Simp BMS
Kevin Sharpe
Been thanked: 10 times
Re: Simp BMS
Post by Kevin Sharpe »
tom91 wrote: Fri Apr 17, 2020 2:57 pm On a Tesla system I would say up to 32 slaves of 6 cells each should work if the communication is robust enough.
The EVTV controller supports 62 Tesla Modules (here)
Has thanked: 328 times
Been thanked: 847 times
Re: Simp BMS
Kevin Sharpe wrote: Fri Apr 17, 2020 4:39 pm
In theory it does and so does the SimpBMS, but I am not going to promise it will do 62 modules as the data travel time will become quite high. No one has yet proven it can do this high of a module count.
Kevin Sharpe
Re: Simp BMS
tom91 wrote: Fri Apr 17, 2020 4:43 pm No one has yet proven it can do this high of a module count.
Are you sure that EVTV have not tested that? It's very clear on their product page.
Re: Simp BMS
Kevin Sharpe wrote: Fri Apr 17, 2020 4:45 pm
It is a number based on the message format. 63 ids available one is assigned to broadcast to all.
mdrobnak
Re: Simp BMS
Post by mdrobnak »
tom91 wrote: Fri Apr 17, 2020 2:57 pm No need for a custom firmware, I can roll it into existing firmware. Have done so in the past with the Outlander Slaves.
Oh, nice. Yeah my thought was BMS + CAN Man-in-the-middle to change the ID + N number of slaves.. ($30 for a complete set on Ebay! - https://www.ebay.com/itm/Chevy-Volt-Sto ... 2817016231)
That's good news. :)
JaniK
Has thanked: 101 times
Been thanked: 15 times
Re: Simp BMS
Post by JaniK »
Does this work with phase2 e-golf too? With the 35.8kWh pack?
Re: Simp BMS
JaniK wrote: Wed May 13, 2020 2:08 pm Does this work with phase2 e-golf too? With the 35.8kWh pack?
Yes it can read temperatures and voltages but not command any balancing.
JaniK
Re: Simp BMS
Post by JaniK »
Thanks for fast reply.
So there would be no balancing happening at all or it will just run automatic on slaves and be uncontrolled?
Re: Simp BMS
JaniK wrote: Wed May 13, 2020 9:14 pm Thanks for fast reply.
No balancing.
JaniK
Re: Simp BMS
Post by JaniK »
Ok cool. Its still great to have the voltages and temps.
Boxster EV
Has thanked: 57 times
Been thanked: 50 times
Re: Simp BMS
Post by Boxster EV »
Does SIMPBMS provide any outputs upon charge completion (IE going from 'charge' state to 'ready')? I'm trying to figure our the best way to manage things like the lock pin on charge socket and cutting the PP signal to disconnect AC.
Been thanked: 411 times
Re: Simp BMS
Boxster EV wrote: Fri May 15, 2020 11:01 am Does SIMPBMS provide any outputs upon charge completion (IE going from 'charge' state to 'ready')? I'm trying to figure our the best way to manage things like the lock pin on charge socket and cutting the PP signal to disconnect AC.
See here EVSE signaling https://en.wikipedia.org/wiki/SAE_J1772#Signaling
So from PP-PE you want to cut the signal and EVSE will think it is disconnected, but i dont know if it will unlock cable? That would be good to test first.
I have a button that pulls additional 1K3 resistor to CP - PE loop and EVSE starts the power. If i remove connection i still need to manually unlock cable from EVSE. I did actually put a switch lock on my plug and i use it if my cable gets stuck.
What i do is i cut complete CP-PE line after diode and EVSE drops the lock. But it reports this event as an error!
Re: Simp BMS
There is an output, charge enable that is on when it is in charge mode. In ready mode no outputs are on.
12V output so you can drive a relay to do all sorts of things.
You can get so fancy to use some relay logic to do, car locked OR charging, lock actuator is locked.
Car unlocked AND not charging lock actuator unlocked.
Boxster EV
Re: Simp BMS
tom91 wrote: Fri May 15, 2020 11:45 am
Yep, I'm thinking analogue and planning to introduce a few relays to manage what I want to switch on or off.
However, I don't quite understand how an output is achieved... Pin 6 of connector J5 is 'charge enable', fed from 12v supply to tell simpbms to go into a charge state. (I achieve this via the 240vac relay coil on my setup). My understanding is that the BMS moves the state from charge to ready once the pack is charged (IE pin 6 will still have 12 fed to it).
Therefore how can an output be achieved?
I'm probably being thick here and need a light bulb moment.
