- bexander
- Has thanked: 78 times
- Been thanked: 102 times
How did you measure the resistance? Just using a multimeter for low resistances is a bit inaccurate.
May I suggest using a bench power supply and push 10A (verify the current with a multimeter) through the inductor and measure the voltage drop in mV mode on the multimeter. Then calculate the resistance. This will give more accurate result.
johnspark
- Has thanked: 59 times
- Been thanked: 48 times
yes you are right bexander, i used to have access to a 10 amp and a 100amp ductor, but i dont work at the company that has those things anymore. Probably could inject 10 amp as you say and measure v drop.
- Been thanked: 1115 times
Sorry guys can we keep on topic please. If you wish to discuss the boost inductor characteristics please start a new thread.
Programming guide video is now live :
- Has thanked: 478 times
- Been thanked: 307 times
Left this as a Youtube comment. I lack skills or funds to contribute, so, just trying to do what I can.
This tutorial will show you how to program both of the chips on the Prius Inverter Logic Board, the "STM32" and the "ATmega328p", necessary for getting the inverter board to work, for those who chose to just purchase the populated board. If you purchased the full kit, these will already be programmed.
Timestamps:
1 - Power the board. 12v to the board. Top left (outside) is ground. 6 pins down is the 12+. Red LED should stay lit.
2 - STM32 Programming. Several methods. You're watching a tutorial, so this is the easiest method. Purchase an "ST-Link v2" dongle from eBay, only a few dollars, it usually comes with the jumper wires. The pinout is shown right on the case. You will not use all the wires, only 3 of them. These 3 wires connect to 3 pins on the Prius Logic Board (but not in the same order).
You will use:
"SWCLK" (single wire clock) - To outside pin closest to board edge.
"SWDIO" (single wire data input and output) - To inside pin.
"GND" (ground) - To middle pin.
Then plug the dongle into a USB port on a PC.
3 - ST-Link Software. Link in description. Download and install it.
In the main viewing window are multiple tabs, click the "Binary File" tab to select it. This will ask to open a file, you choose: "stm32_loader.hex" from OpenInverter.org, download ahead of time. This will change what shows up in the viewing window.
Click "Target --> Program and Verify" from the top menu.
This pops up a window, and you can probably just click "Start" on that window. This programs the STM32 chip with the stm32_loader.hex file.
The STM32 on your Prius Inverter Board can now load other files.
You can close the stm32_loader.hex tab, and go back to the "Binary File" tab, which will ask to open another file. You choose: "stm32_sine.hex" or whatever other OpenInverter.org configuration file makes sense for your project (.hex for motors with encoders, .foc for motors with resolvers, the type of motor you are using determines which of these to pick).
The STM32 on your Prius Inverter Board now also has the software to run a motor using a sine wave (or FOC) and is set to use that.
A different red LED on the Prius Inverter Board will not be rapidly blinking continuously.
You are now done with the ST-Link USB dongle, it's no longer needed. Future updates can be done via wifi.
4 - Programming the AT-MEGA 328P chip. There are many ways to do this, you are watching a tutorial, so this is the easiest.
You will need to purchase an "Atmel-ICE" device. Plug one end of the ribbon cable it comes with into the "AVR" plug on the device. Plug the other rend of the ribbon cable into the (only) 6-pin header on the Prius Inverter Board, with the tab on the plug facing the outside of the board.
A green led will illuminate on the Atmel ICE device.
(Damien skipped this). Plug the Atmel ICE into a USB port on a PC.
5 - Atmel Studio Software. Link in the description. Download and install it.
Click "Tools --> Device Programming" from top menu.
A window appears, select:
"Tool" - Atmel-ICE
"Device" - ATmega328p
"Interface" - ISP
Click Apply.
Click "Read" below "Device Signature", to initiate communication with the chip. Some numbers and symbols should now appear below the Device Signature.
On the left menubar, select "Fuses". In the pane to the right, under "Fuse Register", change the values to match the following:
EXTENDED: 0x05
HIGH: 0xDE
LOW: 0xFF
Click the "Program" button on the bottom right of this pane to program the chip. A quick progress bar will appear and the chip will program
Just to the right of "Program", click the "Read" button. Then, back up top by the Device Signature, click that "Read" button too. (Why?)
On the left menubar, select "Memories". In the pane to the right, is a "Flash" title, and a file you can choose. You want to choose: "optboot_atmega328.hex" from wherever you installed your Arduino IDE. (We've skipped the step of downloading an Arduino IDE?).
