- 4markowen
- Has thanked: 21 times
indeed, very cool.
You can see how the BMS detaches and attaches. Very modular modules
Didn't take as long to put a basic model together as I thought, added a basic parametric cad in IGS and parasolid
EDIT: Grabcad have removed my cad models at the request of BMW
https://www.mouser.co.uk/ProductDetail/ ... bzVg%3D%3DSciroccoEV wrote: ↑Wed Jun 10, 2020 4:23 pmOn my 330E battery, the screws around the edge were dual 10mm AF with internal Torx too. there was also one row of button head Torx across the middle.celeron55 wrote: ↑Wed Jun 10, 2020 10:05 amAt least in the x5 pack it's a large torx, can't remember what exactly but it was the largest one in my cheap screwdriver bit set.black-cat wrote: ↑Wed Jun 10, 2020 9:47 am Picking up a 530e pack on tuesday. What are the fasteners that hold the lid on? They look like torx but the pics are not quite clear enough. I want to pop the lid and make sure it still has charge (sat for almost a year) before driving 200 miles back home with a 120kg paperweight.
Do we know what the connectors on the BMS are yet? I'm thinking we need some harnesses for combining cell taps on paralleled modules.
Picked up a 530e pack today and it has good cell voltages. The pack is a work of art! Over engineered does not come close to describing it.
- SciroccoEV
- Been thanked: 15 times
Yes, that information had already been provided.
Now try finding a source for the mating connector!
I think the part linked just above is the 32 way cell tap connector anyway - I guess it's more likely people will need the BMS communication plug which is a 12 way. It's not a stocked part either (and I think it's restricted also, custom part) - but is a standard 2.54 pitch, so you could get a standard header on it, or replace the board connector with a more standard part. Another route would be to just re-pin the existing housing if it's just about cable lengths...
- mdrobnak
- Been thanked: 5 times
Are these the same as being discussed, or completely different?
https://batteryhookup.com/products/copy ... with-leads
Rated 10 second pulse draw is 5C...if it could do 8 or 10c these would not be bad for my hybrid...(12 modules). How's the pricing ?
-Matt
-Matt
- SciroccoEV
Same packaging and dimensions, but not the same specification. The hybrid modules being discussed are 16 cells of 26Ah in series, whilst the ones you linked are 2 35Ah cells in parallel and 8 cell pairs in series.
These however are the same 16s1p layout - Both are the newer (BMW Gen4?) 35Ah cells
https://batteryhookup.com/products/bmw- ... eq=uniform
I think the 16s is from the 2019+ 3/5/7 hybrids - but I wonder what the 8S2P are from? 8S2P with 12 modules would be a decent 24Kwh pack...
- mdrobnak
I was literally about to post that.cloudy wrote: ↑Thu Jun 18, 2020 7:26 pm These however are the same layout - but the newer (BMW Gen4?) 35Ah cells
I wonder what these are from? The 8S2P with 12 modules if it could use the BMW BMS would be a decent 24Kwh pack...
And, yes, that was my thought. But, decent is the operative word. Not excellent. I have higher current needs than what this can provide for my pure EV. But I thought it might be OK for the GS450h drivetrain.
Granted - but it would certainly get many into usable ranges without having to run 2,3 or more parallel packs, yet still offer the modularity. Hopefully there is some luck getting simpBMS to monitor/balance/re-index the attachable BMS...
- mdrobnak
True. Which brings me back to my other question - given the BMW PHEVs are not as popular here in the US, does the pricing seem decent? 12 modules, with their 15% off, is $2652 before shipping. ($230 for shipping, which seems reasonable from east cost to west coast of USA)
-Matt
These packs in the UK can be had with some negotiation around £100/kwh ($125). These seem to be in the right ballpark. However they don't seem to include the cell monitoring circuit, so you'd need to factor in buying a bunch separately (and it's still not clear if the IDs can be changed when they are mixed up like that) or a separate(complete) BMS. You are also missing interlink connectors/contactors etc that come with stripping your own pack...
- SciroccoEV
That's why I was asking about connectors. I'd be looking to parallel the cell taps between modules and use one BMS slave.cloudy wrote: ↑Thu Jun 18, 2020 8:04 pm These packs in the UK can be had with some negotiation around £100/kwh ($125). These seem to be in the right ballpark. However they don't seem to include the cell monitoring circuit, so you'd need to factor in buying a bunch separately (and it's still not clear if the IDs can be changed when they are mixed up like that) or a separate(complete) BMS. You are also missing interlink connectors/contactors etc that come with stripping your own pack...
With the intention of remaking the bus bars on the 16s? and running a single BMS over two modules? Or linking two modules via the taps somehow? Surely there would be current flow over the tap wires as the paralleled cell voltages vary under load?
- clanger9
Anyone know of a UK source for those 8s2p BMW packs? The price from batteryhookup with 15% off is very tempting, but I'd like to avoid shipping from the US if possible.
4 modules in 36s / 5c / 8kWh configuration would be ideal for my bike conversion project...
I've captured some CANbus from the 330e 5 module pack, both internal BMS can, and external connector CAN.
@tom91 - hopefully this helps with your efforts on adding simpbms support...
Overall setup:
5 modules - 4 of which are at 3.87v/cell - one module which is less - 3.68v/cell. Hoping this would kick in any balancing, but unsure if it does this when not charging.
bmw-330e-5modules-external-on-off.csv
The external CANbus with all 5 CSC modules connected
Full power cycle, on and off
bmw-330e-5modules-5csc-attached-internalcan-on-off.csv
Internal BMS canbus - all 5 BMS modules attached
Master is connected and powered
bmw-330e-5modules-4csc-attached-internalcan-on-off.csv
Internal BMS canbus - 4 BMS modules attached - 1 unplugged
Overall setup:
- bmw-330e-5modules-external-on-off.csv
- (73.29 KiB) Downloaded 128 times
- bmw-330e-5modules-5csc-attached-internalcan-on-off.csv
- (409.52 KiB) Downloaded 108 times
- bmw-330e-5modules-4csc-attached-internalcan-on-off.csv
- (127.47 KiB) Downloaded 102 times
Hi,cloudy wrote: ↑Sat Jun 20, 2020 10:25 pm I've captured some CANbus from the 330e 5 module pack, both internal BMS can, and external connector CAN.
