HOWTO: Flashing ESP8266
- ZooKeeper
- Has thanked: 8 times
- Been thanked: 5 times
Re: HOWTO: Flashing ESP8266
post deleted
Time for ICE Melt
davidwagstaff
Well i'm not getting anywhere with this. It seems the Arduino IDE is not loading the spiffs. Has anyone sucessfully done this with a recent build of the Arduino IDE? I found some info about spiffs no longer being supported by the ESP8266 core
https://arduino-esp8266.readthedocs.io/ ... ystem.html
I am not familiar with using Python and have no idea how to follow the instructions that have been given previously to use this method. Any help would be greatfully received
davidwagstaff
Ok finally have success.
This seems to be a Arduino build compatibility issue. Loaded Arduino 1.8.0 on a different laptop and used ESP board core 2.6.2 and have successfully loaded sketch and spiffs to both NodeMCU and Olimex mod board.
- ZooKeeper
post deleted
Time for ICE Melt
- Has thanked: 479 times
- Been thanked: 314 times
This is what I fuckin' hate about open source. The complete an utter user unfriendliness of it, and the impossibility of an amateur to wade through it. You have to guess the correct thing it might be, that you maybe didn't even know was a thing that could even be correct or incorrect, and hope it works.davidwagstaff wrote: ↑Sun May 24, 2020 7:21 pmThis seems to be a Arduino build compatibility issue. Loaded Arduino 1.8.0 on a different laptop and used ESP board core 2.6.2 and have successfully loaded sketch and spiffs to both NodeMCU and Olimex mod board.
Good sleuthing to guess that maybe that was it and to try it out, needle in a haystack.
This just happened a week ago
Source: https://github.com/esp8266/Arduino/pull/7263
Will need new Arduino Plugin https://github.com/earlephilhower/ardui ... efs-plugin
LittleFS is indeed a drop-in / transparent replacement for SPIFFS.
Just replace all occurrence of SPIFFS by LittleFS in your code.Will need new Arduino Plugin https://github.com/earlephilhower/ardui ... efs-plugin
- ZooKeeper
post deleted
Time for ICE Melt
- celeron55
- Has thanked: 39 times
- Been thanked: 136 times
Polishing software to a degree where a non software engineer can use it is really tedious and not fun, so it comes down to the price one pays for it. Software gets expensive when you pay someone to do the non fun stuff. If you would like to do so, you can choose between buying a ready made closed source solution or paying someone to do the non fun stuff to an open source solution.MattsAwesomeStuff wrote: ↑Sun May 24, 2020 9:38 pm This is what I fuckin' hate about open source. The complete an utter user unfriendliness of it, and the impossibility of an amateur to wade through it. You have to guess the correct thing it might be, that you maybe didn't even know was a thing that could even be correct or incorrect, and hope it works.
Thank you! @celeron55 I was starting to feel discouraged ...again.
Need one of them Johannes torque gloves.
Yeah, not complaining, just lamenting. Open source is best around a group of programming peers. Basically "I could write this, but someone else already did, neat". Outside of that, to someone who couldn't write it from scratch if they had the time, its limits rear their heads.
By virtue of being open source, no one is responsible for anyone else. So for example, one project making a change that borks another project that they probably didn't even know existed. It's certainly not the first project's responsibility to ensure all the projects that use it remain compatible. And, after someone creates a following project, they should not be bound for life in constant support of that project to maintain it and make sure it can keep working. So the nature of Open Source seems to be incomplete documentation, stagnant projects, and time-rotted code.
Option 3 for me is, if you can't write the code, contribute in other ways to the project to help more people be able to use it. Bridge that usability gap.
Most forums are the same its usually the same dozen people talking in code which is hard for the outsider to get in.
Always reminds me of IKEA , you know what you want, you cant really find it, you just hope you'll bump into a store rep that day to guide you
- jason_arnold
- Has thanked: 4 times
Dima, I'd like to have a go at running your latest variant of the web interface, but the mklittlefs tool your PS script calls is no longer available, so I'm unable to compile my own .bin for the file system - any chance you have one ready to share?
@dima I flashed your most recent update, have a solid green light afterwards and no inverter SSID, something I did wrong?
Disregard.
Maybe I spoke too soon. It worked, but now I get a "not compressed" message. I've tried running the script again and selecting "compress javascript -y" when prompted. Anyone have this happen as well?
SO weird.. It'll work for a short period, let me click around the interface briefly, then restart and 404 all pages but update. I can upload the littlefs once again and it'll do the same, attempt to work then says uncompressed and redirects to update.. Maybe I just have a bad Olimex? Anyone that's been through these things before, would certainly appreciate your input.