Re: Simp BMS
Boxster EV wrote: Fri May 15, 2020 12:19 pm
J5 is input
J4 has the outputs on it, these are matched to BMS states. Pin 13 is the 12V charge enable, so if the BMS is in the charge state this output is on.
https://github.com/tomdebree/SimpBMS/bl ... 0V0.21.pdf
Boxster EV
Re: Simp BMS
tom91 wrote: Fri May 15, 2020 12:36 pm
J5 is input
And there's the light bulb moment. :D
rwaudio
Re: Simp BMS
Post by rwaudio »
tom91 wrote: Thu Apr 16, 2020 11:11 am
mdrobnak wrote: Wed Apr 15, 2020 10:46 pm Is it possible to use the Volt BMS slaves with the LG Chem / Chrysler Pacifica batteries? They are 16 series cells, none in parallel. That would certainly cut total acquisition costs on those if so...
You can wire any slave to any battery, just as long as the chemistry and cell count matches.
always some exceptions on this rule, you can wire some slaves with less cells if you tie the unused ones to the highest cell (tested on Outlander and Tesla Slaves.
Hey tom91,
I'm playing with a bunch of Tesla version one model S BMS boards (I use to break down modules to get raw 18650's) I see you mention being able to use the boards at lower than full cell count. I'm going to be using 10x 10S LG Chevy modules and would like to use two boards per module with cell 6 on both not connected. I've tried tying 5&6 together etc however the board always registers a fault. Do you know if there's any way to retain the hardware fault line with 5 cells per module? I'm just doing this on a Due for proof of concept.
Re: Simp BMS
rwaudio wrote: Thu May 28, 2020 4:47 pm
Hey tom91,
No hardware fault will happen thats in the firmware fo the slave, however data will still flow correctly, you need to tie 5 and 6 together to get correct data.
I believe you can even tie 4 5 6 togethor.
rwaudio
Re: Simp BMS
Post by rwaudio »
tom91 wrote: Thu May 28, 2020 7:16 pm
Hey tom91,
Thanks! Since the fault line doesn't seem to activate on temperature anyway I guess I'll ignore it.
Re: Simp BMS
Hi TomDB
I got SimpBMS this weekend and i went on and took apart original Volt BMS wiring, Up till now i read manual and made diagrams on how i would connect it in my Pug. I had had no problem with understanding of the manual. But i am left with a single wire which i think is a Fault wire.
I have made a number of tests on Volt BECM which led me to belive this wire sends quick +5V transient in case if i unplug one connector or one wire from BMS. This may be a latch release for BECM report during charging. But i never saw any difference in BECM output, Did you consider to use this wire or signal in your BMS?
I am talking about the blue wire in position pin 13 of BECM connector. Could we use it somehow? Or do i discard it?
TNX
Re: Simp BMS
Arber, I do not use any fault wires Volt or Tesla. The way things get done is verifying the transmitted data and if the data is transmitted and if there are any issues not allow anything to happen. I do not like assuming things are fine when data becomes spotty or drops out.
Thank you for the feedback on the manual.
Re: Simp BMS
tom91 wrote: Sun May 31, 2020 8:40 pm Arber, I do not use any fault wires Volt or Tesla. The way things get done is verifying the transmitted data and if the data is transmitted and if there are any issues not allow anything to happen. I do not like assuming things are fine when data becomes spotty or drops out.
OK so i will just leave the wire inside the loom for future use maybe...
joromy
Re: Simp BMS
Post by joromy »
I want to have the kWh sent out on the CAN bus.
Have put in "kWh = amp times volt" and added it to CAN send.
And are receiving i correctly on my CAN display.
But I don't understand the theory behind the calculation, what is 0.27777777777778.
It may be wrong way to calculate remaining kWh of the battery anyway?
    SERIALCONSOLE.print("% SOC ");
    SERIALCONSOLE.print(ampsecond * 0.27777777777778, 2);
    SERIALCONSOLE.println ("mAh  ");
    SERIALCONSOLE.print(kWh);
    SERIALCONSOLE.println ("kWh");
  kWh = (ampsecond * 0.00027777777778 * bms.getPackVoltage()/ 1000);
Re: Simp BMS
joromy wrote: Wed Jun 03, 2020 6:27 pm I want to have the kWh sent out on the CAN bus.
AmpSecond to Amp Hour :D
Biggest issue is that Ampere Capacity (Ah or AS) is not linked to voltage, voltage varies over SOC so calculating kWh is not as easy as you think.
Bryson
Re: Simp BMS
Post by Bryson »
Maybe the better way is SOC * Ah setting * #cells in series * voltage at 50% SOC (interpolated from whatever you chose your SOC settings to be)
