The SuperYacht BMW E65 7 Series
Kevin Sharpe
Been thanked: 8 times
Re: The SuperYacht BMW E65 7 Series
Post by Kevin Sharpe »
The HV Junction box being prepared for installation (note the ISA shunt which will play an important role in conversions going forward) 8-)
xp677
Been thanked: 15 times
Post by xp677 »
What are the red isolators that are mounting the fuses? I'm looking for a solution to this at the moment .
Has thanked: 11 times
Been thanked: 345 times
Had a hell of a time finding these.
https://www.amazon.co.uk/gp/product/B07 ... UTF8&psc=1
mfox
Post by mfox »
Great:D , ABS printing parts have not enough isolation ?
bulletbug
Post by bulletbug »
I found a variety of choices using the search terms "Buss Bar insulators". Here's a link to amazon.com https://www.amazon.com/LBY-Busbar-Insul ... B078TDD4X6
EVPanda
Post by EVPanda »
I like the High voltage junction box, do you have a part number for that?
Kevin Sharpe
EVPanda wrote: Fri Feb 21, 2020 4:12 pm I like the High voltage junction box, do you have a part number for that?
It's a generic plastic box that was purchased from a local electronics store...
Kevin Sharpe
mfox wrote: Fri Feb 21, 2020 10:18 am Great:D , ABS printing parts have not enough isolation ?
Why not try printing some and tell us how you get on ;)
zippy500
Has thanked: 76 times
Post by zippy500 »
Google search : IP65 plastic enclosure
I like the ones with the clear lids :)
mfox
Post by mfox »
Kevin Sharpe wrote: Fri Feb 21, 2020 6:28 pm
I will, but when I come to this part :D
Lots of wiring and component mounting done in the Bexus.
mattndex@gmail.com
Post by mattndex@gmail.com »
Is there a chance of you posting a schematic of how the high voltage junction box is wired.
xp677
Post by xp677 »
Jack Bauer wrote: Fri Feb 21, 2020 7:44 am Had a hell of a time finding these.
That's awesome, many thanks. Some more digging and the best Google term seems to be "stand off insulator".
I've currently resorted to cutting out big chunks out of whatever my fuses were originally mounted to - these insulators are a much better solution!
It's funny how similar our projects have turned out - I'm also using a Tesla Gen3 charger in the same location, but I've gutted the end of it that has the supercharger PCB/contactors and am using that as the junction box for my 320V bus. I'm also using the TRW PAS pump, and it looks like the same vacuum pump.
Bentto
Post by Bentto »
xp677 wrote: Sun Feb 23, 2020 4:12 pm
Do you have more info on that (or pics)? That is a very good solution to make everthing appear OEM to evade the EMC testing when converting the car from ICE to EV with the authorities.
xp677
Post by xp677 »
I have not published information on that yet. And now I feel that doing so may be a bad idea. I do not wish to publish Information which would be used explicitly to circumvent such testing.
However the procedure is as described. Remove the parts which you do not need and replace with those that you do.
It looks like Damien has kept his charger intact, so this discussion is not relevant in this thread.
Bentto
Post by Bentto »
xp677 wrote: Tue Feb 25, 2020 11:55 pm I have not published information on that yet. And now I feel that doing so may be a bad idea. I do not wish to publish Information which would be used explicitly to circumvent such testing.
Hm, that is indeed a good point. Thanks for the reply anyway :)
Kevin Sharpe
Top balancing the test battery today... here's the rear pack 😀
Kevin Sharpe
mattndex@gmail.com wrote: Sun Feb 23, 2020 2:49 pm Is there a chance of you posting a schematic of how the high voltage junction box is wired.
The participants on next weeks course are building a HVJB for the Grey Goose project. It will be very similar to that used on BEXUS. I'll ask them to document the build and post details in that thread :)
Front of the car all back together. Next up wiring in the V2 VCU with Wifi and ISA Shunt interface.
V2 VCU and isa can shunt up and running in the bexus. VCU now controlling precharge, startup and shutdown as well as hv control during charging. WiFi interface works perfectly.
slow67
Post by slow67 »
RE3Rotor wrote: Wed Feb 12, 2020 11:05 pm I did notice mine has 2 drive positions on my gearbox. I would love to know if it is as easy as just connecting the shift lever so I can manually switch to the second location.
It may be possible to wire it up this way. Ive done it for other electronics transmissions in the past.
Weigh in for the GS450H transmission.
Sloth
Post by Sloth »
Oops, I'm waiting for the gearbox to be delivered, I need a crane to move it ...
mdrobnak
Post by mdrobnak »
Jack Bauer wrote: Thu Mar 05, 2020 6:35 pm
Nice! Definitely great progress.
I heard you say "that's interesting" but couldn't make out what you were referring to. :lol: Everything working as expected so far?
-Matt