- qmedia2651
you can us a Wimos D1 Mini I've been working on a shield for the LDU to use the Wimos instead of the Olimex. I have the gerber files and PCB file for Fritz. It Works waiting for my parts to populate my board. Working on my 1991 Mercedes 300CE EV Conversion with a Tesla LDU. All Nissan Leaf battery pack fits in the front, this car came with a M104 6cyl cast iron engine about 900 lbs. Less than the battery pack.
[img]
[img]
- bexander
- Has thanked: 78 times
- Been thanked: 102 times
To get it to work using Arduino IDE, I had to do first a "normal" upload (Sketch -> Upload) and then sketch data upload (Tools -> ESP8266 Sketch Data Upload).
Hi all,
I think I've managed to flash to ESP8266 however I'm unable to see it when searching for an SSID, Should the SSID be broadcasting automatically after the flashing process? should I be able to to access the ESP Wifi Web page prior to connecting to the Inverter controller?
- Been thanked: 1918 times
The default SSID is ESP_XXXX (where XXXX is part of the MAC address). If thats not showing something went wrong with the flash process.
No, you can't access anything before connecting
Hi Johannes, Thanks for getting back to me on this, and great work with all of this by the way. Are you saying that, after the upload, if i just apply 3.3v to the MOD-WIFI-ESP8266, I should have a broadcasting ESP_XXXX SSID? Thanks again
I've managed to get it working. After flashing the successfully which should look like the log below, GPIO0 MUST be soldered back to 1 in order to see an active SSID to broadcast a WIFI AP.
This is the logs after successful flash from MAC Os
[SPIFFS] data : /Users/ladmin/Documents/Arduino/FSBrowser/data
[SPIFFS] size : 1000
[SPIFFS] page : 256
[SPIFFS] block : 8192
/wifi-updated.html
/gauges.html
/ajax-loader.gif
/index.html
/inverter.js
/remote.html
/chart.min.js.gz
/syncofs.html
/gauge.min.js.gz
/log.js
/index.js
/jquery.core.min.js.gz
/README.md
/chartjs-annotation.min.js.gz
/wifi.html
/log.html
/style.css
/gauges.js
/jquery.knob.min.js.gz
/refresh.png
[SPIFFS] upload : /var/folders/pf/g5203ncd4r17pkc3gm4tzk7r0000gn/T/arduino_build_495601/FSBrowser.spiffs.bin
[SPIFFS] address : 0x100000
[SPIFFS] reset : --before no_reset --after soft_reset
[SPIFFS] port : /dev/cu.usbserial-A50285BI
[SPIFFS] speed : 115200
[SPIFFS] python : /Users/ladmin/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1/python3
[SPIFFS] uploader : /Users/ladmin/Library/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/upload.py
esptool.py v2.8
Serial port /dev/cu.usbserial-XXXXXXX
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: xx:xx:xx:xx:xx:xx
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Auto-detected Flash size: 2MB
Compressed 1024000 bytes to 118444...
Wrote 1024000 bytes (118444 compressed) at 0x00100000 in 10.5 seconds (effective 783.4 kbit/s)...
Hash of data verified.
Leaving...
Hard resetting via RTS pin...
- Has thanked: 91 times
- Been thanked: 517 times
How did you solve this one? I'm getting it. I've got a Bluepill with STM32-car on there, it responds ok to requests for 'json' using a usb-ttl but when I connect up the Wemos D1 and hit the index.html I get an error. '/cmd?cmd=json' givesjnsaff wrote: ↑Mon Mar 16, 2020 9:20 pm I'm having a similar problem as well. I got the ESP8266 from Johannes so it should be fine. Then programmed the bootloader and stm32_sine.hex red led is on and green is blinking on the blue pill.
No parameters are showing but when I try to Display Error Memory I get:Custom command 'json' getsCode: Select all
Unknown command sequence e��K� Unknown command sequence
So it seems that they are communicating as from the forum search this error is something that the stm32_sine sends back. But TX may be messed up somehow? I believe my Blue Pills may be quite dodgy .. so would want to put the black pill on there instead but the pin labels are not exactly the same. Any ideas? Much appreciated!Code: Select all
Unknown command sequence j��)
j��)BMW E91 2006
This tell you wrong TTL speed. Check speed with 'http://192.168.4.1/baud'
'http://192.168.4.1/baud' just shows
fastUart off
Bluepill has
and ESP8266
fastUart off
Bluepill has
#define USART_BAUDRATE 115200
usart_set_baudrate(TERM_USART, USART_BAUDRATE);
void setup(void){
Serial.begin(115200);
Serial.setTimeout(100);
SPIFFS.begin();