Overall setup:
I think I may have something?
Try sending a changing signal to ID 112
Then tell me how to do it if it works?
39:56.2 Get data from ID: 112 EC 1F 42 B 38 71 C5 48 48 11101100 11111 1000010 1011 111000 1110001 11000101 1001000
39:56.4 Get data from ID: 112 EC 1F 42 B 38 71 C5 48 48 11101100 11111 1000010 1011 111000 1110001 11000101 1001000
39:56.5 Get data from ID: 112 EC 1F 42 B 38 71 C5 48 48 11101100 11111 1000010 1011 111000 1110001 11000101 1001000
39:56.6 Get data from ID: 112 EC 1F 42 B 38 71 C5 48 48 11101100 11111 1000010 1011 111000 1110001 11000101 1001000
39:56.7 Get data from ID: 112 ED 1F 42 B 38 71 C5 48 48 11101101 11111 1000010 1011 111000 1110001 11000101 1001000
39:56.8 Get data from ID: 112 ED 1F 42 B 38 71 C5 48 48 11101101 11111 1000010 1011 111000 1110001 11000101 1001000
39:56.9 Get data from ID: 112 ED 1F 42 B 38 71 C5 48 48 11101101 11111 1000010 1011 111000 1110001 11000101 1001000
39:57.0 Get data from ID: 112 ED 1F 42 B 38 71 C5 48 48 11101101 11111 1000010 1011 111000 1110001 11000101 1001000
39:57.1 Get data from ID: 112 ED 1F 42 B 38 71 C5 48 48 11101101 11111 1000010 1011 111000 1110001 11000101 1001000
39:57.3 Get data from ID: 112 EC 1F 42 B 38 71 C5 48 48 11101100 11111 1000010 1011 111000 1110001 11000101 1001000
39:57.4 Get data from ID: 112 EC 1F 42 B 38 71 C5 48 48 11101100 11111 1000010 1011 111000 1110001 11000101 1001000
39:57.5 Get data from ID: 112 EC 1F 42 B 38 71 C5 48 48 11101100 11111 1000010 1011 111000 1110001 11000101 1001000
39:57.7 Get data from ID: 112 E8 1F 41 B 38 71 C5 48 48 11101000 11111 1000001 1011 111000 1110001 11000101 1001000
39:57.7 Get data from ID: 112 E6 1F 41 B 38 71 C5 48 48 11100110 11111 1000001 1011 111000 1110001 11000101 1001000
39:57.7 Get data from ID: 112 E5 1F 40 B 38 71 C5 48 48 11100101 11111 1000000 1011 111000 1110001 11000101 1001000
39:57.9 Get data from ID: 112 CC 1F 3C B 38 71 C5 48 48 11001100 11111 111100 1011 111000 1110001 11000101 1001000
39:57.9 Get data from ID: 112 C3 1F 39 B 38 71 C5 48 48 11000011 11111 111001 1011 111000 1110001 11000101 1001000
39:57.9 Get data from ID: 112 C0 1F 38 B 38 71 C5 48 48 11000000 11111 111000 1011 111000 1110001 11000101 1001000
39:58.1 Get data from ID: 112 A0 1F 31 B 38 71 B5 48 48 10100000 11111 110001 1011 111000 1110001 10110101 1001000
39:58.1 Get data from ID: 112 9F 1F 31 B 38 71 B5 48 48 10011111 11111 110001 1011 111000 1110001 10110101 1001000
39:58.2 Get data from ID: 112 AC 1F 31 B 38 71 B5 48 48 10101100 11111 110001 1011 111000 1110001 10110101 1001000
39:58.2 Get data from ID: 112 B2 1F 34 B 38 71 B5 48 48 10110010 11111 110100 1011 111000 1110001 10110101 1001000
39:58.3 Get data from ID: 112 B8 1F 35 B 38 71 B5 48 48 10111000 11111 110101 1011 111000 1110001 10110101 1001000
39:58.3 Get data from ID: 112 BA 1F 36 B 38 71 B5 48 48 10111010 11111 110110 1011 111000 1110001 10110101 1001000
39:58.4 Get data from ID: 112 B8 1F 37 B 38 71 B5 48 48 10111000 11111 110111 1011 111000 1110001 10110101 1001000
39:58.5 Get data from ID: 112 BA 1F 36 B 38 71 B5 48 48 10111010 11111 110110 1011 111000 1110001 10110101 1001000
39:58.5 Get data from ID: 112 B2 1F 36 B 38 71 B5 48 48 10110010 11111 110110 1011 111000 1110001 10110101 1001000
39:58.5 Get data from ID: 112 AA 1F 34 B 38 71 B5 48 48 10101010 11111 110100 1011 111000 1110001 10110101 1001000
39:58.6 Get data from ID: 112 A5 1F 32 B 38 71 B5 48 48 10100101 11111 110010 1011 111000 1110001 10110101 1001000
39:58.6 Get data from ID: 112 A4 1F 32 B 38 71 B5 48 48 10100100 11111 110010 1011 111000 1110001 10110101 1001000
39:58.7 Get data from ID: 112 9B 1F 2F B 38 71 B5 48 48 10011011 11111 101111 1011 111000 1110001 10110101 1001000
39:58.8 Get data from ID: 112 9C 1F 2F B 38 71 B5 48 48 10011100 11111 101111 1011 111000 1110001 10110101 1001000
39:58.8 Get data from ID: 112 9A 1F 2F B 38 71 B5 48 48 10011010 11111 101111 1011 111000 1110001 10110101 1001000
39:58.8 Get data from ID: 112 A3 1F 30 B 38 71 B5 48 48 10100011 11111 110000 1011 111000 1110001 10110101 1001000
39:58.9 Get data from ID: 112 BA 1F 35 B 38 71 B5 48 48 10111010 11111 110101 1011 111000 1110001 10110101 1001000
39:58.9 Get data from ID: 112 B5 1F 35 B 38 71 B5 48 48 10110101 11111 110101 1011 111000 1110001 10110101 1001000
39:59.0 Get data from ID: 112 B1 1F 34 B 38 71 A5 48 48 10110001 11111 110100 1011 111000 1110001 10100101 1001000
39:59.1 Get data from ID: 112 B2 1F 34 B 38 71 A5 48 48 10110010 11111 110100 1011 111000 1110001 10100101 1001000
39:59.1 Get data from ID: 112 B4 1F 34 B 38 71 A5 48 48 10110100 11111 110100 1011 111000 1110001 10100101 1001000
