EM61 or EM57 motor
SciroccoEV
Been thanked: 15 times
EM61 or EM57 motor
Post by SciroccoEV »
I've got the option of either motor and will probably be separating the motor and inverter anyway.
From what I've been able to find online, the inverter integration with the motor and a change to cheaper magnet materials were the only significant changes for the EM57, but I've not been able to find anything on performance differences between the two.
Does anyone have any information?
Has thanked: 81 times
Been thanked: 244 times
Re: EM71 or EM57 motor
I found EM61 motor easier as standalone installation to existing cars gearbox. It is more round shape easier to conform to... But if used with original gbx both should be fine.
Personally I think the 61 is better motor with more hidden power. Since they made it first and tested it. Later on they optimised production for 57 which always means some cuts... They optimised with magnets and stator wire alloy.
Arlin demonstrated 61 can field 300hp! I haven't seen results for 57.
SciroccoEV
Well, based on that I have an EM61 with inverter and cabling on its way for £1000 delivered.
SciroccoEV wrote: Tue Aug 18, 2020 12:13 pm Well, based on that I have an EM61 with inverter and cabling on its way for £1000 delivered.
You wont be sorry. My Pug runs really good with one side of Volt inverter. Also a friend uses 61 with Mazda RX8 and original transmission. His system was 200Vdc but we will optimise to 360Vdc 96S. Should run up to 200km/h without FW.
zippy500
Has thanked: 40 times
Post by zippy500 »
Thats a good price
SciroccoEV
zippy500 wrote: Tue Aug 18, 2020 5:43 pm Thats a good price
I thought I was getting a Gen1 Motor, Inverter and interconnect wiring...
The delivery truck turned up just as I was about to set off to get the van MOT'd, so I had to get the pallet unloaded very quickly and shoved onto my property before rushing off to make my appointment.
Upon my return I started peeling off the layers of pallet wrap and cardboard. What I saw first was the end of a pair of driveshafts. Once fully exposed is became clear that I had essentially the complete contents of a Gen1 Leaf front compartment, Motor, Inverter, Gearbox, driveshafts, pumps, water heater, even the charge ports.
Well chuffed!
If I made new rear suspension links and a mounting subframe, it might just be possible to use the Leaf motor and gearbox rear mounted in the Excel.
SciroccoEV
Leaf meets Lotus
Alibro
Has thanked: 280 times
Been thanked: 159 times
Post by Alibro »
Nice one!
I hope you don't mind my asking but I had originally planned to get a Gen2 Leaf motor and use Johu's replacement logic board but I ended up with a complete Gen1 Leaf so now have to decide how to control the inverter. Any advice for a total novice? Would I be best to go for Damiens VCU?
I need a bigger hammer!
zippy500
Post by zippy500 »
nice project
Has thanked: 60 times
Been thanked: 180 times
Alibro wrote: Fri Aug 21, 2020 2:11 pm Nice one!
Can vcu or Prius gen3 inverter.
More pooowwwaaa baby. charger and dcdc. But more involved setup
