BMW e39 "i5"
mfox
Re: BMW e39 "i5"
Post by mfox »
Integration of LCD BMS.
Im happy how it looks like. It need's to be more fabricated and painted in black . To be fully integrated in car.
I really enjoy doing this.
mfox
Re: BMW e39 "i5"
Post by mfox »
Second is for lexus gearbox ;)
Kevin Sharpe
Re: BMW e39 "i5"
Post by Kevin Sharpe »
Fabulous build :D
Would it be possible to post the photos direct to the forum and not via a third party hosting site in future? So many forums have been destroyed when hosts change policies and no longer host for free. Many thanks :)
mfox
Re: BMW e39 "i5"
Post by mfox »
Tnx :D
Is not a problem. It was in my habit to put pictures like this.
philbrennan
Been thanked: 7 times
Re: BMW e39 "i5"
Post by philbrennan »
Amazing. Inspiration for my e39 touring build. I'm caught between this and the Lexus route.
mfox
Re: BMW e39 "i5"
Post by mfox »
TNX :) , Lexus drivetrain , you don't have nothing to think about.
2.5 years ago when I bouhgt warp and zilla, there was no lexus... Only bmw cupe with no open source controller. Now I also bought lexus, but voltage with tesla battery is to small for some performance . Let it stay. Maybe I catch another inspiration for some other project .
mfox
Re: BMW e39 "i5"
Post by mfox »
I bought e46 pedal and zeva digital pot adapter. They customise pot adapter to my e46 pedal. I find that best and the safest solution for throttle. Better then analog . I could done this with arduino and digital arduino pot , but It is to dangerous to play with. I need to be 100% sure that will work. On the bench work perfect. it goes 0-100% :D
hood for box is finish.
Also bought some wirening.
Bentto
Re: BMW e39 "i5"
Post by Bentto »
Nice. Could you explain why this is a safer solution? It's still signal (but now as a variable resistance instead of voltage) that has to reach the controller. Instead of a direct 0-5V signal to the controller that is converte to digital over there you have now added an extra component that can potentially fail?
mfox
Re: BMW e39 "i5"
Post by mfox »
Bentto wrote: Thu Mar 05, 2020 6:55 am Nice. Could you explain why this is a safer solution? It's still signal (but now as a variable resistance instead of voltage) that has to reach the controller. Instead of a direct 0-5V signal to the controller that is converte to digital over there you have now added an extra component that can potentially fail?
I mean , it is safer solution to buy this thing when allready exist, then trying to make my own with arduino. I don't know if I'm able to make it reliably. Yes I know I will learn something, but it needs more time, and without this I have enough work to do...
Other thing is that Zilla reads resistance from 150R-4K8. Not voltage.. Hall sensor work with voltage. So I need convert voltage from 0-5V to resistance of 0-5K (). IF I use alanog pot, during time of using you can get twitches on the motor because of spending mecanical pot...
E46 throtle pedal gives signal from 0.8V-4.0V , so they needed to customize digital pot.
It also have zilla hairbal that work with hall sensor , but in my case is not that.
Bentto
Re: BMW e39 "i5"
Post by Bentto »
Ok, clear ;) Following the build with much interest.
mfox
Re: BMW e39 "i5"
Post by mfox »
I purchased gopro 7 black , so I decided to open youtube channel and make some video. why the hell not :)
This is the first introduction video.
I is not like I imagine at first , but is ok . Sorry for my bad english.
mfox
Re: BMW e39 "i5"
Post by mfox »
I have second video.
I need to work a little bit on my audio.
mfox
Re: BMW e39 "i5"
Post by mfox »
happy Easter to all who celebrate,
I have new video
mfox
Re: BMW e39 "i5"
Post by mfox »
mike77cos
Has thanked: 4 times
Re: BMW e39 "i5"
Post by mike77cos »
What a great project
mfox
Re: BMW e39 "i5"
Post by mfox »
Tnx. And sorry for bad audio quality. Didn't have time and will to play with it.
mfox
Re: BMW e39 "i5"
Post by mfox »
Finnaly the real thing
mfox
Re: BMW e39 "i5"
Post by mfox »
Seat heating and kill switch
mario
Has thanked: 70 times
Been thanked: 10 times
Re: BMW e39 "i5"
Post by mario »
Great job. Keep up a good work. :)
mfox
Re: BMW e39 "i5"
Post by mfox »
Tnx :)
mfox
Re: BMW e39 "i5"
Post by mfox »
Plastic covered
mfox
Re: BMW e39 "i5"
Post by mfox »
mfox
Re: BMW e39 "i5"
Post by mfox »
Finnaly my last battery pack that I needed to put in the car.
and finnaly fully load.
mattndex@gmail.com
Re: BMW e39 "i5"
Post by mattndex@gmail.com »
This is impressive work, I'm inspired.
mfox
Re: BMW e39 "i5"
Post by mfox »
tnx :)
