Configuration Files
Jump to navigation
Jump to search
This page has been superseded by the openinverter Parameter Database
This page contains a selection of known motor and inverter configurations. To use a configuration, copy and paste the respective highlighted json code and save it into a file that ends in .json.
To add a new configuration, log in (same as forum login) and use the "Edit source" tab above. See the existing configurations as a template.
E-Polo
- Motor: Lenze MFEMAXX 360Vac@120Hz
- DC voltage: 500V
"boost": 2200,
"fweak": 100,
"fconst": 160,
"udcnom": 500,
"fslipmin": 1.5,
"fslipmax": 3.59,
"fslipconstmax": 6,
"polepairs": 2,
"respolepairs": 1,
"encmode": 0,
"fmin": 0.5,
"fmax": 220,
"numimp": 30,
"dirchrpm": 100,
"dirmode": 1,
"syncofs": 0,
"snsm": 12,
"pwmfrq": 1,
"pwmpol": 0,
"deadtime": 63,
"ocurlim": 250,
"minpulse": 1000,
"il1gain": 4.5,
"il2gain": 4.5,
"udcgain": 5.56,
"udcofs": 0,
"udclim": 1000,
"snshs": 0,
"bmslimhigh": 60,
"bmslimlow": -40,
"udcmin": 400,
"udcmax": 525,
"iacmax": 190,
"idcmax": 110,
"idcmin": -40,
"throtmax": 100,
"ifltrise": 12,
"ifltfall": 2,
"chargemode": 3,
"chargecur": 12,
"chargekp": 10,
"chargeflt": 10,
"chargemax": 60,
"potmin": 12,
"potmax": 4095,
"pot2min": 602,
"pot2max": 3100,
"potmode": 0,
"throtramp": 20,
"throtramprpm": 20000,
"ampmin": 10,
"slipstart": 50,
"brknompedal": -77,
"brkpedalramp": 1,
"brknom": 20,
"brkmax": -50,
"brkrampstr": 15,
"brkout": -50,
"idlespeed": 300,
"idlethrotlim": 50,
"idlemode": 2,
"speedkp": 0.15,
"speedflt": 5,
"cruisemode": 1,
"udcsw": 460,
"udcswbuck": 540,
"tripmode": 0,
"pwmfunc": 0,
"pwmgain": 45,
"pwmofs": -2100,
"canspeed": 0,
"canperiod": 0,
DMOC with Siemens 1PV5135
"boost": "3600",
"fweak": "140",
"fpconst": "400",
"fslipmin": "1.68",
"fslipmax": "3.5",
"polepairs": "2",
"ampmin": "5",
"encflt": "4",
"fmin": "0.5",
"fmax": "200",
"pwmfrq": "1",
"pwmpol": "0",
"deadtime": "50",
"numimp": "64",
"potmin": "640",
"potmax": "3850",
"pot2min": "4095",
"pot2max": "4095",
"idlespeed": "-100",
"idlethrotlim": "50",
"idlemode": "0",
"speedkp": "0.12",
"speedflt": "1",
"cruisemode": "0",
"bmslimhigh": "50",
"bmslimlow": "-1",
"brknompedal": "-25",
"brknom": "1",
"brkmax": "1",
"brkrampstr": "10",
"udcsw": "390",
"udcmin": "150",
"udcmax": "520",
"udclim": "1000",
"ocurlim": "-400",
"minpulse": "1000",
"il1gain": "-4.65",
"il2gain": "-4.65",
"udcgain": "3.78",
"pwmfunc": "0",
"pwmgain": "100",
"pwmofs": "0",
"speedgain": "6000",
"snshs": "0",
"snsm": "3",
"fslipspnt": "-1.68",
Fleck Elektroauto ACIM AKOE 132 2.2.100024 28KW motor custom wound for 180VRMS www.fleck-elektroauto.de
"boost": 7000,
"fweak": 150,
"udcnom": 325,
"fpconst": 75,
"fslipmin": 3,
"fslipmax": 6.8,
"polepairs": 2,
"encflt": 3,
"encmode": 1,
"fmin": 0,
"fmax": 240,
"imax": 400,
"numimp": 64,
"dirchrpm": 100,
"syncofs": 0,
"snsm": 13,
"pwmfrq": 1,
"pwmpol": 0,
"deadtime": 185,
"ocurlim": -700,
"tripmode": 0,
"minpulse": 1000,
"il1gain": -2,
"il2gain": -2,
"udcgain": 3,
"udcofs": 0,
"udclim": 430,
"snshs": 0,
"chargemode": 0,
"chargecur": 0,
"chargekp": 80,
"chargeflt": 8,
"chargemax": 90,
"potmin": 980,
"potmax": 4090,
"pot2min": 1850,
"pot2max": 4090,
"potmode": 0,
"throtramp": 10,
"throtramprpm": 2000,
"ampmin": 21,
"slipstart": 50,
"brknompedal": -30,
"brkpedalramp": 1,
"brknom": 0,
"brkmax": 25,
"brkrampstr": 50,
"brkout": -1,
"idlespeed": 500,
"idlethrotlim": 16,
"idlemode": 2,
"speedkp": 0.18,
"speedflt": 5,
"cruisemode": 0,
"bmslimhigh": 60,
"bmslimlow": -1,
"udcmin": 305,
"udcmax": 420,
"udcsw": 320,
"udcswbuck": 360,
"pwmfunc": 0,
"pwmgain": -12,
"pwmofs": 1620,
"canspeed": 0,
"canperiod": 0,
"ifltrise": 10,
"ifltfall": 3,
"fslipspnt": 0,
"ampnom": 0
Toyota Prius Gen2 Inverter
Only inverter parameters
"pwmfrq": 2,
"pwmpol": 0,
"deadtime": 0,
"ocurlim": 100,
"minpulse": 1000,
"il1gain": 3.18,
"il2gain": 3.18,
"udcgain": 3.78,
"udcofs": 327,
"udclim": 540,
"snshs": 0