39:59.2 Get data from ID: 112 B7 1F 35 B 38 71 A5 48 48 10110111 11111 110101 1011 111000 1110001 10100101 1001000
39:59.2 Get data from ID: 112 B8 1F 35 B 38 71 A5 48 48 10111000 11111 110101 1011 111000 1110001 10100101 1001000
39:59.2 Get data from ID: 112 B6 1F 35 B 38 71 A5 48 48 10110110 11111 110101 1011 111000 1110001 10100101 1001000
39:59.3 Get data from ID: 112 B7 1F 35 B 38 71 A5 48 48 10110111 11111 110101 1011 111000 1110001 10100101 1001000
39:59.4 Get data from ID: 112 B8 1F 35 B 38 71 A5 48 48 10111000 11111 110101 1011 111000 1110001 10100101 1001000
39:59.4 Get data from ID: 112 B9 1F 35 B 38 71 A5 48 48 10111001 11111 110101 1011 111000 1110001 10100101 1001000
39:59.5 Get data from ID: 112 B9 1F 35 B 38 71 A5 48 48 10111001 11111 110101 1011 111000 1110001 10100101 1001000
39:59.5 Get data from ID: 112 BA 1F 35 B 38 71 A5 48 48 10111010 11111 110101 1011 111000 1110001 10100101 1001000
39:59.6 Get data from ID: 112 BA 1F 35 B 38 71 A5 48 48 10111010 11111 110101 1011 111000 1110001 10100101 1001000
39:59.6 Get data from ID: 112 C4 1F 37 B 38 71 A5 48 48 11000100 11111 110111 1011 111000 1110001 10100101 1001000
39:59.6 Get data from ID: 112 C2 1F 37 B 38 71 A5 48 48 11000010 11111 110111 1011 111000 1110001 10100101 1001000
39:59.7 Get data from ID: 112 CF 1F 39 B 38 71 A5 48 48 11001111 11111 111001 1011 111000 1110001 10100101 1001000
39:59.8 Get data from ID: 112 D4 1F 3B B 38 71 A5 48 48 11010100 11111 111011 1011 111000 1110001 10100101 1001000
39:59.8 Get data from ID: 112 D5 1F 3B B 38 71 A5 48 48 11010101 11111 111011 1011 111000 1110001 10100101 1001000
39:59.8 Get data from ID: 112 E0 1F 3D B 38 71 A5 48 48 11100000 11111 111101 1011 111000 1110001 10100101 1001000
40:00.0 Get data from ID: 112 E8 1F 40 B 38 71 A5 48 48 11101000 11111 1000000 1011 111000 1110001 10100101 1001000
40:00.0 Get data from ID: 112 EB 1F 40 B 38 71 A5 48 48 11101011 11111 1000000 1011 111000 1110001 10100101 1001000
40:00.0 Get data from ID: 112 EC 1F 40 B 38 71 A5 48 48 11101100 11111 1000000 1011 111000 1110001 10100101 1001000
40:00.1 Get data from ID: 112 ED 1F 41 B 38 71 A5 48 48 11101101 11111 1000001 1011 111000 1110001 10100101 1001000
40:00.1 Get data from ID: 112 F0 1F 41 B 38 71 A5 48 48 11110000 11111 1000001 1011 111000 1110001 10100101 1001000
40:00.2 Get data from ID: 112 F3 1F 42 B 38 71 A5 48 48 11110011 11111 1000010 1011 111000 1110001 10100101 1001000
40:00.2 Get data from ID: 112 F1 1F 42 B 38 71 A5 48 48 11110001 11111 1000010 1011 111000 1110001 10100101 1001000
40:00.2 Get data from ID: 112 EF 1F 41 B 38 71 A5 48 48 11101111 11111 1000001 1011 111000 1110001 10100101 1001000
40:00.3 Get data from ID: 112 F0 1F 41 B 38 71 A5 48 48 11110000 11111 1000001 1011 111000 1110001 10100101 1001000
40:00.4 Get data from ID: 112 EC 1F 41 B 38 71 A5 48 48 11101100 11111 1000001 1011 111000 1110001 10100101 1001000
40:00.5 Get data from ID: 112 ED 1F 41 B 38 71 A5 48 48 11101101 11111 1000001 1011 111000 1110001 10100101 1001000
40:00.6 Get data from ID: 112 EC 1F 41 B 38 71 A5 48 48 11101100 11111 1000001 1011 111000 1110001 10100101 1001000
40:00.6 Get data from ID: 112 ED 1F 41 B 38 71 A5 48 48 11101101 11111 1000001 1011 111000 1110001 10100101 1001000
40:00.7 Get data from ID: 112 ED 1F 41 B 38 71 A5 48 48 11101101 11111 1000001 1011 111000 1110001 10100101 1001000
40:00.7 Get data from ID: 112 EC 1F 41 B 38 71 A5 48 48 11101100 11111 1000001 1011 111000 1110001 10100101 1001000
40:00.8 Get data from ID: 112 ED 1F 41 B 38 71 A5 48 48 11101101 11111 1000001 1011 111000 1110001 10100101 1001000
40:00.9 Get data from ID: 112 ED 1F 41 B 38 71 A5 48 48 11101101 11111 1000001 1011 111000 1110001 10100101 1001000
40:00.9 Get data from ID: 112 EC 1F 41 B 38 71 A5 48 48 11101100 11111 1000001 1011 111000 1110001 10100101 1001000
40:01.0 Get data from ID: 112 EC 1F 41 B 38 71 A5 48 48 11101100 11111 1000001 1011 111000 1110001 10100101 1001000
40:01.0 Get data from ID: 112 EB 1F 41 B 38 71 A5 48 48 11101011 11111 1000001 1011 111000 1110001 10100101 1001000
40:01.1 Get data from ID: 112 EB 1F 41 B 38 71 A5 48 48 11101011 11111 1000001 1011 111000 1110001 10100101 1001000
40:01.2 Get data from ID: 112 EB 1F 41 B 38 71 A5 48 48 11101011 11111 1000001 1011 111000 1110001 10100101 1001000
40:01.2 Get data from ID: 112 EB 1F 41 B 38 71 95 48 48 11101011 11111 1000001 1011 111000 1110001 10010101 1001000
40:01.3 Get data from ID: 112 EB 1F 41 B 38 71 95 48 48 11101011 11111 1000001 1011 111000 1110001 10010101 1001000
