Leaf Gen 1 board
Re: Leaf Gen 1 board
I wish I found this thread earlier, I was unable to find the white connector anywhere after damaging the first one and had to buy a replacement inverter just for the connector. Good news is the inverter is only $200, Now I have 2 inverters for whatever reason and know where to get a hold of the connector:).
Anywho, Just bought the v3 Brainboard, Had my Gen 1 Leaf adapter made and ordered parts from the BOM. I'll test and report back when I get a hold of all parts. For now I'll keep reading through the Docs.
Is the process for the Gen1 and brainboard similar to the Gen2? Just attach the brainboard to the adapter, connect wires to the white connector? What pins power the motor?
I have installed the Leaf Gen 1 adapter with my V3 brain board into my Leaf Gen 1 Inverter, but I still haven't got the motor to spin yet.
The DESAT error is always asserted, even before I try to run the motor in manual mode from the web interface. Has anyone else made it past this point?
Update: Got the motor spinning! We had to remove the DESAT pin (and connect the forward pin to 12V...). Looks like the alert signal on this Leaf inverter is active high instead of active low. Does anyone know if this polarity is easily changed in the brainboard firmware? If not, it might be easier to invert the signal with hardware.
The inverter enclosure can't close with brain board being a daughter board on top of the adapter board, so I will have to design a new board to combine the brain board and adapter board (and integrate the brain board test circuit too).
- Has thanked: 157 times
- Been thanked: 1023 times
That is very useful feedback. Too bad the universal brain board approach doesn't work here. How much extra room would there need to be? Would it work upside down?
The DESAT pin feeds into a NAND tree, i.e. it must be high in order for PWM to run. Inversion needed... Maybe an NPN transistor for now
Thanks for reporting back. What pin is the DESAT pin? Is it on the v3 board or the adapter board?lpitka wrote: ↑Fri Feb 28, 2020 3:36 pm Update: Got the motor spinning! We had to remove the DESAT pin (and connect the forward pin to 12V...). Looks like the alert signal on this Leaf inverter is active high instead of active low. Does anyone know if this polarity is easily changed in the brainboard firmware? If not, it might be easier to invert the signal with hardware.
It might work with the brain board on the bottom side of the adapter board. I will take a look when I'm back in the shop on the weekend.johu wrote: ↑Fri Feb 28, 2020 4:47 pm That is very useful feedback. Too bad the universal brain board approach doesn't work here. How much extra room would there need to be? Would it work upside down?
Another option would be to rearrange the adapter board so the brain board can sit right on top of the adapter board and be soldered to it instead of having to use female headers. Currently female headers are needed because the brain board would otherwise collide with CN4 and CN5, and the WiFi module would collide with CN1. If the brain board could be moved up a few mm on the adapter board then it would no longer collide with CN4 and CN5, and CN1 could be moved to the other side of the WiFi module. In this case, the brain board would be able to sit low enough on the adapter board to fit in the inverter enclosure.
I will add a transistor to invert the DESAT signal on the next board I order. Simple fix to the problem.
The DESAT pin is on the V3 board and is used to detect desaturation of the motor, as described in the theory section of the WiKi: https://openinverter.org/wiki/Hardware_ ... _Operationelectric_e60 wrote: ↑Sun Mar 01, 2020 5:52 amThanks for reporting back. What pin is the DESAT pin? Is it on the v3 board or the adapter board?lpitka wrote: ↑Fri Feb 28, 2020 3:36 pm Update: Got the motor spinning! We had to remove the DESAT pin (and connect the forward pin to 12V...). Looks like the alert signal on this Leaf inverter is active high instead of active low. Does anyone know if this polarity is easily changed in the brainboard firmware? If not, it might be easier to invert the signal with hardware.
There are 5 fault signals on CN3 of the adapter board that are all tied to this pin. Johannes noted these pins in a post a few pages back in this forum topic.
Thanks. After removing DESAT pin, did you just have to put power to pin 7 and connect grounds to get the inverter working? I tried and had no luck.lpitka wrote: ↑Thu Mar 05, 2020 5:01 amIt might work with the brain board on the bottom side of the adapter board. I will take a look when I'm back in the shop on the weekend.johu wrote: ↑Fri Feb 28, 2020 4:47 pm That is very useful feedback. Too bad the universal brain board approach doesn't work here. How much extra room would there need to be? Would it work upside down?
Here are the basic steps I followed to get the motor spinning:electric_e60 wrote: ↑Thu Mar 05, 2020 5:59 pm Thanks. After removing DESAT pin, did you just have to put power to pin 7 and connect grounds to get the inverter working? I tried and had no luck.
