Haha :)
Shouldn't you see your typed password in the auto-complete list? I didn't make it a "password" field...
ZooKeeper
Has thanked: 8 times
Post by ZooKeeper »
It shows one digit at a time as you type it in, as is normal. The second I hit "ok", I knew I had fat-fingered something. Once I figure out how to get it on serial comms, I will change the PW again with AT commands and be back up and running!
This is 100% my fault, I should have taken more care in entering the new PW digits, but I was too cavalier about it and screwed myself.
imwoody36
Post by imwoody36 »
So I couldn't complete my mission to test the battery charging feature. Anyone have a left over buck/boost module (without inductor)? Yes I could just buy another inverter but my space is limited so I'd rather avoid it.
EDIT: whats the temperature curve for the heatsink sensor, anyone got that?
[/quote]
Yes Johu..I have many gen2 prius inverters laying around....want a care package? I am willing to ship for free just tell me what you want
the priustoric boatcar guy
I have a Prius inverter as well, but I'm too lazy to find the temp curve myself. It's supposed to be in the service manual but I couldn't find that either. So if someone could just post a screenshot that would help.
EDIT: I checked some old mails and found it. Small problem: I forgot the voltage divider so there will only be valid values starting at like 40°C
EDIT again: looks like -30mV per °C. Or -37 digit/°C. So T=167°C - ADC / 37 . Maybe I'll just add a "linear" option for tmphs
More editing: So it seems like the lowest measurable inverter temperature without voltage divider would be 56°C. So maybe it would be a good idea to add a 10k resistor in parallel to C37 to form a 1:2 voltage divider. I will add a hard coded formula in the next firmware that is always used in Prius hardware, i.e. "snshs" becomes meaningless, just like for the Tesla boards.
RetroZero
Has thanked: 645 times
Been thanked: 64 times
Post by RetroZero »
Thanks for checking all that Johu.
So for testing purposes, keep inverter cooled below 75°C (real) as to not create temp error.
Whilst waiting on next firmware update, a 10k resistor in parallel with C37 will solve the problem.
Me personally, I'll wait until firmware, even if I need to put iceblocks inside the inverter. Adapter board looks too good to go soldering resistors in addition 😊
The firmware is not going to increase the input voltage of the ADC ;) It will just get you a valid reading in the first place. Without the resistor you only see temperature changing above 56°C.
Just tested it with my Prius power stage and it works. If you install the 10k resistor you can measure down to about 0°C, otherwise it starts at 56°C. At startup it will check once for a voltage > 2.6V and if it sees that it will assume no 10k resistor is installed. It will of course fail to detect that if you start into a hot inverter, i.e. warmer than about 85°C.
stm32_sine.zip
(67.6 KiB) Downloaded 312 times
RetroZero
Post by RetroZero »
I wired up everything and got preharge and contact relays working.
I have 4 throttle faults (even with the pedal not connected)... Set potmin and potmin2 to values that are in plot values (when connected) but still the same faults.
Step by step
ZooKeeper
Post by ZooKeeper »
WHEW! That was not fun, but I got back in :D
As we can see, I have messed about some with the parameters trying to get spin. Screenshot is obviously not attempting any output as am not in manual mode and test params are zero.
current parameter settings
RetroZero
Post by RetroZero »
I started with 12v supply.
Boost 37000
Mode Permanent Forward
Fslipspnt 8
Ampnom 75%.
Got light bulbs in delta form to flash, then hooked up MG1
Cliffhanger ;)
Then what?
ZooKeeper
Post by ZooKeeper »
RetroZero wrote: Thu Jul 16, 2020 5:27 am I started with 12v supply.
Boost 37000
Fslipspnt 8
Ampnom 75%.
Thanks, I will try that as well and verify MSDN on #25.
imwoody36
Post by imwoody36 »
Imagethis is how I added a 10k resistor to c37
RetroZero
Post by RetroZero »
Nice.
