Arduino IDE board target / getting started?
mdrobnak
Post by mdrobnak »
So I'm trying to load up the CHAdeMO controller, and realize that with the amount of libraries called, some of them are hardware specific.
I just looked at the schematic and found the Atmega processor, so I'm testing with Arduino Uno Wifi. The problem is that I'm running into some weirdness with respect to where the files live and such.
I've tried various things and gotten various issues, the main one I keep getting is CAN_FRAME has not been declared, OR, that it can't find src/globals.h or src/chademo.h
This is on Windows.
Any ideas? Yes, I know that was a bit vague, and I'm sorry for that.
-Matt
Isaac96
Re: Arduino IDE board target / getting started?
Post by Isaac96 »
The src/globals.h error is because the directory structure changed when the code went on Github.
Edit the first few lines of the .ino file:
#include "src/globals.h"
#include "src/chademo.h"
needs to become
#include "globals.h"
#include "chademo.h"
Also you need to add the other libraries declared in the .ino file:
#include <mcp_can.h> // libraries folder
#include <INA226.h> // libraries folder
#include <EEPROMAnything.h> // libraries folder
#include <FrequencyTimer2.h> // libraries folder
FrequencyTimer2 and INA226 can be found in the library manager of the Arduino IDE.
Others are available on GitHub:
https://github.com/collin80/mcp_can
https://github.com/collin80/EEPROMAnything
No guarantee that those are the right libraries; you might need to find and install the right ones.
-Isaac
mdrobnak
Post by mdrobnak »
Tried that.
chademo.cpp:7:26: error: 'Print' does not name a type; did you mean 'int'?
template<class T> inline Print &operator <<(Print &obj, T arg) { obj.print(arg); return obj; } //Sets up serial streaming Serial<<someshit;
int
chademo.cpp:11:1: error: 'CHADEMO' does not name a type
CHADEMO::CHADEMO()
chademo.cpp:30:6: error: 'CHADEMO' has not been declared
void CHADEMO::setDelayedState(int newstate, uint16_t delayTime)
chademo.cpp:30:45: error: 'uint16_t' has not been declared
sketch\chademo.cpp: In function 'void setDelayedState(int, int)':
chademo.cpp:32:2: error: 'chademoState' was not declared in this scope
chademoState = LIMBO;
chademo.cpp:32:17: error: 'LIMBO' was not declared in this scope
chademo.cpp:33:2: error: 'stateHolder' was not declared in this scope
stateHolder = (CHADEMOSTATE)newstate;
chademo.cpp:33:17: error: 'CHADEMOSTATE' was not declared in this scope
chademo.cpp:34:2: error: 'stateMilli' was not declared in this scope
stateMilli = millis();
sketch\chademo.cpp:34:2: note: suggested alternative: 'static'
static
chademo.cpp:34:15: error: 'millis' was not declared in this scope
chademo.cpp:35:2: error: 'stateDelay' was not declared in this scope
stateDelay = delayTime;
sketch\chademo.cpp: At global scope:
chademo.cpp:38:1: error: 'CHADEMOSTATE' does not name a type
CHADEMOSTATE CHADEMO::getState()
chademo.cpp:43:6: error: 'CHADEMO' has not been declared
void CHADEMO::setTargetAmperage(uint8_t t_amp)
chademo.cpp:43:33: error: variable or field 'setTargetAmperage' declared void
chademo.cpp:43:33: error: 'uint8_t' was not declared in this scope
chademo.cpp:48:6: error: 'CHADEMO' has not been declared
void CHADEMO::setTargetVoltage(uint16_t t_volt)
chademo.cpp:48:32: error: variable or field 'setTargetVoltage' declared void
chademo.cpp:48:32: error: 'uint16_t' was not declared in this scope
sketch\chademo.cpp:48:32: note: suggested alternative: 'char16_t'
char16_t
chademo.cpp:53:6: error: 'CHADEMO' has not been declared
void CHADEMO::setChargingFault()
sketch\chademo.cpp: In function 'void setChargingFault()':
chademo.cpp:55:2: error: 'carStatus' was not declared in this scope
carStatus.chargingFault = 1;
chademo.cpp:58:6: error: 'CHADEMO' has not been declared
void CHADEMO::setBattOverTemp()
sketch\chademo.cpp: In function 'void setBattOverTemp()':