- Connect the brain board to get Gen 1 adapter board with DESAT pin removed
- Connect the start pin (pin 7) to the 12V pin
- Apply 12V and GND
- From the web interface:
- Load the Leaf configuration file from the wiki and save it to flash: https://openinverter.org/wiki/Configuration_Files
FYI: I had to remove the last comma from this JSON file for it to upload properly! - Follow the "Tuning Process" described at the bottom of this guide: https://openinverter.org/wiki/Using_FOC_Software
Good luck!
Hey Lance,
you see me surprised - it works with pinswap=4 ?
Removed the trailing comma
Hi Johannes,
Yes, it worked with pinswap=4. I haven't tried changing any parameters yet. Waiting until we finish mounting the motor in the truck before we try adjusting parameters.
thanks for your help. I decided to give it a shot today. Got The inverter powered on. Removed my DESAT, connected start -> 12V, hooked up 12V and GND But I get a "WARN - PWNSTUCK" and "STOP - MPROT" errors. Did you have these issues?lpitka wrote: ↑Tue Mar 10, 2020 6:48 pmHere are the basic steps I followed to get the motor spinning:electric_e60 wrote: ↑Thu Mar 05, 2020 5:59 pm Thanks. After removing DESAT pin, did you just have to put power to pin 7 and connect grounds to get the inverter working? I tried and had no luck.After following these steps the motor started to work. If you have issues then make sure to check the error log.
- Apply 12V and GND
FYI: I had to remove the last comma from this JSON file for it to upload properly!- Follow the "Tuning Process" described at the bottom of this guide: https://openinverter.org/wiki/Using_FOC_Software
Good luck!
Did you upload the Leaf parameters json config file? I had those errors before I used this parameters file.
Seems like I may be having issues with the parameters then.
I did upload the parameters.json file but got "out of range" error message when it tried to set curki to 20000 and for another parameter. I think That may be the culprit.
I'll try tinkering with it a bit more when I get home and hopefully I'll get the leaf motor to spin .
Make sure you are using the latest FOC firmware: https://github.com/jsphuebner/stm32-sine/releases
I believe the earlier versions of the firmware had a lower limit for the curki parameter.
Thanks. Updated the firmware and the parameters uploaded successfully but the errors are still there unfortunately and no luck with the motor. Think I may have to do more digging.
lpitka wrote: ↑Tue Mar 17, 2020 5:58 pm Make sure you are using the latest FOC firmware: https://github.com/jsphuebner/stm32-sine/releases
Had a session with Soheil and Graison today and we got the Gen1 adapter board sorted. Most importantly: pinswap=2, i.e. swap resolver sin/cos. Just as important: negative current sensor gains, -1.7. Then it turned out the deadtime of 78 for the gen2 inverter is NOT sufficient for the gen1. We increased it to 150, maybe it can be lower but we held it there. We tuned syncofs of 49000.
Soheil found a voltage signal on CN3.12 which I assumed to be another fault signal. Will confirm this later when he connects it to the UDC input but he said he found a 9mV/V coefficient on it.
So maybe I will respin the board and put it on the shop. Would be good to confirm the fault pins. Right now they are disconnected.
So fantastic session and in the end the motor spun and regenned beautifully - Thanks guys it was fun
I would like to get started with this.
Before I have an adapter board made, does anyone have a spare one he wants to sell?
Hello everyone. Has anyone else started a Gen1 inverter with an Exanos adapter ? The development is interesting , but in my opinion undeservedly forgotten. With the parameters of the Ekhanes, nothing has worked for me yet (please share information about who started the inverter with this adapter.
- Romale
- Has thanked: 214 times
- Been thanked: 49 times
I made 5 such adapters, but could not launch them. Constant error
evil neodymium
- Romale
new information!
I can run this adapter. tomorrow I will search for the corner and I hope it will work as it should. after that, I will be able to test the inverter on my buggy from a voltage of 130 volts (the gen2 inverter accelerates it from this voltage to 105 km/h)
evil neodymium
Nice! did you find udc or any of the desat/error signals?
- Romale
hello.
No, I bit off the desat pin.
the victory is not yet complete. it is not possible to find the syncofs, the engine spins itself, it is worth touching the accelerator and stops only with the stop inverter command. pinswap = 4, current sensors 1.68 (if the current sensors are set to a negative value, then there is always an overcurrent)
evil neodymium
- InductiveJon
Spent some time working with this board recently and wanted to add a few things:
CN3-12 is indeed the UDC signal. It needs to be pulled up to 5V.
CN3-14 which is connected to CN6-1 on the adapter board is not populated on my inverter harness.
CN6-3 Is connected to the inverter chassis via one of the board mounts
Still working on the desat but it looks like it goes to 2.5V on CN3-16,8,6. I haven't been able to get anything out of pin 4 or 13.
Got the board working using the same settings described above - pinswap = 2, negative current sensor gains.
We have made a prototype bracket which lowers the board and resolves the clearance issue with the cover.
