I'm thinking about converting one of my two Midas Gold Mk3 kit cars to EV. Its been stored up for a while so seen better days. Currently runs on Austin A series engined metro running gear front and rear with the hydrogas spheres removed and replaced with coil spring suspension and rear subframe cut down to make a beam axle.
The car is a hatchback with quite a bit of space in the back to put in batteries (plus longtitudinal underslung tank inside the rear subframe area).
I noted a few recent mini conversions using the mitsubishi outlander phev rear drive train and rear inverter so Im going to attempt to go down that route and accumulated/ordered a few outlander parts.
rear differential unit
rear inverter
inverter converter/charger
pair of refurbed driveshafts to tube mock up for
type 1 charger port (for now)
zombieverter fully built to save errors. I'm fine with having built ECUs such as megasquirt in the past but my eyesight is getting poor so going the lazy route on that.
VAG throttle pedal off a SEAT
Someone has suggested the BMW sp41 battery so looking at that as an option over the mitsubishi battery pack.
Looking to keep it as front wheel drive. Interestingly the existing A series power output is around 94 bhp/70kw so a good balanced like for like power output from the mitsubishi outlander I think,
I have a spare metro subframe so will have a look at the initial diff unit mounting as a sandbox and work from there. Things will get a bit more difficult after that as the engine bay isnt massive, probably similar to a classic mini.
Will be a slow burner but will try and pop some stuff on here.