40:01.4 Get data from ID: 112 EB 1F 41 B 38 71 95 48 48 11101011 11111 1000001 1011 111000 1110001 10010101 1001000
40:01.4 Get data from ID: 112 ED 1F 41 B 38 71 95 48 48 11101101 11111 1000001 1011 111000 1110001 10010101 1001000
40:01.5 Get data from ID: 112 ED 1F 41 B 38 71 95 48 48 11101101 11111 1000001 1011 111000 1110001 10010101 1001000
40:01.6 Get data from ID: 112 ED 1F 41 B 38 71 95 48 48 11101101 11111 1000001 1011 111000 1110001 10010101 1001000
40:01.6 Get data from ID: 112 EE 1F 41 B 38 71 95 48 48 11101110 11111 1000001 1011 111000 1110001 10010101 1001000
40:01.7 Get data from ID: 112 EE 1F 41 B 38 71 95 48 48 11101110 11111 1000001 1011 111000 1110001 10010101 1001000
40:01.8 Get data from ID: 112 EE 1F 41 B 38 71 95 48 48 11101110 11111 1000001 1011 111000 1110001 10010101 1001000
40:01.8 Get data from ID: 112 EF 1F 41 B 38 71 95 48 48 11101111 11111 1000001 1011 111000 1110001 10010101 1001000
40:01.9 Get data from ID: 112 EF 1F 41 B 38 71 95 48 48 11101111 11111 1000001 1011 111000 1110001 10010101 1001000
40:01.9 Get data from ID: 112 EF 1F 42 B 38 71 95 48 48 11101111 11111 1000010 1011 111000 1110001 10010101 1001000
40:02.0 Get data from ID: 112 EF 1F 42 B 38 71 95 48 48 11101111 11111 1000010 1011 111000 1110001 10010101 1001000
40:02.1 Get data from ID: 112 EF 1F 42 B 38 71 95 48 48 11101111 11111 1000010 1011 111000 1110001 10010101 1001000
40:02.2 Get data from ID: 112 EE 1F 41 B 38 71 95 48 48 11101110 11111 1000001 1011 111000 1110001 10010101 1001000
40:02.3 Get data from ID: 112 EE 1F 41 B 38 71 95 48 48 11101110 11111 1000001 1011 111000 1110001 10010101 1001000
40:02.4 Get data from ID: 112 EE 1F 41 B 38 71 95 48 48 11101110 11111 1000001 1011 111000 1110001 10010101 1001000
40:02.4 Get data from ID: 112 ED 1F 41 B 38 71 95 48 48 11101101 11111 1000001 1011 111000 1110001 10010101 1001000
40:02.5 Get data from ID: 112 ED 1F 41 B 38 71 95 48 48 11101101 11111 1000001 1011 111000 1110001 10010101 1001000
40:02.6 Get data from ID: 112 ED 1F 41 B 38 71 95 48 48 11101101 11111 1000001 1011 111000 1110001 10010101 1001000
40:02.6 Get data from ID: 112 EE 1F 41 B 38 71 95 48 48 11101110 11111 1000001 1011 111000 1110001 10010101 1001000
40:02.7 Get data from ID: 112 EE 1F 41 B 38 71 95 48 48 11101110 11111 1000001 1011 111000 1110001 10010101 1001000
40:02.8 Get data from ID: 112 EF 1F 41 B 38 71 95 48 48 11101111 11111 1000001 1011 111000 1110001 10010101 1001000
40:02.8 Get data from ID: 112 EF 1F 42 B 38 71 95 48 48 11101111 11111 1000010 1011 111000 1110001 10010101 1001000
40:02.9 Get data from ID: 112 EF 1F 42 B 38 71 95 48 48 11101111 11111 1000010 1011 111000 1110001 10010101 1001000
40:03.0 Get data from ID: 112 EF 1F 42 B 38 71 95 48 48 11101111 11111 1000010 1011 111000 1110001 10010101 1001000
40:03.1 Get data from ID: 112 EF 1F 42 B 38 71 95 48 48 11101111 11111 1000010 1011 111000 1110001 10010101 1001000
40:03.2 Get data from ID: 112 EE 1F 42 B 38 71 95 48 48 11101110 11111 1000010 1011 111000 1110001 10010101 1001000
40:03.2 Get data from ID: 112 EE 1F 41 B 38 71 95 48 48 11101110 11111 1000001 1011 111000 1110001 10010101 1001000
40:03.3 Get data from ID: 112 EE 1F 41 B 38 71 95 48 48 11101110 11111 1000001 1011 111000 1110001 10010101 1001000
40:03.4 Get data from ID: 112 EE 1F 41 B 38 71 95 48 48 11101110 11111 1000001 1011 111000 1110001 10010101 1001000
40:03.4 Get data from ID: 112 ED 1F 41 B 38 71 95 48 48 11101101 11111 1000001 1011 111000 1110001 10010101 1001000
40:03.5 Get data from ID: 112 ED 1F 41 B 38 71 95 48 48 11101101 11111 1000001 1011 111000 1110001 10010101 1001000
40:03.5 Get data from ID: 112 EE 1F 41 B 38 71 95 48 48 11101110 11111 1000001 1011 111000 1110001 10010101 1001000
40:03.6 Get data from ID: 112 EE 1F 41 B 38 71 95 48 48 11101110 11111 1000001 1011 111000 1110001 10010101 1001000
40:03.6 Get data from ID: 112 ED 1F 41 B 38 71 95 48 48 11101101 11111 1000001 1011 111000 1110001 10010101 1001000
40:03.7 Get data from ID: 112 EE 1F 41 B 38 71 95 48 48 11101110 11111 1000001 1011 111000 1110001 10010101 1001000
40:03.8 Get data from ID: 112 EF 1F 41 B 38 71 95 48 48 11101111 11111 1000001 1011 111000 1110001 10010101 1001000
40:03.8 Get data from ID: 112 EF 1F 42 B 38 71 95 48 48 11101111 11111 1000010 1011 111000 1110001 10010101 1001000
40:03.9 Get data from ID: 112 EF 1F 42 B 38 71 95 48 48 11101111 11111 1000010 1011 111000 1110001 10010101 1001000
40:04.0 Get data from ID: 112 EE 1F 41 B 38 71 95 48 48 11101110 11111 1000001 1011 111000 1110001 10010101 1001000
40:04.0 Get data from ID: 112 ED 1F 41 B 38 71 95 48 48 11101101 11111 1000001 1011 111000 1110001 10010101 1001000