Click the "Program" button right below the Flash and filename.
The ATmega328p chip should now have an Arduino bootloader loaded onto it, which means the Arduino software can now load files onto that chip.
6 - Conclusion. Don't do this, and don't support Damien, he has threatened to make more videos and boards if you do.
A couple bits were ambiguous to me, I added some commentary that I hope is correct (I've never done this before, and I don't have one of these boards, and I'm not using a Gen3). Please correct me if I'm wrong.
Next some screencaps of the procedure might be helpful to people, either here or on the wiki.
I'm curious (but don't need to know), what the purpose of the ATmega328p is, and why we flashed it with an arduino bootloader. And what we then do with that in terms of getting a motor spinning or whatnot. Outside the scope of this episode perhaps.
Timestamps:
You will use:
"Tool" - Atmel-ICE
"Interface" - ISP
Click Apply.
EXTENDED: 0x05
HIGH: 0xDE
LOW: 0xFF
Anyone experiencing problems running motors in reverse after successful tuning please set fwkp to 0 and try again. Johannes and I are working on this problem. A full tuning and tutorial video can be expected in about a week.
So just to let folks know we do have a V1d version of the logic board on the way with the following additions :
-Second STM32 for running MG1 and MG2 in dual motor applications.
-MG1 cpu is slaved to MG2 via transcieverless CAN : https://www.mikrocontroller.net/attachm ... AP2921.pdf
-Dual wifi modules
-External connectors will remain the same with a few pin remaps.
-Buck / boost charge retained.
This will be sold as separate kit. V1c will remain available.
-Dual wifi modules
- Been thanked: 1913 times
Transceiverless CAN, thats really cool. So will you pre-program devices with things like pot already mapped?
Yeah for the full kits I'll configure both stm32 to communicate. Mg2 will send things like start, direction and throttle to mg1.
Cool progress!
As my build is pushing beyond "cheap easy summer project and on the road having fun" and into "several thousand, multi-year restoration" territory, choice of inverter and cost of control board are shrinking in comparable priority. By the time I'm ready to roll things, I might switch to the Gen 3.
- konstantin8818
- Has thanked: 2 times
- Been thanked: 10 times
Now that is interesting news =) Dual MGR system getting real.
- Has thanked: 166 times
- Been thanked: 411 times
Wow! Would it be possible to implement a sort of electronic differential drive with both motor interacting on torque output? We could have a sort of a torque converter drive similar to Volt/Ampera system where both motors are spinning to relieve traction motor of higher RPM losses. I am not sure where this would be used yet but it is really cool!Jack Bauer wrote: ↑Fri Sep 11, 2020 4:29 pm Yeah for the full kits I'll configure both stm32 to communicate. Mg2 will send things like start, direction and throttle to mg1.
- Bratitude
- Has thanked: 246 times
- Been thanked: 469 times
If I understand and what you are asking correctly, two separate motors driving separate axles, then You have torque vectoring. drive like it’s on rails around corners. it would significantly improve handling. add in input from a yaw sensor and steering wheel angle = a very awesome awd system.arber333 wrote: ↑Fri Sep 11, 2020 8:29 pmWow! Would it be possible to implement a sort of electronic differential drive with both motor interacting on torque output? We could have a sort of a torque converter drive similar to Volt/Ampera system where both motors are spinning to relieve traction motor of higher RPM losses. I am not sure where this would be used yet but it is really cool!Jack Bauer wrote: ↑Fri Sep 11, 2020 4:29 pm Yeah for the full kits I'll configure both stm32 to communicate. Mg2 will send things like start, direction and throttle to mg1.
or more related to driving the Prius trans axle?
No, my idea would be to run the MG1 WITH the MG2 in a sort of torque converter way.Bratitude wrote: ↑Sat Sep 12, 2020 8:04 pm If I understand and what you are asking correctly, two separate motors driving separate axles, then You have torque vectoring. drive like it’s on rails around corners. it would significantly improve handling. add in input from a yaw sensor and steering wheel angle = a very awesome awd system.
If you think about Leaf motor at speed i can attest it draws 40A when car is at 110km/h straight road (8000rpm) and 80A (!) when car is at 130km/h (9000rpm). I guess we call that windage and air drag losses. Volt fights this with its "long range mode" where generator helps to drive the axle and because of a reduction gear and clutches two motors end up running at lower RPM than one single motor would at high speed. I think in Volt this happens at like 100km/h. You can certainly feel the lag in thrust if you want to pull the car out of this mode by accelerating.
