Has thanked: 370 times
Been thanked: 1547 times
ZooKeeper wrote: Tue Oct 06, 2020 10:15 pm Edit: If you hear PWM, the VCU is signaling the inverter from my experience. When I was not getting any inverter output, I also could not hear any PWM.
Maybe no all phases are firing
hugow93
Has thanked: 24 times
Been thanked: 9 times
Post by hugow93 »
johu wrote: Wed Oct 07, 2020 7:42 am
Yeah, I think that's probably the case. Is there an easy way to verify this?
I'm ordering some replacement ULN2003 ICs now. Given the damage on the existing one, that's my best guess at the cause.
Thanks for the clarification Zookeeper, will get practicing my surface mount soldering!
Converting a1994 Suzuki Samurai soft top
| Siemens 1PV5135 Motor | Gen 2 Toyota Prius Inverter + OI Control Board | 24 kwh Renault Zoe battery |
ZooKeeper
Post by ZooKeeper »
When I had the VCU mis-pinned to the inverter, there was no audible PWM nor measurable ULN output.
imwoody36
Post by imwoody36 »
hugo, when I had that problem... it was a cold solder connection at the MCU. is your board one that needed the microprocessor rotated before johu shipped it to you?
...Oh, just saw your message and photo...yes, you have a bad 2003, I got mine from amazon
the priustoric boatcar guy
imwoody36 wrote: Thu Oct 08, 2020 5:47 pm hugo, when I had that problem... it was a cold solder connection at the MCU. is your board one that needed the microprocessor rotated before johu shipped it to you?
No, you and Damien were the only ones blessed with a hand rotated MCU ;)
Pcstreet
Post by Pcstreet »
Hi to you all you are all doing great work. I'm new to this and being a retired mechanic I thinking about using a mgr to replace Beetle engine and box. My question is if I get a gen 2 board from JLCPCB how do I install the stm32 bootloader. I've watched Damien's video on using stlink v2 to do this but which pins on the gen 2 board do I connect to or do I just need to purchase the pre programmed mod-esp8266 from the shop. I would love to purchase the gen 2 board kit but on a very tight budget any help would be much appreciated.
RetroZero
Been thanked: 53 times
Post by RetroZero »
I damaged my first board (and I was not alone), bought a STM Nucleo thingy to try and swop stm32 and reprogramme it. Didn't work (blame it mostly on inadequate tools) and lack of experience.
What I am saying is, try to buy the community kit, there's enough to deal with setting it up, so if you add sourcing items yourself and not using Esp wifi, it complicates diagnostics when solicitating the forum. Oh, and TIME. You need loads more if on a tight budget. My humble non electronics engineer opinion.
Pcstreet
Post by Pcstreet »
Thanks for the reply retrozero I'm going to buy the esp Wi-Fi from the shop but in Damien's video he says you need to program the bootloader and foc first to the stm on the board. On his board he as 3 pins clock ,data and ground to connect the stmlink v2 tool. These are marked on the board but I can't see them on the gen2 board so I wondered if you need to do it on the gen2 board.
RetroZero
Post by RetroZero »
Euh, if it's the adapter board in this thread - for toyota prius gen 2 inverter, the option is through Openinverter Shop. Not EVBMW. It is Johannes that has 'taken over' code développement of this particular board. It comes with all software. Updates and changes between Sine and Foc is done via wifi.
Pcstreet
Post by Pcstreet »
Yes it is this board and thanks for your help
Pcstreet
Post by Pcstreet »
Hi again got my board connected to power and ground got 2 red led one flashing. Put in the Wi-Fi module and red led on. Green led flashes when I change firmware. So my question is does the board need to be wired to a inverter to show parameters as all I see is like spinning wheels at the side thanks Paul
No you just need power
Has thanked: 10 times
Been thanked: 335 times
RetroZero
Post by RetroZero »
The things you do for the internet! Merci 😁. Very instructive.
Has thanked: 403 times
Been thanked: 260 times
Post by MattsAwesomeStuff »
For the dumb ones of us... what's the takeaway from the video?
Like, I'm not even sure what people were skeptical of and what they were saying couldn't or had to be done... let alone in what way this disproves that.
Something about how people think you need 600v to run a Gen2? And, the video shows that you... don't (except for all the times it spikes to 500v?).
My hunch is that the conclusion is "Shut up, a 250v battery pack is fine and the motor can still reach highway speeds", but, is that true?
I think I need a little nudge to get the context better.
ZooKeeper
Post by ZooKeeper »
My MGR will happily spin at way faster than highway speeds with sub 200v power, so with that and the video, I would conclude that:
- Higher volts = lower Amps for same POWER
- All the talk of "Back EMF", while accurate, does not impart a NEED for high voltage
- Voltage does equate to RPM, but not the only factor
- Voltage is the PUSH for Amps
- The power (kW) required can be met by a combination of V & A over a wide range
If I have any of that wrong, please do offer a correction :D
RetroZero
Post by RetroZero »
Agree with Matt and Zookeeper. Don't need 650v to run a prius efficiently.
However, the higher the voltage, the wider the operating range AND the slower the depletion rate of battery pack.
Find that sweet point between min operating voltage and maximum range from your battery pack. Since homologation costs here are proportional to modifications complexity, I plan to run the most stock standard option. 250v pack (bit more than standard Gen 2), but more in parallel.
My problem is the jumper wire to bypass buck/boost converter, limiting 20kw...(which I think needs to be removed before using the inverter as a charger) might have to install a kilovac to solve that issue. Then I need to prove the bypass will not be a safety issue, however, driving around and proving there is no "black smoke release" is not enough.
Not lamenting BTW, I love these challenges way over the top... Damien's video reassures the fact that even at 200v we can be rolling.... how far? Depends on how big your pack is 😉
How so? You can pull 100A from a 400V, x Ah pack or 200A from a 200V, 2x Ah battery pack. Depletion rate will be the same.
I really shouldn't have made that video ....
Isaac96
Post by Isaac96 »
Too late Damien, just head off to Lanzarote with your ad revenue :)
We do know that the Prius works at just about any voltage.
Higher voltages require less field weakening.
Field weakening is less efficient because of the extra current required (is it? there's something like that).
That does not mean that you need 650v.
400v seems to be an excellent voltage for running all these Toyota/Lexus motors, as seen on DamienTV. 650V is all well and good but not necessary in the slightest.
bexander
Has thanked: 71 times
Been thanked: 97 times
Post by bexander »
The video is excellent!
To keep this thread on topic I have started a new one to discuss the video.
Can be found here:
viewtopic.php?f=14&t=1155
RetroZero
Post by RetroZero »
johu wrote: Sat Oct 31, 2020 2:12 pm
Yup, I still got lots to learn : Volts X Amps = Watts
Amp-Hour is whats going to change how far down the road you go. Ithink
Pcstreet
Post by Pcstreet »
Hi again got everything wired up and getting a message in spot values saying udcbelowudcsw wondered what it means and would it stop the motor spinning. I'm trying to run the motor on 12v hv and what should the pinswap say in the latest foc. Any help would be welcome thanks Paul
Isaac96
Post by Isaac96 »
UCDbelowUDCSW means that your voltage is lower than the 'udcsw' parameter. Set udcsw to 0, that should do the trick as long as your udc is calibrated.
Pcstreet
Post by Pcstreet »
Thanks for that should the pinswap be set to 5 for the gen2 inverter running a mgr as in the tuning video by damien and Joho.