40:04.0 Get data from ID: 112 EC 1F 41 B 38 71 95 48 48 11101100 11111 1000001 1011 111000 1110001 10010101 1001000
40:04.1 Get data from ID: 112 EC 1F 41 B 38 71 95 48 48 11101100 11111 1000001 1011 111000 1110001 10010101 1001000
40:04.2 Get data from ID: 112 EC 1F 41 B 38 71 95 48 48 11101100 11111 1000001 1011 111000 1110001 10010101 1001000
40:04.3 Get data from ID: 112 EB 1F 41 B 38 71 95 48 48 11101011 11111 1000001 1011 111000 1110001 10010101 1001000
40:04.4 Get data from ID: 112 E9 1F 40 B 38 71 95 48 48 11101001 11111 1000000 1011 111000 1110001 10010101 1001000
40:04.4 Get data from ID: 112 E8 1F 40 B 38 71 95 48 48 11101000 11111 1000000 1011 111000 1110001 10010101 1001000
40:04.4 Get data from ID: 112 E5 1F 40 B 38 71 95 48 48 11100101 11111 1000000 1011 111000 1110001 10010101 1001000
40:04.5 Get data from ID: 112 E0 1F 3E B 38 71 95 48 48 11100000 11111 111110 1011 111000 1110001 10010101 1001000
40:04.5 Get data from ID: 112 DC 1F 3E B 38 71 95 48 48 11011100 11111 111110 1011 111000 1110001 10010101 1001000
40:04.6 Get data from ID: 112 D0 1F 3B B 38 71 95 48 48 11010000 11111 111011 1011 111000 1110001 10010101 1001000
40:04.6 Get data from ID: 112 CA 1F 3A B 38 71 95 48 48 11001010 11111 111010 1011 111000 1110001 10010101 1001000
40:04.6 Get data from ID: 112 C4 1F 39 B 38 71 95 48 48 11000100 11111 111001 1011 111000 1110001 10010101 1001000
40:04.6 Get data from ID: 112 BF 1F 38 B 38 71 95 48 48 10111111 11111 111000 1011 111000 1110001 10010101 1001000
40:04.7 Get data from ID: 112 B8 1F 36 B 38 71 95 48 48 10111000 11111 110110 1011 111000 1110001 10010101 1001000
40:04.7 Get data from ID: 112 B1 1F 35 B 38 71 95 48 48 10110001 11111 110101 1011 111000 1110001 10010101 1001000
40:04.7 Get data from ID: 112 AE 1F 34 B 38 71 95 48 48 10101110 11111 110100 1011 111000 1110001 10010101 1001000
40:04.8 Get data from ID: 112 A9 1F 32 B 38 71 95 48 48 10101001 11111 110010 1011 111000 1110001 10010101 1001000
40:04.8 Get data from ID: 112 AA 1F 32 B 38 71 95 48 48 10101010 11111 110010 1011 111000 1110001 10010101 1001000
40:04.9 Get data from ID: 112 B3 1F 33 B 38 71 95 48 48 10110011 11111 110011 1011 111000 1110001 10010101 1001000
40:05.1 Get data from ID: 112 D2 1F 3A B 38 71 85 48 48 11010010 11111 111010 1011 111000 1110001 10000101 1001000
40:05.1 Get data from ID: 112 D5 1F 3B B 38 71 85 48 48 11010101 11111 111011 1011 111000 1110001 10000101 1001000
40:05.2 Get data from ID: 112 D9 1F 3C B 38 71 85 48 48 11011001 11111 111100 1011 111000 1110001 10000101 1001000
40:05.3 Get data from ID: 112 D6 1F 3C B 38 71 85 48 48 11010110 11111 111100 1011 111000 1110001 10000101 1001000
40:05.7 Get data from ID: 112 D6 1F 3C B 38 71 85 48 48 11010110 11111 111100 1011 111000 1110001 10000101 1001000
40:05.8 Get data from ID: 112 D7 1F 3C B 38 71 85 48 48 11010111 11111 111100 1011 111000 1110001 10000101 1001000
40:06.0 Get data from ID: 112 D7 1F 3C B 38 71 85 48 48 11010111 11111 111100 1011 111000 1110001 10000101 1001000
40:06.2 Get data from ID: 112 D6 1F 3B B 38 71 85 48 48 11010110 11111 111011 1011 111000 1110001 10000101 1001000
40:06.3 Get data from ID: 112 D7 1F 3C B 38 71 85 48 48 11010111 11111 111100 1011 111000 1110001 10000101 1001000
40:06.3 Get data from ID: 112 DC 1F 3C B 38 71 85 48 48 11011100 11111 111100 1011 111000 1110001 10000101 1001000
40:07.0 Get data from ID: 112 F5 1F 42 B 38 71 85 48 48 11110101 11111 1000010 1011 111000 1110001 10000101 1001000
40:07.0 Get data from ID: 112 F2 1F 42 B 38 71 85 48 48 11110010 11111 1000010 1011 111000 1110001 10000101 1001000
40:07.1 Get data from ID: 112 EF 1F 41 B 38 71 85 48 48 11101111 11111 1000001 1011 111000 1110001 10000101 1001000
40:07.2 Get data from ID: 112 EE 1F 41 B 38 71 85 48 48 11101110 11111 1000001 1011 111000 1110001 10000101 1001000
40:07.4 Get data from ID: 112 EB 1F 40 B 38 71 85 48 48 11101011 11111 1000000 1011 111000 1110001 10000101 1001000
40:07.6 Get data from ID: 112 E9 1F 40 B 38 71 75 48 48 11101001 11111 1000000 1011 111000 1110001 1110101 1001000
40:07.7 Get data from ID: 112 EA 1F 40 B 38 71 75 48 48 11101010 11111 1000000 1011 111000 1110001 1110101 1001000
40:08.1 Get data from ID: 112 EC 1F 41 B 38 71 75 48 48 11101100 11111 1000001 1011 111000 1110001 1110101 1001000
40:08.4 Get data from ID: 112 EC 1F 41 B 38 71 75 48 48 11101100 11111 1000001 1011 111000 1110001 1110101 1001000
40:08.5 Get data from ID: 112 EC 1F 41 B 38 71 75 48 48 11101100 11111 1000001 1011 111000 1110001 1110101 1001000
40:09.3 Get data from ID: 112 EC 1F 41 B 38 71 75 48 48 11101100 11111 1000001 1011 111000 1110001 1110101 1001000