chademo.cpp:60:2: error: 'carStatus' was not declared in this scope
carStatus.battOverTemp = 1;
chademo.cpp:64:6: error: 'CHADEMO' has not been declared
void CHADEMO::loop()
sketch\chademo.cpp: In function 'void loop()':
chademo.cpp:66:9: error: 'byte' does not name a type
static byte frameRotate;
chademo.cpp:67:19: error: 'IN1' was not declared in this scope
if (!digitalRead(IN1)) //IN1 goes low if we have been plugged into the chademo port
chademo.cpp:67:7: error: 'digitalRead' was not declared in this scope
chademo.cpp:69:7: error: 'insertionTime' was not declared in this scope
if (insertionTime == 0)
chademo.cpp:73:26: error: 'OUT0' was not declared in this scope
digitalWrite(OUT0, LOW);
chademo.cpp:73:32: error: 'LOW' was not declared in this scope
chademo.cpp:73:13: error: 'digitalWrite' was not declared in this scope
chademo.cpp:74:26: error: 'OUT1' was not declared in this scope
digitalWrite(OUT1, LOW);
chademo.cpp:76:20: error: 'millis' was not declared in this scope
insertionTime = millis();
chademo.cpp:78:12: error: 'millis' was not declared in this scope
else if (millis() > (uint32_t)(insertionTime + 500))
chademo.cpp:78:24: error: 'uint32_t' was not declared in this scope
sketch\chademo.cpp:78:24: note: suggested alternative: 'char32_t'
char32_t
chademo.cpp:80:8: error: 'bChademoMode' was not declared in this scope
if (bChademoMode == 0)
chademo.cpp:83:9: error: 'chademoState' was not declared in this scope
if (chademoState == STOPPED && !bStartedCharge) {
chademo.cpp:83:25: error: 'STOPPED' was not declared in this scope
chademo.cpp:83:37: error: 'bStartedCharge' was not declared in this scope
chademo.cpp:84:21: error: 'STARTUP' was not declared in this scope
chademoState = STARTUP;
chademo.cpp:85:6: error: 'Serial' was not declared in this scope
Serial.println(F("Starting Chademo process."));
chademo.cpp:85:21: error: 'F' was not declared in this scope
chademo.cpp:86:6: error: 'carStatus' was not declared in this scope
carStatus.battOverTemp = 0;
chademo.cpp:96:6: error: 'bChademo10Protocol' was not declared in this scope
bChademo10Protocol = 0;
chademo.cpp:103:3: error: 'insertionTime' was not declared in this scope
insertionTime = 0;
chademo.cpp:104:7: error: 'bChademoMode' was not declared in this scope
if (bChademoMode == 1)
chademo.cpp:106:4: error: 'Serial' was not declared in this scope
Serial.println(F("Stopping chademo process."));
chademo.cpp:106:19: error: 'F' was not declared in this scope
chademo.cpp:108:4: error: 'bStartedCharge' was not declared in this scope
bStartedCharge = 0;
chademo.cpp:109:4: error: 'chademoState' was not declared in this scope
chademoState = STOPPED;
chademo.cpp:109:19: error: 'STOPPED' was not declared in this scope
chademo.cpp:114:17: error: 'OUT0' was not declared in this scope
chademo.cpp:114:23: error: 'LOW' was not declared in this scope
chademo.cpp:114:4: error: 'digitalWrite' was not declared in this scope
chademo.cpp:115:17: error: 'OUT1' was not declared in this scope
chademo.cpp:116:8: error: 'settings' was not declared in this scope
if (settings.debuggingLevel > 0)
chademo.cpp:124:6: error: 'bChademoMode' was not declared in this scope
if (bChademoMode)
chademo.cpp:127:8: error: 'bDoMismatchChecks' was not declared in this scope
if (!bDoMismatchChecks && chademoState == RUNNING)
chademo.cpp:127:29: error: 'chademoState' was not declared in this scope
chademo.cpp:127:45: error: 'RUNNING' was not declared in this scope
chademo.cpp:129:9: error: 'CurrentMillis' was not declared in this scope
if ((CurrentMillis - mismatchStart) >= mismatchDelay) bDoMismatchChecks = 1;
In file included from C:\Users\mdrobnak\Documents\Arduino\JLD505_TM2019\JLD505_TM2019.ino:9:0:
chademo.h:95:22: error: 'CAN_FRAME' has not been declared
void handleCANFrame(CAN_FRAME &frame);
JLD505_TM2019:894:12: error: variable or field 'SCOTT' declared void
