To summarize, a BMW Isetta "bubble" car from 1960, 4 wheel version, to be converted for inner city use. I prefer a minimal/reversible conversion, so only swapping out the ICE but keeping the Trans (not interested in hub motor). With only a 13hp engine currently (single cylinder motorcycle engine), it would seem that I need a very modest motor, and battery -- a used e-motorbike should be good for most parts; Alternatively, a new e-motor but also, low powered (but less cost effective).
A unique challenge is a real lack of space for batteries. If I re-position the original 12v small battery from it's under seat location, there would be enough clearance for a single Tesla model S dimension battery, but at 5.3kwh, not much capacity (also, I assume Tesla batteries are meant to be used for applications with more power needs). I'm just mentioning Tesla to give a feel for available space based on the battery form factor/dimensions. There could potentially be space for another Tesla model S dimension battery in the engine bay.
Details below:
Project: BMW Isetta, 4 wheel version
Current Layout: ICE, Transmission, and a chaincase with integrated rear axle (no differential as rear wheels very near to each other).
Car Weight: 350kg minus approx 50kg in ICE related parts (engine, filter, exhaust, muffler, carb, etc)
Design (I think): Swap out ICE for e-motor and use existing transmission, chaincase,etc. (Not in-hub motor).
- Power: Same or slightly more power than original engine (ICE: 13hp
- Range: Inner city use, I'm sure 50miles is great. Assume 8 or 10kwh would be enough.
- Special challenge: Very little space for batteries, and probably shouldn't add more than 50-70kg in extra weight.
(space available for charger, controller, controller radiator if needed, junction box)
Any suggestions? Parts or motors to look at? Battery is a BIG question...
Thanks. Baron (London, UK)
