What Should I Harvest from Chevy Volt?
bobbyj_408
Post by bobbyj_408 »
A local yard has a pretty in tact 2014 Chevy Volt, with various parts available. I'm thinking of getting the batteries, and using it with a 450h build I'm planning. I could probably get the batteries for $1500, that sounds like a good deal, right? My question is, are there any other parts from the volt that I should harvest as well? I'd really appreciate your thoughts.
Thanks!
Has thanked: 134 times
Been thanked: 335 times
Re: What Should I Harvest from Chevy Volt?
bobbyj_408 wrote: Tue Nov 17, 2020 6:59 pm Hi,
Thanks!
Battery definitely.
I consider inverter good part. Then there is DCDC module or APM in the back. Also charger is a good unit.
You want to get the emergency disconnect between rear seats. Its 350A fuse and is convenient for servicing.
Maybe also a heater element with cables and connectors.
Then you may want to keep a coolant pump and 3 way valve.
Maybe you want to use brake booster?
bobbyj_408
arber333 wrote: Tue Nov 17, 2020 8:48 pm Battery definitely.
Nice.
Hmmm, would I need the inverter from the Volt if I'm using the inverter from the lexus to control the motor? Any other use for it?
Great! Good call! Is there a useful resource out there to communicate with the DCDC and the charger?
Will do!
That's the cabin heater, right?
Nice, yeah, great idea. This is used for battery cooling, right?
Yeah, probably. I suppose this is a system that doesnt need a vacuum assist?
bobbyj_408 wrote: Wed Nov 18, 2020 4:52 am Great! Good call! Is there a useful resource out there to communicate with the DCDC and the charger?
See here:
https://leafdriveblog.wordpress.com/201 ... dc-or-apu/
https://leafdriveblog.wordpress.com/201 ... a-charger/
Are you in US? Then you can also salvage the charging port and Volts charging cable.
No vacuum, there is a hydraulic servo inside.
clanger9
Post by clanger9 »
The heat pump would be a nice thing to salvage.
bobbyj_408
arber333 wrote: Wed Nov 18, 2020 7:22 am
See here:
Nice! Thanks for the links.
I do live in the US, so I'll grab that port and charger!
bobbyj_408
clanger9 wrote: Wed Nov 18, 2020 5:56 pm The heat pump would be a nice thing to salvage.
Nice! Is this a heat pump for cabin heating?
clanger9
Post by clanger9 »
Yes - it's quite powerful and runs the battery & cabin heating/cooling circuit.
bobbyj_408
Nice! I'll definitely grab that. Thanks for the advice!
Has thanked: 168 times
Been thanked: 350 times
The volt uses an Bosch iboost brake servo. If I can get it for cheap, definitely worth it. top tier ev brake system right there!
charger and dcdc converters are great small units. Worthy!
High voltage wiring harness,
-worth taking if a good price. That will give you plenty of cabling and connectors for your charger, dcdc, heater, etc.
coolent pumps!