void SCOTT(CAN_FRAME frame)
JLD505_TM2019:894:12: error: 'CAN_FRAME' was not declared in this scope
chademo.cpp:129:25: error: 'mismatchStart' was not declared in this scope
C:\Users\mdrobnak\Documents\Arduino\JLD505_TM2019\JLD505_TM2019.ino:894:12: note: suggested alternative: 'CAN_FAIL'
CAN_FAIL
chademo.cpp:129:43: error: 'mismatchDelay' was not declared in this scope
C:\Users\mdrobnak\Documents\Arduino\JLD505_TM2019\JLD505_TM2019.ino: In function 'void setup()':
JLD505_TM2019:174:3: error: 'CAN' was not declared in this scope
CAN.begin(CAN_500KBPS);
C:\Users\mdrobnak\Documents\Arduino\JLD505_TM2019\JLD505_TM2019.ino:174:3: note: suggested alternative: 'NAN'
NAN
C:\Users\mdrobnak\Documents\Arduino\JLD505_TM2019\JLD505_TM2019.ino: In function 'void loop()':
JLD505_TM2019:231:2: error: 'CAN_FRAME' was not declared in this scope
CAN_FRAME inFrame;
chademo.cpp:132:7: error: 'chademoState' was not declared in this scope
if (chademoState == LIMBO && (CurrentMillis - stateMilli) >= stateDelay)
C:\Users\mdrobnak\Documents\Arduino\JLD505_TM2019\JLD505_TM2019.ino:231:2: note: suggested alternative: 'CAN_FAIL'
CAN_FRAME inFrame;
CAN_FAIL
chademo.cpp:132:23: error: 'LIMBO' was not declared in this scope
chademo.cpp:132:33: error: 'CurrentMillis' was not declared in this scope
JLD505_TM2019:321:20: error: 'CAN' was not declared in this scope
if (Flag_Recv || (CAN.checkReceive() == CAN_MSGAVAIL)) {
C:\Users\mdrobnak\Documents\Arduino\JLD505_TM2019\JLD505_TM2019.ino:321:20: note: suggested alternative: 'NAN'
NAN
JLD505_TM2019:323:20: error: 'inFrame' was not declared in this scope
CAN.receiveFrame(inFrame);
chademo.cpp:132:49: error: 'stateMilli' was not declared in this scope
sketch\chademo.cpp:132:49: note: suggested alternative: 'static'
static
chademo.cpp:132:64: error: 'stateDelay' was not declared in this scope
chademo.cpp:134:19: error: 'stateHolder' was not declared in this scope
chademoState = stateHolder;
chademo.cpp:137:7: error: 'bChademoSendRequests' was not declared in this scope
if (bChademoSendRequests && bChademoRequest)
chademo.cpp:137:31: error: 'bChademoRequest' was not declared in this scope
chademo.cpp:140:4: error: 'frameRotate' was not declared in this scope
frameRotate++;
C:\Users\mdrobnak\Documents\Arduino\JLD505_TM2019\JLD505_TM2019.ino: In function 'void wakeUpScott()':
JLD505_TM2019:875:5: error: 'CAN_FRAME' was not declared in this scope
CAN_FRAME outFrame;
chademo.cpp:145:5: error: 'sendCANStatus' was not declared in this scope
sendCANStatus();
C:\Users\mdrobnak\Documents\Arduino\JLD505_TM2019\JLD505_TM2019.ino:875:5: note: suggested alternative: 'CAN_FAIL'
CAN_FRAME outFrame;
CAN_FAIL
JLD505_TM2019:876:5: error: 'outFrame' was not declared in this scope
outFrame.id = 0x382;
chademo.cpp:148:5: error: 'sendCANBattSpecs' was not declared in this scope
sendCANBattSpecs();
JLD505_TM2019:888:20: error: 'CAN' was not declared in this scope
INT8U result = CAN.sendFrame(outFrame);
C:\Users\mdrobnak\Documents\Arduino\JLD505_TM2019\JLD505_TM2019.ino:888:20: note: suggested alternative: 'NAN'
NAN
C:\Users\mdrobnak\Documents\Arduino\JLD505_TM2019\JLD505_TM2019.ino: At global scope:
chademo.cpp:151:5: error: 'sendCANChargingTime' was not declared in this scope
sendCANChargingTime();
CAN_FAIL
chademo.cpp:156:11: error: 'chademoState' was not declared in this scope
switch (chademoState)
chademo.cpp:158:8: error: 'STARTUP' was not declared in this scope
case STARTUP:
chademo.cpp:159:4: error: 'bDoMismatchChecks' was not declared in this scope
bDoMismatchChecks = 0; //reset it for now
chademo.cpp:160:20: error: 'SEND_INITIAL_PARAMS' was not declared in this scope
setDelayedState(SEND_INITIAL_PARAMS, 50);
chademo.cpp:167:4: error: 'bChademoSendRequests' was not declared in this scope
bChademoSendRequests = 1; //causes chademo frames to be sent out every 100ms
