I've had a little more of a play tonight, and I think it's starting to make sense. (Thanks Kevin)
Regardless of the position of the DIP switch, my TWC, upon detecting a vehicle, will start generating a 1kHz 5% Duty Cycle PWM signal ('Digital Comms'). It will generate this for about 3 seconds, and then switch to a duty cycle corresponding with the allocated current i.e. 16% for 10A.
If I switch in a 1.3k resistor when the duty cycle is not 5%, the TWC will switch on an apply power (according to J1172/IEC61851).
If I switch in a 1.3k resistor when the duty cycle is 5%, the TWC will flash red. I suspect it times out if I do not send CAN messages and this timeout is the flashing red. (I don't yet have hardware to sense this and start immediately sending CAN to prove this.)
Hence I suspect Tesla vehicles have the first 3 seconds to establish SWCAN or the session will revert to J1772.
Some third party vehicles will see the 5% duty cycle and switch to Digital Comms (I suspect HomePlug thinking its a DC fast charger) and then timeout.
New Tesla charger board
- Been thanked: 1117 times
Re: New Tesla charger board
If you look here : https://github.com/damienmaguire/Tesla- ... gicBoardV4
You will see the schematic for the board on which I implemented swcan. I copied the tesla control pilot circuit exactly even used the very same relay.
- Kevin Sharpe
- Been thanked: 10 times
I'd have to check the current standard but historically it referenced lots different 'digital' protocols which allowed the EVSE to identify the vehicle, etc.
Digital comms have been a feature of the IEC standard for at least a decade (we sold an EVSE controller in 2011 that was 'digital ready').
- Kevin Sharpe
3 seconds is the ACon timeout which is not Tesla specific. See page 38 in the attached extract from IEC61851-1{ed2.0}
