Some time ago I've started my conversion of BMW E87 from 2006 year. I tried many times to put my project into this section, but I had limited time to divide this between homemade conversion and asking all of You for help in my troubles
So, from beginning:
First I tried to fight with v2 board, which I already did and is working well with my powerstage and big foil capacitors but then Johannes improve old version and did v3 board, what was perfect for my conversion, because I had original Leaf motor EM57+inverter.
My setup now is:
- EM57 motor from 2012 year
- Leaf battery pack, but with 80 cells and about 320V fully charged
- charger from Volvo V60 plug-in bought with type 2 charging connector - also found on Arber's blog
- DCDC from Chevrolet Ampera - thanks Arber for Your help
- Orion BMS - almost perfect stuff, but not so cheap
- Vacuum pump from Audi
- power steering pump from Opel Astra - is working well but works like jet turbine
Rest of components I will show in next posts, I hope. I'm working in aluminium extrusion plant, so don't be surprised, that there are so many alu profiles
Here is first trial to made motor holder. Fits in original gas motor handle Like I said, I used V60 socket. Fits under original filling cover and have 3 color status LED - Later I want to connect them Trunk packet - 24 cells (in fact 48) - original from Leaf battery fits perfect.
On left side is fuse holder and on right side will be Orion BMS on top. Underbody pack where was tank. Of course BMW can't do regular form, so was not so easy to discover how to put this on original bolts. After some weeks on trials with spline, coupler, trials with parameters and CAN control, was time to do harness. My CAN setup now is now divided:
CAN1: BMW (throttle, brake, instrument cluster, etc) -inverter
CAN2: OrionBMS, charger, DCDC
I will try to put everything in one CAN, if will be no problem with communication, I will left like this.
Now looks like this. Better but still needs some works, covers and DCDC cooling. I will use original motor cover, where was air intake to filter. Will be driven to DCDC, should be enough, I hope. After months of work now car is working. First test trials on road was great! Acceleration according to original 1,6l gas was like a rocket
Now I have to work with instrument cluster rpms and still blinking check-engine information (of course hundred of sensors are missed
In next post I will show how I connected powersteering and what was important in tubing, what I did't know.
Regards.