chademo.cpp:168:20: error: 'WAIT_FOR_EVSE_PARAMS' was not declared in this scope
setDelayedState(WAIT_FOR_EVSE_PARAMS, 50);
chademo.cpp:169:8: error: 'settings' was not declared in this scope
if (settings.debuggingLevel > 0) Serial.println(F("Sent params to EVSE. Waiting."));
chademo.cpp:169:37: error: 'Serial' was not declared in this scope
chademo.cpp:169:52: error: 'F' was not declared in this scope
chademo.cpp:174:8: error: 'SET_CHARGE_BEGIN' was not declared in this scope
case SET_CHARGE_BEGIN:
chademo.cpp:175:8: error: 'settings' was not declared in this scope
if (settings.debuggingLevel > 0) Serial.println(F("CAR:Charge enable ON"));
chademo.cpp:175:37: error: 'Serial' was not declared in this scope
chademo.cpp:175:52: error: 'F' was not declared in this scope
chademo.cpp:176:17: error: 'OUT1' was not declared in this scope
digitalWrite(OUT1, HIGH); //signal that we're ready to charge
chademo.cpp:176:23: error: 'HIGH' was not declared in this scope
chademo.cpp:176:4: error: 'digitalWrite' was not declared in this scope
chademo.cpp:177:4: error: 'carStatus' was not declared in this scope
carStatus.chargingEnabled = 1; //should this be enabled here???
chademo.cpp:178:20: error: 'WAIT_FOR_BEGIN_CONFIRMATION' was not declared in this scope
setDelayedState(WAIT_FOR_BEGIN_CONFIRMATION, 50);
chademo.cpp:181:20: error: 'IN0' was not declared in this scope
if (digitalRead(IN0)) //inverse logic from how IN1 works. Be careful!
chademo.cpp:181:8: error: 'digitalRead' was not declared in this scope
chademo.cpp:183:21: error: 'CLOSE_CONTACTORS' was not declared in this scope
setDelayedState(CLOSE_CONTACTORS, 100);
chademo.cpp:186:8: error: 'CLOSE_CONTACTORS' was not declared in this scope
case CLOSE_CONTACTORS:
chademo.cpp:187:8: error: 'settings' was not declared in this scope
if (settings.debuggingLevel > 0) Serial.println(F("CAR:Contactor close."));
chademo.cpp:187:37: error: 'Serial' was not declared in this scope
chademo.cpp:187:52: error: 'F' was not declared in this scope
chademo.cpp:188:17: error: 'OUT0' was not declared in this scope
digitalWrite(OUT0, HIGH);
chademo.cpp:189:20: error: 'RUNNING' was not declared in this scope
setDelayedState(RUNNING, 50);
chademo.cpp:192:4: error: 'bStartedCharge' was not declared in this scope
bStartedCharge = 1;
chademo.cpp:193:4: error: 'mismatchStart' was not declared in this scope
mismatchStart = millis();
chademo.cpp:193:20: error: 'millis' was not declared in this scope
chademo.cpp:199:8: error: 'CEASE_CURRENT' was not declared in this scope
case CEASE_CURRENT:
chademo.cpp:200:8: error: 'settings' was not declared in this scope
if (settings.debuggingLevel > 0) Serial.println(F("CAR:Current req to 0"));
chademo.cpp:200:37: error: 'Serial' was not declared in this scope
chademo.cpp:200:52: error: 'F' was not declared in this scope
chademo.cpp:202:19: error: 'WAIT_FOR_ZERO_CURRENT' was not declared in this scope
chademoState = WAIT_FOR_ZERO_CURRENT;
chademo.cpp:205:8: error: 'evse_status' was not declared in this scope
if (evse_status.presentCurrent == 0)
chademo.cpp:207:21: error: 'OPEN_CONTACTOR' was not declared in this scope
setDelayedState(OPEN_CONTACTOR, 150);
chademo.cpp:210:8: error: 'OPEN_CONTACTOR' was not declared in this scope
case OPEN_CONTACTOR:
chademo.cpp:211:8: error: 'settings' was not declared in this scope
if (settings.debuggingLevel > 0) Serial.println(F("CAR:OPEN Contacor"));
chademo.cpp:211:37: error: 'Serial' was not declared in this scope
chademo.cpp:211:52: error: 'F' was not declared in this scope
chademo.cpp:212:23: error: 'LOW' was not declared in this scope
chademo.cpp:215:4: error: 'sendCANStatus' was not declared in this scope
sendCANStatus(); //we probably need to force this right now
chademo.cpp:216:20: error: 'STOPPED' was not declared in this scope
setDelayedState(STOPPED, 100);
chademo.cpp:218:8: error: 'FAULTED' was not declared in this scope
case FAULTED:
chademo.cpp:219:4: error: 'Serial' was not declared in this scope
Serial.println(F("CAR: fault!"));
chademo.cpp:219:19: error: 'F' was not declared in this scope
chademo.cpp:229:8: error: 'settings' was not declared in this scope
chademo.cpp:235:4: error: 'bListenEVSEStatus' was not declared in this scope
bListenEVSEStatus = 0; //don't want to pay attention to EVSE status when we're stopped
chademo.cpp:244:6: error: 'CHADEMO' has not been declared
void CHADEMO::doProcessing()
sketch\chademo.cpp: In function 'void doProcessing()':
chademo.cpp:246:2: error: 'uint8_t' was not declared in this scope
uint8_t tempCurrVal;
chademo.cpp:248:6: error: 'chademoState' was not declared in this scope
if (chademoState == RUNNING && ((CurrentMillis - lastCommTime) >= lastCommTime))
chademo.cpp:248:22: error: 'RUNNING' was not declared in this scope
chademo.cpp:248:35: error: 'CurrentMillis' was not declared in this scope
chademo.cpp:248:51: error: 'lastCommTime' was not declared in this scope
chademo.cpp:251:3: error: 'Serial' was not declared in this scope
Serial.println(F("EVSE comm fault! Commencing emergency shutdown!"));
chademo.cpp:251:18: error: 'F' was not declared in this scope
chademo.cpp:254:18: error: 'OPEN_CONTACTOR' was not declared in this scope
chademoState = OPEN_CONTACTOR;
chademo.cpp:257:6: error: 'chademoState' was not declared in this scope
if (chademoState == RUNNING && bDoMismatchChecks)
chademo.cpp:257:22: error: 'RUNNING' was not declared in this scope
chademo.cpp:257:33: error: 'bDoMismatchChecks' was not declared in this scope
chademo.cpp:259:7: error: 'Voltage' was not declared in this scope
if (Voltage > settings.maxChargeVoltage && !carStatus.battOverVolt)
chademo.cpp:259:17: error: 'settings' was not declared in this scope
chademo.cpp:259:47: error: 'carStatus' was not declared in this scope
chademo.cpp:261:4: error: 'vOverFault' was not declared in this scope
vOverFault++;
chademo.cpp:264:5: error: 'Serial' was not declared in this scope
Serial.println(F("Over voltage fault!"));
chademo.cpp:264:20: error: 'F' was not declared in this scope
chademo.cpp:266:20: error: 'CEASE_CURRENT' was not declared in this scope
chademoState = CEASE_CURRENT;
chademo.cpp:269:8: error: 'vOverFault' was not declared in this scope
else vOverFault = 0;
chademo.cpp:274:6: error: 'Count' was not declared in this scope
if(Count==20)
chademo.cpp:276:8: error: 'evse_status' was not declared in this scope
if (evse_status.presentVoltage > settings.targetChargeVoltage-1) //All initializations complete and we're running.We've reached charging target
chademo.cpp:276:37: error: 'settings' was not declared in this scope
chademo.cpp:281:56: error: 'carStatus' was not declared in this scope
if (settings.minChargeAmperage == 0 || carStatus.targetCurrent < settings.minChargeAmperage){
chademo.cpp:286:36: error: 'CEASE_CURRENT' was not declared in this scope
chademoState = CEASE_CURRENT; //Terminate charging
chademo.cpp:292:9: error: 'carStatus' was not declared in this scope
if (carStatus.targetCurrent < settings.maxChargeAmperage) carStatus.targetCurrent++;
chademo.cpp:299:6: error: 'CHADEMO' has not been declared
void CHADEMO::handleCANFrame(CAN_FRAME &frame)
chademo.cpp:299:30: error: variable or field 'handleCANFrame' declared void
chademo.cpp:299:30: error: 'CAN_FRAME' was not declared in this scope
chademo.cpp:299:41: error: 'frame' was not declared in this scope
chademo.cpp:460:6: error: 'CHADEMO' has not been declared
void CHADEMO::sendCANBattSpecs()
sketch\chademo.cpp: In function 'void sendCANBattSpecs()':
chademo.cpp:462:2: error: 'CAN_FRAME' was not declared in this scope
CAN_FRAME outFrame;
chademo.cpp:463:2: error: 'outFrame' was not declared in this scope
outFrame.id = CARSIDE_BATT_ID;
chademo.cpp:463:16: error: 'CARSIDE_BATT_ID' was not declared in this scope
chademo.cpp:470:34: error: 'settings' was not declared in this scope