I also talked with a guy that was developing a sort of torque variable transmission drive where one motor would fight the other and result would be high RPM on the final drive while on the other side motors would still be in their comfort zone, no FW. I thought of that as application when Damien announced his next board.
Maybe i didnt get the setup correctly but using the PSD we could drive both motors separately and have some variable drive to gather torque/rpm onto one axle? I may be wrong and this would be only possible with Gen3 axle. I need to watch Mr. Kelly again....
I wanted to share my experience with doing a Gen3 Prius logic board swap with the group. I made a YouTube video walking through some aspects of doing the logic board swap (see below).
I’m doing my swap with a G9200-47210 inverter that I bought on eBay. From a little bit of internet sleuthing, it looks like this inverter in from a 2012 Prius. Of note is that this inverter uses a smaller format board that is 150mmx143mm (F1759-47070-05). I think the 2010-2011 Prius board are a larger size (like in Damien’s design). Since the board bolt pattern was different than Damien’s v1c design, I ended up drilling a new set of holes for the pin and screw hole in my board from JLCPCB.
[media] [/media]
I’ve still got a ways to go before I’m running a motor, but I thought my progress so far might be of interest to the group. I also wanted to let others know that I found this to be a very do-able project for those that have an interest in diy EVs and rudimentary soldering skills.
[media] [/media]
- Bratitude
arber333 wrote: ↑Sat Sep 12, 2020 8:43 pmNo, my idea would be to run the MG1 WITH the MG2 in a sort of torque converter way.Bratitude wrote: ↑Sat Sep 12, 2020 8:04 pm If I understand and what you are asking correctly, two separate motors driving separate axles, then You have torque vectoring. drive like it’s on rails around corners. it would significantly improve handling. add in input from a yaw sensor and steering wheel angle = a very awesome awd system.
This would be applicable to quite a few hybrid box’s wouldn’t it? If there’s enough difference in ratios, wouldn’t this be useful for increasing 0-60 while maintaining a higher top speed? Interesting.
V1d dual motor initial schematic attached.
- MG1 STM32 has no inputs other than CAN from MG2 STM32 for control.
One concern I have is I am reusing the bias circuit from the mg2 resolver for the mg1. I THINK it will be ok but ....
A fault in either mg1 or mg2 power stages shuts down both mg units.
MG1 and 2 disabled during charge.
Single TDA2822 used for both resolver exciters. One side for each MG.
Single 3v3 reg using AMS117. I THINK it will be ok but ....
PriusG3_V1d_dual - Schematic.pdf- (697.15 KiB) Downloaded 435 times
Really good management of resources JB! Could we use this single CAN bus to disable MG1 (or put it in freewheel mode) if it would not be needed?Jack Bauer wrote: ↑Sun Sep 13, 2020 9:40 am Single TDA2822 used for both resolver exciters. One side for each MG.
[/list]
And....here it is. The V1d now with 3 mcus on board:)
The program for release is :
*PDFs of schematic and pcb layout public now.
*Source files only available on Patreon for a period of time. Probably 6 to 12 months.
*Once bench tested both partial boards and full kits will be available from the webshop.
*Once bench tested a Yaris/Auris variant will be released in the same way.
PriusG3_V1d_dual_3D.pdf- (197.37 KiB) Downloaded 363 times
PriusG3_V1d_dual - Schematic.pdf- (697.1 KiB) Downloaded 410 times
PriusG3_V1d_dual - PCB.pdf- (472.73 KiB) Downloaded 481 times
V1d design updated and released on github:
https://github.com/damienmaguire/Prius- ... master/V1d
Prototypes on order from JLCPCB.
Now in production at JLCPCB:)
- bobby_come_lately
- Has thanked: 56 times
- Been thanked: 63 times
Nice! Great to see this design evolving. May be useful if my project turns out to need MOAR POWER!
m.art.y
- Has thanked: 38 times
- Been thanked: 37 times
Hi. On Prius gen 3 inverter v1c board there are two connectors conn3 and conn5. I understand conn3 is to enable dcdc converter when pins are shorted? What is conn5 and how it should be wired - are conn5 pins supposed to be shorted as well? Thanks
