Triumph Herald Project
EVElvis
Post by EVElvis »
http://www.evalbum.com/3093
Started in 2009
Enova 90kW motor
Headway Batteries
Would like to get some better batteries before I try to go any distance.
https://www.youtube.com/channel/UCKT7BW ... g/featured
Kevin Sharpe
Been thanked: 10 times
Re: Triumph Herald Project
Post by Kevin Sharpe »
Looks like a great project in the video :)
Please post your images direct to this forum and not via a third party hosting site. They often do not display correctly or get removed which breaks our forum (see screenshot).
Please also add your location so that we know where in the world you're based :)
zippy500
Has thanked: 100 times
Been thanked: 7 times
Post by zippy500 »
Damien will be proud , you using that motor ;)
Can you tell us how you setup your speedo ?
EVElvis
Post by EVElvis »
Cheers Guys
The speedo uses the shell and needle of the original.
The speedo utilises an Arduino Nano, Small LCD, and a Easydriver stepper motor board, driving a Switec X27 168 motor.
Latest code and info here:
https://github.com/TJH1981/Digital-Speedometer.
The Code needs improving as if you loose power when it is not at zero it will not return to zero on re-start. It is also a bit noisy with the motor directly mounted to the metal face.