I still have 4 throttle faults. But when I press the pedal, at about 3/4, potnom jumps to 85%.(I set pot values to min and max found in actual values when looking at spot values section) .
And light bulb on hv line starts flashing... Like dead short....
I'm only running on 12 v, I should get some motor spin on that, since it worked in manual mode?
ZooKeeper
Post by ZooKeeper »
IT WORKS! Flashing lights AND Jiggling MGR :D
MORE POWER!!!!!! "I'm Givin' her all she's got Capt'n"
Answer was provided by JH, I had pin 25 of the Prius Inverter marked for shifter I/O, needs 12v "Run" (Ignition switch, relay, etc) signal.
<edit: Adding settings, hope this helps others>
testing
testing
HIMC Testing1.png (2.99 KiB) Viewed 6470 times
regen
regen
contactor
contactor
HIMC Contactor Control1.png (4.79 KiB) Viewed 6470 times
derate
derate
inverter
inverter
motor
motor
LRBen
Has thanked: 122 times
Been thanked: 290 times
Post by LRBen »
Got the delta lights to flash using manual mode. Used the settings that Retrozero used as well as connecting inverter MSDN pin to the 12v supply.
I was expecting each light to flash in series. What I got was all lights flashing at once but at different levels of brightness. Is that the correct outcome?
Been thanked: 413 times
LRBen wrote: Thu Jul 16, 2020 6:55 pm Got the delta lights to flash using manual mode. Used the settings that Retrozero used as well as connecting inverter MSDN pin to the 12v supply.
Hm... that would be consistent... you are using incandesent bulbs. I used LEDs so i guess filament doesnt cool down very fast. Maybe you could command it 0.3Hz slip? That should make each light flash 1 second apart. What deadtime are you using?
A
RetroZero
Post by RetroZero »
Yeah, that's what I got. Good to see another 12v start up in progress. 👍
I didn't touch deadtime. Left it as I found it. Don't have values with me, but I think it was 26...
LRBen
Post by LRBen »
arber333 wrote: Thu Jul 16, 2020 7:27 pm Hm... that would be consistent... you are using incandesent bulbs. I used LEDs so i guess filament doesnt cool down very fast. Maybe you could command it 0.3Hz slip? That should make each light flash 1 second apart. What deadtime are you using?
A
Using 0 deadtime. Tried it again at 0.3Hz slip. Now they all flash at the same time in one second intervals.
RetroZero wrote: Thu Jul 16, 2020 7:35 pm Yeah, that's what I got. Good to see another 12v start up in progress. 👍
You may want to use Deadtime 160 to start with. Remember Damiens gen3 destruction story?
It is just empty space between pulses. If it is too wide it doesnt hurt. If it is too short on other hand...
A
LRBen
Post by LRBen »
I thought the dead time was only needed on the Gen 3 inverter?
RetroZero
Post by RetroZero »
Yeah, I remember those 2 videos like it was yesterday. From what I understand, gen 2 only switches one side, but I'll give it a go when I can get back to my project...off to a wedding for the weekend 😠. I want spinning MG1!
LRBen wrote: Thu Jul 16, 2020 7:39 pm I thought the dead time was only needed on the Gen 3 inverter?
Ah... i am not sure really. Maybe not. But what does it hurt to try?
Hm... on the other hand i remember gen2 has all low transistors switched on and all high transistors off when at standstill? Then your current would really flow directly through the delta connection. Maybe what you need is a Y connection. Then connect all bulbs like that...
But that would mean any 2 bulbs would be on at a time...
Better try with a simple ACIM motor...
LRBen
Post by LRBen »
I'll hook up an ACIM over the weekend. Seems like progress anyway.
arber333 wrote: Thu Jul 16, 2020 7:38 pm You may want to use Deadtime 160 to start with. Remember Damiens gen3 destruction story?
No we are on a gen2 here. The lower channels remain unused, the power stage creates its own deadtime. Leave it at 0 or it will distort your waveform.
