Furnished with a pair of new matching DC contactors with the correct 15.3 ohm coil impedance; this impedance value is needed to keep the LIM happy in a non-BMW installation, though there are workarounds if you need to control higher-capacity contactors (see Wiki: https://openinverter.org/wiki/BMW_I3_Fa ... LIM_Module).
Furnished with new matching connector shells/terminals/weather grommets for connectors 1B, 2B, and 4B (3B is for CHAdeMO units only, which this unit will not interface with).
Pics below show with the PCB removed to illustrate no water damage -- a common failure issue with used units.
As I have not used this unit personally, I cannot warranty it, but it appears pristine for a pull.
Listed on eBay:
https://www.ebay.com/itm/305000804058
If shipping outside the US is desired, please purchase via eBay; buyers shipping within the US can purchase directly from me, and take a 5% discount.
[Pending] BMW i3 LIM + connectors + contactors [SOLD]
- asavage
- Has thanked: 279 times
- Been thanked: 103 times