outFrame.data.byte[4] = lowByte(settings.maxChargeVoltage);
chademo.cpp:470:26: error: 'lowByte' was not declared in this scope
chademo.cpp:471:26: error: 'highByte' was not declared in this scope
outFrame.data.byte[5] = highByte(settings.maxChargeVoltage);
chademo.cpp:472:27: error: 'uint8_t' was not declared in this scope
outFrame.data.byte[6] = (uint8_t)settings.packSizeKWH;
chademo.cpp:475:2: error: 'CAN' was not declared in this scope
chademo.cpp:478:3: error: 'Serial' was not declared in this scope
Serial.print(F("CAR: Absolute MAX Voltage:"));
chademo.cpp:478:16: error: 'F' was not declared in this scope
chademo.cpp:487:6: error: 'CHADEMO' has not been declared
void CHADEMO::sendCANChargingTime()
sketch\chademo.cpp: In function 'void sendCANChargingTime()':
chademo.cpp:489:2: error: 'CAN_FRAME' was not declared in this scope
CAN_FRAME outFrame;
chademo.cpp:490:2: error: 'outFrame' was not declared in this scope
outFrame.id = CARSIDE_CHARGETIME_ID;
chademo.cpp:490:16: error: 'CARSIDE_CHARGETIME_ID' was not declared in this scope
chademo.cpp:502:2: error: 'CAN' was not declared in this scope
chademo.cpp:503:9: error: 'settings' was not declared in this scope
if (settings.debuggingLevel > 1)
chademo.cpp:505:9: error: 'Serial' was not declared in this scope
Serial.print(F("CAR: Charging Time"));
chademo.cpp:505:22: error: 'F' was not declared in this scope
chademo.cpp:511:6: error: 'CHADEMO' has not been declared
void CHADEMO::sendCANStatus()
sketch\chademo.cpp: In function 'void sendCANStatus()':
chademo.cpp:513:2: error: 'uint8_t' was not declared in this scope
uint8_t faults = 0;
chademo.cpp:514:10: error: expected ';' before 'status'
uint8_t status = 0;
chademo.cpp:515:2: error: 'CAN_FRAME' was not declared in this scope
CAN_FRAME outFrame;
chademo.cpp:516:2: error: 'outFrame' was not declared in this scope
outFrame.id = CARSIDE_CONTROL_ID;
chademo.cpp:516:16: error: 'CARSIDE_CONTROL_ID' was not declared in this scope
chademo.cpp:519:6: error: 'carStatus' was not declared in this scope
if (carStatus.battOverTemp) faults |= CARSIDE_FAULT_OVERT;
chademo.cpp:519:30: error: 'faults' was not declared in this scope
sketch\chademo.cpp:519:30: note: suggested alternative: 'auto'
auto
chademo.cpp:519:40: error: 'CARSIDE_FAULT_OVERT' was not declared in this scope
chademo.cpp:520:6: error: 'carStatus' was not declared in this scope
if (carStatus.battOverVolt) faults |= CARSIDE_FAULT_OVERV;
chademo.cpp:520:30: error: 'faults' was not declared in this scope
sketch\chademo.cpp:520:30: note: suggested alternative: 'auto'
auto
chademo.cpp:520:40: error: 'CARSIDE_FAULT_OVERV' was not declared in this scope
chademo.cpp:521:6: error: 'carStatus' was not declared in this scope
if (carStatus.battUnderVolt) faults |= CARSIDE_FAULT_UNDERV;
chademo.cpp:521:31: error: 'faults' was not declared in this scope
sketch\chademo.cpp:521:31: note: suggested alternative: 'auto'
auto
chademo.cpp:521:41: error: 'CARSIDE_FAULT_UNDERV' was not declared in this scope
chademo.cpp:522:6: error: 'carStatus' was not declared in this scope
if (carStatus.currDeviation) faults |= CARSIDE_FAULT_CURR;
chademo.cpp:522:31: error: 'faults' was not declared in this scope
sketch\chademo.cpp:522:31: note: suggested alternative: 'auto'
auto
chademo.cpp:522:41: error: 'CARSIDE_FAULT_CURR' was not declared in this scope
chademo.cpp:523:6: error: 'carStatus' was not declared in this scope
if (carStatus.voltDeviation) faults |= CARSIDE_FAULT_VOLTM;
chademo.cpp:523:31: error: 'faults' was not declared in this scope
sketch\chademo.cpp:523:31: note: suggested alternative: 'auto'
auto
chademo.cpp:523:41: error: 'CARSIDE_FAULT_VOLTM' was not declared in this scope
chademo.cpp:525:6: error: 'carStatus' was not declared in this scope
if (carStatus.chargingEnabled) status |= CARSIDE_STATUS_CHARGE;
