The project I have in mind, a Vauxhall Firenza, I've had the car in the workshop for a while with a good chunk of restoration bits complete, I've just been feeling a bit unenthusiastic about installing a big new Smogmaker. So started to explore options to convert I was initially put off due to cost and configuration of battery space. I think the gs450h platform has made my change my mind on this as its possible to use more of the engine bay for batteries with this configuration.
Electrickery Progress sofar;
Have Damien's vcu running and confirmed software is up to date, I have the wifi monitoring page working and Ive put together a wiring harness. next, get the ISA shunt working and displaying and assemble precharge. I can then test it all out (need to figure a temporary battery).
One issue I've been a little stuck on is final drive, I understand Damien is using a 2.88:1 diff on the Superyacht, but I think the simplest solutions for my build only go as high as 3:09:1 I'm not sure if this will present a large issue I may have to get creative.
Many Thanks Everyone, Tom
