EVBMW Leaf Gen 1 inverter board or Prius Gen 2 Inverter controller board
Alibro
Has thanked: 368 times
Been thanked: 221 times
Post by Alibro »
Hi Guys
I recently became the owner of an almost complete Gen 1 Nissan Leaf so after a few days stripping I have the motor and inverter along with many other bits on the bench. I also have a Gen 2 Toyota Prius inverter so I now have to decide which route to take, i.e. stick with the Leaf hardware and use the EVBMW controller board or use the Leaf motor and the Prius inverter with Johu's controller.
My original plan was to buy a Gen 2 Leaf and use Johu's controller board but the Gen 1 Leaf came along at a great price and I couldn't refuse.
I was about to launch into a question about which board should I go for then thought, Sod it and ordered Damiens board. :D
The Leaf inverter was designed to drive the Leaf motor so they should in theory be a better match than the LEaf motor with a Prius inverter.
I can always buy Johu's board later if I decide to go that way.
Just out of interest I thought I'd post this anyway to gauge other folks reactions. What would you have done?
Has thanked: 369 times
Been thanked: 1543 times
Re: EVBMW Leaf Gen 1 inverter board or Prius Gen 2 Inverter controller board
I would have hacked the Gen1 inverter for good with a drop-in board :) There is a working board out there, but not for sale anywhere.
The Leaf inverter is more capable in current capability and also in PWM frequency. 4.4kHz recommended for the Prius inverter is somewhat noisy. 8.8kHz is barely audible.
Alibro
Post by Alibro »
johu wrote: Thu Aug 27, 2020 8:03 pm I would have hacked the Gen1 inverter for good with a drop-in board :) There is a working board out there, but not for sale anywhere.
LOL, I might have known you would say that. :D If I could have hacked it I would.
80Kw is plenty for me (for now) so power is not a consideration. I guess as this is my first conversion simplicity is most important.
DaveH
Been thanked: 11 times
Post by DaveH »
It might be easier to get approval for the Leaf inverter/motor combination? Not having gone through it yet myself, I don't know if it actually makes a difference, but they have been EMC tested as a system.