chademo.cpp:525:33: error: 'status' was not declared in this scope
sketch\chademo.cpp:525:33: note: suggested alternative: 'static'
static
chademo.cpp:525:43: error: 'CARSIDE_STATUS_CHARGE' was not declared in this scope
chademo.cpp:526:6: error: 'carStatus' was not declared in this scope
if (carStatus.notParked) status |= CARSIDE_STATUS_NOTPARK;
chademo.cpp:526:27: error: 'status' was not declared in this scope
sketch\chademo.cpp:526:27: note: suggested alternative: 'static'
static
chademo.cpp:526:37: error: 'CARSIDE_STATUS_NOTPARK' was not declared in this scope
chademo.cpp:527:6: error: 'carStatus' was not declared in this scope
if (carStatus.chargingFault) status |= CARSIDE_STATUS_MALFUN;
chademo.cpp:527:31: error: 'status' was not declared in this scope
sketch\chademo.cpp:527:31: note: suggested alternative: 'static'
static
chademo.cpp:527:41: error: 'CARSIDE_STATUS_MALFUN' was not declared in this scope
chademo.cpp:528:6: error: 'bChademo10Protocol' was not declared in this scope
if (bChademo10Protocol)
chademo.cpp:530:7: error: 'carStatus' was not declared in this scope
if (carStatus.contactorOpen) status |= CARSIDE_STATUS_CONTOP;
chademo.cpp:530:32: error: 'status' was not declared in this scope
sketch\chademo.cpp:530:32: note: suggested alternative: 'static'
static
chademo.cpp:530:42: error: 'CARSIDE_STATUS_CONTOP' was not declared in this scope
chademo.cpp:531:7: error: 'carStatus' was not declared in this scope
if (carStatus.stopRequest) status |= CARSIDE_STATUS_CHSTOP;
chademo.cpp:531:30: error: 'status' was not declared in this scope
sketch\chademo.cpp:531:30: note: suggested alternative: 'static'
static
chademo.cpp:531:40: error: 'CARSIDE_STATUS_CHSTOP' was not declared in this scope
chademo.cpp:534:6: error: 'bChademo10Protocol' was not declared in this scope
if (bChademo10Protocol) outFrame.data.byte[0] = 2; //tell EVSE we are talking 1.0 protocol
chademo.cpp:536:34: error: 'carStatus' was not declared in this scope
outFrame.data.byte[1] = lowByte(carStatus.targetVoltage);
chademo.cpp:536:26: error: 'lowByte' was not declared in this scope
chademo.cpp:537:26: error: 'highByte' was not declared in this scope
outFrame.data.byte[2] = highByte(carStatus.targetVoltage);
chademo.cpp:538:26: error: 'askingAmps' was not declared in this scope
outFrame.data.byte[3] = askingAmps;
chademo.cpp:539:26: error: 'faults' was not declared in this scope
outFrame.data.byte[4] = faults;
sketch\chademo.cpp:539:26: note: suggested alternative: 'auto'
auto
chademo.cpp:540:26: error: 'status' was not declared in this scope
outFrame.data.byte[5] = status;
sketch\chademo.cpp:540:26: note: suggested alternative: 'static'
static
chademo.cpp:544:2: error: 'CAN' was not declared in this scope
chademo.cpp:546:6: error: 'settings' was not declared in this scope
chademo.cpp:548:3: error: 'Serial' was not declared in this scope
Serial.print(F("CAR: Protocol:"));
chademo.cpp:548:16: error: 'F' was not declared in this scope
chademo.cpp:557:23: error: 'BIN' was not declared in this scope
Serial.print(faults,BIN);
chademo.cpp:565:6: error: 'chademoState' was not declared in this scope
if (chademoState == RUNNING && askingAmps < carStatus.targetCurrent)
chademo.cpp:565:22: error: 'RUNNING' was not declared in this scope
chademo.cpp:568:34: error: 'evse_status' was not declared in this scope
int offsetError = askingAmps - evse_status.presentCurrent;
chademo.cpp:574:6: error: 'chademoState' was not declared in this scope
if (chademoState != RUNNING && askingAmps > 0) askingAmps--;
chademo.cpp:574:22: error: 'RUNNING' was not declared in this scope
chademo.cpp:580:1: error: 'CHADEMO' does not name a type
CHADEMO chademo;
Multiple libraries were found for "Wire.h"
Used: C:\Users\mdrobnak\Downloads\arduino-1.8.10\hardware\arduino\avr\libraries\Wire
Multiple libraries were found for "SPI.h"
Used: C:\Users\mdrobnak\Downloads\arduino-1.8.10\hardware\arduino\avr\libraries\SPI