40:09.5 Get data from ID: 112 EC 1F 41 B 38 71 75 48 48 11101100 11111 1000001 1011 111000 1110001 1110101 1001000
40:09.6 Get data from ID: 112 EC 1F 41 B 38 71 75 48 48 11101100 11111 1000001 1011 111000 1110001 1110101 1001000
40:09.7 Get data from ID: 112 ED 1F 41 B 38 71 75 48 48 11101101 11111 1000001 1011 111000 1110001 1110101 1001000
40:09.8 Get data from ID: 112 ED 1F 41 B 38 71 75 48 48 11101101 11111 1000001 1011 111000 1110001 1110101 1001000
40:10.0 Get data from ID: 112 EE 1F 41 B 38 71 75 48 48 11101110 11111 1000001 1011 111000 1110001 1110101 1001000
40:10.2 Get data from ID: 112 ED 1F 41 B 38 71 75 48 48 11101101 11111 1000001 1011 111000 1110001 1110101 1001000
40:10.9 Get data from ID: 112 E3 1F 3F B 38 71 75 48 48 11100011 11111 111111 1011 111000 1110001 1110101 1001000
40:11.0 Get data from ID: 112 CB 1F 3B B 38 71 75 48 48 11001011 11111 111011 1011 111000 1110001 1110101 1001000
40:11.2 Get data from ID: 112 9B 1F 30 B 38 71 75 48 48 10011011 11111 110000 1011 111000 1110001 1110101 1001000
40:11.2 Get data from ID: 112 9A 1F 2F B 38 71 65 48 48 10011010 11111 101111 1011 111000 1110001 1100101 1001000
40:11.3 Get data from ID: 112 A6 1F 30 B 38 71 65 48 48 10100110 11111 110000 1011 111000 1110001 1100101 1001000
40:11.4 Get data from ID: 112 A0 1F 2F B 38 71 65 48 48 10100000 11111 101111 1011 111000 1110001 1100101 1001000
40:11.4 Get data from ID: 112 AA 1F 32 B 38 71 65 48 48 10101010 11111 110010 1011 111000 1110001 1100101 1001000
40:11.5 Get data from ID: 112 B1 1F 33 B 38 71 65 48 48 10110001 11111 110011 1011 111000 1110001 1100101 1001000
40:11.6 Get data from ID: 112 B3 1F 34 B 38 71 65 48 48 10110011 11111 110100 1011 111000 1110001 1100101 1001000
40:11.6 Get data from ID: 112 A3 1F 32 B 38 71 65 48 48 10100011 11111 110010 1011 111000 1110001 1100101 1001000
40:11.8 Get data from ID: 112 A3 1F 30 B 38 71 65 48 48 10100011 11111 110000 1011 111000 1110001 1100101 1001000
40:11.8 Get data from ID: 112 A4 1F 30 B 38 71 65 48 48 10100100 11111 110000 1011 111000 1110001 1100101 1001000
40:12.1 Get data from ID: 112 BA 1F 34 B 38 71 65 48 48 10111010 11111 110100 1011 111000 1110001 1100101 1001000
40:12.2 Get data from ID: 112 B4 1F 34 B 38 71 65 48 48 10110100 11111 110100 1011 111000 1110001 1100101 1001000
40:12.3 Get data from ID: 112 B6 1F 34 B 38 71 55 48 48 10110110 11111 110100 1011 111000 1110001 1010101 1001000
40:12.5 Get data from ID: 112 BB 1F 35 B 38 71 55 48 48 10111011 11111 110101 1011 111000 1110001 1010101 1001000
40:12.6 Get data from ID: 112 BC 1F 35 B 38 71 55 48 48 10111100 11111 110101 1011 111000 1110001 1010101 1001000
40:12.8 Get data from ID: 112 D7 1F 3B B 38 71 55 48 48 11010111 11111 111011 1011 111000 1110001 1010101 1001000
40:12.9 Get data from ID: 112 D7 1F 3B B 38 71 55 48 48 11010111 11111 111011 1011 111000 1110001 1010101 1001000
40:12.9 Get data from ID: 112 DF 1F 3B B 38 71 55 48 48 11011111 11111 111011 1011 111000 1110001 1010101 1001000
40:13.3 Get data from ID: 112 F4 1F 41 B 38 71 55 48 48 11110100 11111 1000001 1011 111000 1110001 1010101 1001000
40:13.4 Get data from ID: 112 F0 1F 41 B 38 71 55 48 48 11110000 11111 1000001 1011 111000 1110001 1010101 1001000
40:13.4 Get data from ID: 112 ED 1F 40 B 38 71 55 48 48 11101101 11111 1000000 1011 111000 1110001 1010101 1001000
40:13.5 Get data from ID: 112 ED 1F 40 B 38 71 55 48 48 11101101 11111 1000000 1011 111000 1110001 1010101 1001000
40:13.5 Get data from ID: 112 EB 1F 40 B 38 71 55 48 48 11101011 11111 1000000 1011 111000 1110001 1010101 1001000
40:13.6 Get data from ID: 112 ED 1F 40 B 38 71 55 48 48 11101101 11111 1000000 1011 111000 1110001 1010101 1001000
40:13.8 Get data from ID: 112 ED 1F 40 B 38 71 55 48 48 11101101 11111 1000000 1011 111000 1110001 1010101 1001000
40:14.0 Get data from ID: 112 ED 1F 40 B 38 71 55 48 48 11101101 11111 1000000 1011 111000 1110001 1010101 1001000
40:14.2 Get data from ID: 112 EC 1F 40 B 38 71 55 48 48 11101100 11111 1000000 1011 111000 1110001 1010101 1001000
40:14.2 Get data from ID: 112 EB 1F 40 B 38 71 55 48 48 11101011 11111 1000000 1011 111000 1110001 1010101 1001000
40:14.3 Get data from ID: 112 EB 1F 40 B 38 71 55 48 48 11101011 11111 1000000 1011 111000 1110001 1010101 1001000
40:14.4 Get data from ID: 112 EB 1F 40 B 38 71 55 48 48 11101011 11111 1000000 1011 111000 1110001 1010101 1001000
40:14.5 Get data from ID: 112 EC 1F 40 B 38 71 55 48 48 11101100 11111 1000000 1011 111000 1110001 1010101 1001000
40:14.8 Get data from ID: 112 EE 1F 40 B 38 71 45 48 48 11101110 11111 1000000 1011 111000 1110001 1000101 1001000
