I am planning to convert a 2006 Subaru Impreza WRX to EV
my idea was to use either 2xPrius gen3/4 transaxles(with 2x coresponding inverters) or 2xRX450H transaxles P313(with 2xGS450H inverters)
to do a system where it can either be RWD or AWD(with damiens boards controlling them)
all would have locked input shafts,
opel zafira electric power steering pump,
bmw up-32 brake vacuum booster,
some kind of oem electric A/C compressor
arrange batteries like a opel ampera/chevy volt battery pack
the plan was 2017 Renault Zoe 40kwh Battery pack, charger and charge plug(but i dont know if that would fit my application)
goals are
100km range
around 4-5 second 0-100kp/h (with AWD and sport mode enabled)
Maybe someday DC fast charging
i dont know much about CAN programming but i am willing to learn,
trained car mechanic so welding, cutting and fabbing is not a problem
it seems nobody is using the built in voltage booster(in the toyota inverters) is there a reason why?
this is the shell i plan to use(it needs a lot of parts and a lot of love to become perfect)
Best Regards
Martin
Denmark
