,
"potmin": 775,
"potmax": 3900,
"pot2min": 4095,
"pot2max": 4095,
"potmode": 0,
"throtramp": 0.84,
"throtramprpm": 6500,
"throtcur": 1,
"brknompedal": -50,
"regenramp": 0.53,
"brknom": 0,
"brkmax": -5,
"brkcruise": -30,
"brkrampstr": 20,
"brkhistr": 1000,
"brkhistp": 1000,
"brkout": -10,
"idlespeed": 0,
"idlethrotlim": 0,
"idlemode": 3,
"speedkp": 0.25,
"speedflt": 5,
"cruisemode": 0,
"udcsw": 8,
"udcswbuck": 8,
"tripmode": 2,
"pwmfunc": 0,
"pwmgain": 100,
"pwmofs": 0,
"canspeed": 1,
"canperiod": 0,
"manualiq": 0,
"manualid": 0
"curkp": 32,
"curki": 20000,
"curkifrqgain": 50,
"fwkp": -100,
"dmargin": -2000,
"syncofs": 9700,
"polepairs": 4,
"respolepairs": 2,
"encmode": 4,
"fmax": 400,
"numimp": 16,
"dirchrpm": 50,
"dirmode": 1,
"snsm": 14,
"pwmfrq": 1,
"pwmpol": 0,
"deadtime": 0,
"ocurlim": 50,
"il1gain": 3.15,
"il2gain": 3.15,
"udcgain": 3.75,
"udcofs": 327,
"udclim": 250,
"snshs": 0,
"pinswap": 5,
"bmslimhigh": 50,
"bmslimlow": -10,
"udcmin": 6,
"udcmax": 320,
"idcmax": 10,
"idcmin": -40,
"tmphsmax": 120,
"tmpmmax": 100,
"throtmax": 100,
"throtmin": -5,
"chargemode": 0,
"chargecur": 0,
"chargekp": 80,
"chargeki": 10,
"chargeflt": 8,
"chargemax": 90,
"potmin": 775,
"potmax": 3900,
"pot2min": 4095,
"pot2max": 4095,
"potmode": 0,
"throtramp": 0.84,
"throtcur": 1,
"brknompedal": -50,
"regenramp": 0.53,
"brknom": 0,
"brkmax": -5,
"brkcruise": -30,
"brkrampstr": 20,
"brkhistr": 1000,
"brkhistp": 1000,
"brkout": -10,
"idlespeed": 0,
"idlethrotlim": 0,
"idlemode": 3,
"speedkp": 0.25,
"speedflt": 5,
"cruisemode": 0,
"udcsw": 8,
"udcswbuck": 8,
"tripmode": 2,
"pwmfunc": 0,
"pwmgain": 100,
"pwmofs": 0,
"canspeed": 1,
"canperiod": 0,
"manualiq": 0,
"manualid": 0
I have a very similar problem to vin. I have now got an MGR mounted in my car and driving the wheels. If I’m gentle with the throttle with the wheels off the ground I can spin up to 6000rpm. However, I can’t move the car at all, I just get some jerky movement and then an overcurrent trip. Watching the current plots suggests that none of the current values are exceeding 25A when the trip occurs, although there is a fair bit of noise on the graph. The DC current is only an amp or two.
I did get some overcurrent trips when trying to set syncofs in manual mode too so I’m not 100% confident that I have this right although it appears to be very similar to what others have found on the MGR (~11000).
With the FOC software, how does the overcurrent trip work? What value sets the current limit?
I noticed the ocurlim parameter is hidden, I presume this is because it isn’t used?
Maybe "throtcur" is too high? I interpreted throtcur=1 as "1% = 1A", so 33% = 33A, but that might not be accurate.
I tried altering that. It actually felt a bit better when I increased it but I still had the same overcurrent problem.
Indeed on the Prius boards there is no over current comparator like on other boards. It relies solely on the over current detection inside the Prius inverter. So if you are presented with over current it actually means the Prius inverter signalled that. OR: there is noise MFIV. You can disconnect MFIV and tie the according pin to 12V. It's not gonna do any harm, the inverter will simply ignore the PWM on overcurrent.
If that helps you could increase C1 to 10nF or even 100nF.
Thanks, that’s really helpful! I will give that a try.johu wrote: ↑Tue Dec 22, 2020 9:46 pm
Just to clarify, you mean to put 12v onto pin 27 of the openinverter VCU so that the pin is permanently high? I guess the Prius inverter pulls that low when there is a fault?
Yes exactly. Disconnect the Prius pin.
tom3141 wrote: ↑Tue Dec 22, 2020 5:03 pm I have a very similar problem to vin. I have now got an MGR mounted in my car and driving the wheels. If I’m gentle with the throttle with the wheels off the ground I can spin up to 6000rpm. However, I can’t move the car at all, I just get some jerky movement and then an overcurrent trip. Watching the current plots suggests that none of the current values are exceeding 25A when the trip occurs, although there is a fair bit of noise on the graph. The DC current is only an amp or two.
Hi Tom, I changed my throtramp to be 0.5 and it makes a difference. Not sure whether this would be a permanent solution, as it significantly drops the acceleration from a start of point, however it gives you movement with load. I haven’t tried Johannes’ recommendation as yet because as you rightly said, amperage doesn’t even hit 25A
I have just tried Johannes suggestion so that I now have pin 27 (MFIV) connected permanently to 12v. I’m still having exactly the same issue. Overcurrent error with any load. I’ve tried lowering the throtramp and regenramp right down but it doesn’t help.
If an overcurrent error can only come from the Prius, I’m confused as to how I’m still getting an error!
I’ve watched the din_ocur value and it doesn’t change from 1 when it trips.
Tom, unless I misunderstood what was written, the VCU pin 27 gets pulled high and DISconnect it from the Prius Inverter pin 27. You may have done exactly that.
I have completely disconnected the wire between the Prius inverter and VCU pin 27. I have connected pin 27 on the VCU permanently to 12v. The Prius MFIV output is not connected to anything.
As far as I understand from what Johannes said, the MFIV output is the only thing that should cause an overcurrent fault on the VCU.