40:14.9 Get data from ID: 112 EE 1F 40 B 38 71 45 48 48 11101110 11111 1000000 1011 111000 1110001 1000101 1001000
40:15.0 Get data from ID: 112 EE 1F 41 B 38 71 45 48 48 11101110 11111 1000001 1011 111000 1110001 1000101 1001000
40:15.1 Get data from ID: 112 EE 1F 40 B 38 71 45 48 48 11101110 11111 1000000 1011 111000 1110001 1000101 1001000
40:15.1 Get data from ID: 112 EE 1F 41 B 38 71 45 48 48 11101110 11111 1000001 1011 111000 1110001 1000101 1001000
40:15.2 Get data from ID: 112 EE 1F 41 B 38 71 45 48 48 11101110 11111 1000001 1011 111000 1110001 1000101 1001000
40:15.4 Get data from ID: 112 ED 1F 40 B 38 71 45 48 48 11101101 11111 1000000 1011 111000 1110001 1000101 1001000
40:15.6 Get data from ID: 112 ED 1F 40 B 38 71 45 48 48 11101101 11111 1000000 1011 111000 1110001 1000101 1001000
40:15.7 Get data from ID: 112 ED 1F 40 B 38 71 45 48 48 11101101 11111 1000000 1011 111000 1110001 1000101 1001000
40:15.8 Get data from ID: 112 EC 1F 40 B 38 71 45 48 48 11101100 11111 1000000 1011 111000 1110001 1000101 1001000
40:16.0 Get data from ID: 112 ED 1F 40 B 38 71 45 48 48 11101101 11111 1000000 1011 111000 1110001 1000101 1001000
40:16.0 Get data from ID: 112 EE 1F 40 B 38 71 45 48 48 11101110 11111 1000000 1011 111000 1110001 1000101 1001000
40:16.1 Get data from ID: 112 EE 1F 40 B 38 71 45 48 48 11101110 11111 1000000 1011 111000 1110001 1000101 1001000
40:16.2 Get data from ID: 112 EE 1F 40 B 38 71 45 48 48 11101110 11111 1000000 1011 111000 1110001 1000101 1001000
40:16.3 Get data from ID: 112 EE 1F 40 B 38 71 45 48 48 11101110 11111 1000000 1011 111000 1110001 1000101 1001000
40:16.6 Get data from ID: 112 ED 1F 40 B 38 71 45 48 48 11101101 11111 1000000 1011 111000 1110001 1000101 1001000
40:16.7 Get data from ID: 112 EC 1F 40 B 38 71 45 48 48 11101100 11111 1000000 1011 111000 1110001 1000101 1001000
40:16.8 Get data from ID: 112 EC 1F 40 B 38 71 45 48 48 11101100 11111 1000000 1011 111000 1110001 1000101 1001000
40:17.0 Get data from ID: 112 ED 1F 40 B 38 71 45 48 48 11101101 11111 1000000 1011 111000 1110001 1000101 1001000
40:17.1 Get data from ID: 112 ED 1F 40 B 38 71 45 48 48 11101101 11111 1000000 1011 111000 1110001 1000101 1001000
40:17.2 Get data from ID: 112 ED 1F 40 B 38 71 45 48 48 11101101 11111 1000000 1011 111000 1110001 1000101 1001000
40:17.5 Get data from ID: 112 EC 1F 40 B 38 71 45 48 48 11101100 11111 1000000 1011 111000 1110001 1000101 1001000
40:17.6 Get data from ID: 112 EC 1F 40 B 38 71 45 48 48 11101100 11111 1000000 1011 111000 1110001 1000101 1001000
40:17.7 Get data from ID: 112 EC 1F 40 B 38 71 45 48 48 11101100 11111 1000000 1011 111000 1110001 1000101 1001000
40:18.0 Get data from ID: 112 EE 1F 40 B 38 71 45 48 48 11101110 11111 1000000 1011 111000 1110001 1000101 1001000
40:18.2 Get data from ID: 112 EE 1F 40 B 38 71 45 48 48 11101110 11111 1000000 1011 111000 1110001 1000101 1001000
40:18.3 Get data from ID: 112 ED 1F 40 B 38 71 45 48 48 11101101 11111 1000000 1011 111000 1110001 1000101 1001000
40:18.5 Get data from ID: 112 EC 1F 40 B 38 71 45 48 48 11101100 11111 1000000 1011 111000 1110001 1000101 1001000
40:18.6 Get data from ID: 112 EC 1F 40 B 38 71 45 48 48 11101100 11111 1000000 1011 111000 1110001 1000101 1001000
40:18.8 Get data from ID: 112 ED 1F 40 B 38 71 45 48 48 11101101 11111 1000000 1011 111000 1110001 1000101 1001000
40:19.0 Get data from ID: 112 EE 1F 40 B 38 71 45 48 48 11101110 11111 1000000 1011 111000 1110001 1000101 1001000
40:19.1 Get data from ID: 112 EE 1F 40 B 38 71 45 48 48 11101110 11111 1000000 1011 111000 1110001 1000101 1001000
40:19.3 Get data from ID: 112 ED 1F 40 B 38 71 35 48 48 11101101 11111 1000000 1011 111000 1110001 110101 1001000
40:19.4 Get data from ID: 112 EC 1F 40 B 38 71 35 48 48 11101100 11111 1000000 1011 111000 1110001 110101 1001000
40:19.6 Get data from ID: 112 EC 1F 40 B 38 71 35 48 48 11101100 11111 1000000 1011 111000 1110001 110101 1001000
40:19.7 Get data from ID: 112 EC 1F 40 B 38 71 35 48 48 11101100 11111 1000000 1011 111000 1110001 110101 1001000
40:20.0 Get data from ID: 112 EE 1F 41 B 38 71 35 48 48 11101110 11111 1000001 1011 111000 1110001 110101 1001000
40:20.1 Get data from ID: 112 EE 1F 41 B 38 71 35 48 48 11101110 11111 1000001 1011 111000 1110001 110101 1001000
40:20.2 Get data from ID: 112 ED 1F 40 B 38 71 35 48 48 11101101 11111 1000000 1011 111000 1110001 110101 1001000
- Has thanked: 106 times
- Been thanked: 228 times
Thank you very much it looks like I have some good data now.cloudy wrote: ↑Sat Jun 20, 2020 10:25 pm @tom91 - hopefully this helps with your efforts on adding simpbms support...
