Right, so if Damien wants to create an interface which is similar to the Huebner one then a third party can take it from there (the customization probably involves the most back-and-forth with clients, Damien already gets burned out with the clients he has).mdrobnak wrote: ↑Wed Jun 03, 2020 3:01 am From my perspective you could put together customized versions which drop into various vehicles, like E46 BMWs as there is sufficient documentation to build a Plug-and-Play solution from the control side of things. However, even with that variables like BMS, contactor setup, etc are enough variance that this is not easy to be done for the end user without having knowledge and access to certain tools.
As a result I think it opens up a marker for an integrator to put this all together and make some cash off that while still allowing it to be a pretty cheap conversion. Except for the damn oil pump...places on eBay are removing them from the transmission...
-Matt
So the simple CAN control, voltage limits, pedal interface, throttle limits and such would be in the universal interface, then the specific CAN bus or special I/O gets done on one-off basis. No, I won't do that (unless I use the product in the future).
-Isaac
d