Multiple libraries were found for "EEPROM.h"
Used: C:\Users\mdrobnak\Downloads\arduino-1.8.10\hardware\arduino\avr\libraries\EEPROM
Multiple libraries were found for "mcp_can.h"
Used: C:\Users\mdrobnak\Documents\Arduino\libraries\MCP_CAN_lib
Multiple libraries were found for "INA226.h"
Used: C:\Users\mdrobnak\Documents\Arduino\libraries\Arduino-INA226
Multiple libraries were found for "EEPROMAnything.h"
Used: C:\Users\mdrobnak\Documents\Arduino\libraries\EEPROMAnything
Multiple libraries were found for "SoftwareSerial.h"
Used: C:\Users\mdrobnak\Downloads\arduino-1.8.10\hardware\arduino\avr\libraries\SoftwareSerial
Not used: C:\Users\mdrobnak\Documents\Arduino\libraries\EspSoftwareSerial
Multiple libraries were found for "FrequencyTimer2.h"
Used: C:\Users\mdrobnak\Documents\Arduino\libraries\FrequencyTimer2
exit status 1
mdrobnak
Post by mdrobnak »
And if I put #include "chademo.h" back in the cpp file too:
In file included from sketch\chademo.cpp:5:0:
I...am not a fan of this half-abstraction weirdness that is Arduino.
Been thanked: 1139 times
Arduino has become quite a nightmare for me of late. It's usually down to someone writing code based on a particular library that then gets updated so when someone comes along later, grabs what they think is the right library and tries to compile, it sits there looking at you. Most recent example is Tom's bmwphev bms code. If I update the libraries, it compiles but then breaks the volt and i3 bms compilation...
Anyway, the chademo code was originally written in 2015 when I worked with evtv to get the E39 charging. Problem is, since then it was never really finished, got a few tweaks here and there by various parties along the way, some released, some not and is just a total mess job right now. I do have it working in the E31 but really what it needs is a rewrite. Johannes did a version for the stm32 for his project to the ebst of my knowledge :
https://github.com/jsphuebner/stm32-car
Isaac96
Post by Isaac96 »
Yeah Arduino really needs some way to make virtual environments with specific libraries. Like venv for Python. I've had to modify libraries for my own use (because I don't know how to make a library use defaults when passing some arguments) and so my code is always a little off.
Matt, what does your directory structure look like? Seems like the compiler is getting confused by different layers of folders. My original advice came from looking at Damien's github and its structure. Generally you want the .cpp and .h files in the same folder as the .ino, then they open along with the sketch and you can edit all at once without causing other problems.
-Isaac
mdrobnak
Post by mdrobnak »
Ok, so I stepped back..and downloaded the mcp_can from collin80's repo.
I set the board to an Arduino nano.
Now I'm going to move that all out of the way, and re-extract from Damien's repo, and note what needed to be changed...
* Download zip of Chademo-Fast-Charge-Controller.
* Extract Software folder into your Arduino sketches directory. Rename from Software to JLD505_TM2019
* Download mcp_can from collin80, extract into the libraries folder.
* Download https://github.com/collin80/EEPROMAnything .. same deal
* Download https://github.com/jarzebski/Arduino-INA226
* Download https://www.arduinolibraries.info/libra ... ncy-timer2
* Load project in Arduino
* Fix the two lines:
Remove "src/"
And...that should produce a sketch that compiles.
Now to poke and prod.
-Matt
EDIT: Re-reading Isaac's original post - I missed that I didn't download the mcp_can from the right repo, so he was right from the get-go.
This is the equivalent of DLL hell. :) The issue is that there really are no docs with these 'libraries' as I am going to guess that a bunch of the people working on them are not professional software developers. Also documentation is the hardest part. :)