Overall setup:
Found even that it requested to balance or atleast something that looks like it
The control message to each module so 0x80 is for module 0 and 0x81 is for module 1 ect. The balancing voltages starts at 0x10C7 4295mV just like the I3 does then changes to 3678mV so as you indicate the lowever cell voltage.
Also got clear capture of a start up sequence to help get the modules started propperly, this was one of the biggest issues I faced with the I3 modules even when most canbus was decoded.
Is anyone with a brick based near Bristol and feels like coming to Zero-EV on a day on the weekend or let me borrow a module? I would like to validate some findings and then share these here and add them to my SimpBMS coding.
Hi, thanks for all this information sharing. I have a 2018 330e pack and really want to use the full internal BMW BMS via CAN. Not even opening the case if possible.
Does anyone know if the 330e pack has the same external CAN commands and data flow as a 2018 BMW X5 PHEV? (Albeit with one extra module?)
I just may (very much on the off-chance a colleague will let me) have the opportunity to log CAN messages to and from the pack external connector on his X5. If (very much if) I can make this happen, what sequence of events would I be looking for to capture the key signals?
This is what I was thinking:
>Start logger and iPhone video at same time of the dash
>Key on
>Try and note when contactor made contact - is it audible somewhere in the car? I'm guessing not. Can't hear them in my Lexus
>Note the SOC and any other info on the dash and more detailed screens
>switch on AC as a load at a known time and see any current data change on CAN
>Put in to D
>Drive
>Stop
>Turn off AC
>Key Off
May be do this a few times at different SOC.
May be great to try a charge cycle to?
Do you think this would be enough?
What is the data rate on the external bus pls?
If this fails, then I'll have to pop the case, and learn from your on-going work with the modules.
Thanks very much for your help and I'll certainly share what I can get if I can get permission.
>Key on
>Put in to D
>Drive
>Stop
>Turn off AC
>Key Off
External bus also at 500kbps - the internal switch gear looks physically identical across the 5/6 module packs I believe, so a full log as described would have a good chance of translating across all types - I've posted a log of the external bus (when disconnected from the car) a few posts up....
The entire contactor/bms/pre charge/iso monitoring can be removed from the housing in a single compact brick, so being able to control it would be useful for many - even if not using in the original case...
So thanks to Cloudy for the captures.
I have gained more confidence in my ways of canbus decoding and analysis.
BMW I3 use a CRC8 checksum with a stuffer in Byte 8 (starting counting at 1), I have concluded the Phev canbus commands do the same.
Now having done some computation, on the SimpBMS, as doing math in excel to do checksums is painful. I have good news, all be it for me, the final XOR in the checksum is IDENTICAL to the I3 one for each ID
I will generate a version of my SimpBMS software for more testing, hopefully this weekend.
Your work on this is much appreciated!
Have you been able to see any module bus ID coding mechanisms for those mixing packs? Might it be possible to recode in future?
The tis mentions cell module positions and serial numbers are stored in the SME and must be re entered if replacing SME...
"The serial number and installation position of the cell module and cell supervision circuit is stored in the SME. This composition must be maintained during repair. Or when replacing a cell module or cell supervision circuit, note down the serial number and installation position of the newly installed component for the start-up before the assembly."
Some relevant links:
https://www.newtis.info/tisv2/a/en/f30- ... 1VnYFQO2Rg
https://www.newtis.info/tisv2/a/en/f30- ... 1VnYjrQjIY
https://www.newtis.info/tisv2/a/en/f30- ... 1Vne0WFLGI
Are you watching over my shoulder? Been looking at some can captures made by someone showing one set of IDS being no longer present and being replaced by ID 0.
So maybe you could do a quick capture of a pack missing a 'random' CSC (slave module) remember to jump the connector to pass through the connector, maybe just removing the Cell Connector is enough too as the signals as physically linked on the PCB. Looking for more captures showing this behavoir.
I have found how to possibly get the Module into "unassigned" however assigning is what I need to capture now.
