Nissan Leaf Gen3 inverter
Re: Nissan Leaf Gen3 inverter
So I've managed to replay some can messages to the Leaf Stack and OMG I scared the hell out of myself LOL, It just took off, luckily I only played replayed for a short time and at 100ms, I realised that sending the same messages for 5ms will just prolong the playback, which can make things very intense. Anyways,
Question,
Is it possible to convert the throttle CAN messages from a BMW to the LEAF's EV CAN bus? And how do I even start please?
As always appreciate the gurus on the forum.
Question,
- Bratitude
- Has thanked: 222 times
- Been thanked: 413 times
yes. zombiverter or some board working as a canbus man in the middle.
the basic throttle messages are the same for gen1, 2 and 3 leaf inverters.
Thanks Bratitude, I thought of it, but just wondering weather it’s a bit of an overkill considering is’s only going to be specific used for transferring/converting CAN messages. I’m not aware of any man-in-the middle boards, which actually make sense, any any ideas on any particular ones that are already around? I get the feeling there will be one in the forum, guess I need to drill through an see. But any ideas would be appreciated.
Thanks again.
- Bratitude
a Arduino with a can interface. due or teensy with a can transiver. arber has a nice can board based around a due i think
So, I thought I do some testing with an Arduino Due on the Gen 3 Stack, I’ve programmed the Arduino Due and got things connected.
Question: Is it possible to use the Olimex ESP 32 Wi-Fi module to access the data on the Due?
Would it be transferring information over to the open inverter web GUI?
I’ve connected the Olimex to pin 16 and 17 in the Due, but don’t seem to get anything coming through. Olimex is flashing as if it’s receiving data, however there is no info on the Web interface.
Any ideas?
Any ideas?
Hi All
Just a quick update on the process of operating this leaf. Got the it it all spinning using the Due, still working on the Throttle pedal setup. Got a little video here check it out
stinkydiver73
Hi! I try to spin up a gen3 inverter+motor with 320VDC from the mains for testing. I have no wire harness and the pinout in the doc don't tell the polarities of the resolver signals. So I started try all the combinations (i think 8 is enough). The first two did nothing, with the 3. the shaft tried rotating back and forwrad. Rotated one more wirepair (4. combination). It's worked, but the potentiometer input was noisy, the rotation was not smooth. After few seconds the mains breaker went off, it was scary. Added a filter capacitor to the analog input, the signal is much smoother, but the motor no longer starts. I'm afraid I killed the inverter, probably overvoltage due to the sudden unintended breaks. But the system still works as a DC generator, on rotating the shaft with hand, there is 5-6VDC, same as before, the IGBT-s are no short circuits. The board still communicating, start sending the 0x1DA, 0x120, 0x55a messages as soon I give 12V on the power ON pin, no need to send any can command. I watch everything over wifi with savvycan , there is an esp32 devboard with the ESP32RET firmware on the can bus. I sending the commands with an stm32bluepill, I ported the arduino code, I will upload it.
Is it possible to read trouble codes from the inverter? It's not responding to the UDS scan for me.
Ive been enjoying 6 months or so with the 145kw setting on my 24kwh leaf, semislick wider front tyres have helped big time with traction. I have the aluminium panel version leaf which may have been on the JDM veraions only ? i recently removed the rear seats, they are heavy at 22kg. I managed just on 1400kg on the weigh bridge, so its fairly quick now, managed a low 6 seconds to 60mph. Huge difference from stock. The throttle map is beatiful and responsive. Battery so far hasnt been concerned running higher demand.
So far no one has managed to break the 400a bracket,
Hunting through on kavaser i noticed X1DB then LB_Current min is -400 , the only reference i could find to that golden number.
Dala did write some code to fool the VCM into seeing 40kw less been drawn from the battery, but this threw a full error when reaching 400a.
From what i am told the e+ will only deliver 180kw over 70kmh or so.
180kw will turn a light leaf into an animal,
If you want a cheap and fair quality board for this in the future try out these: https://github.com/EliasKotlyar/Canfilter
You can pick them up for $15 from the usual Chinese outlets. STM32F105, dual can with transceivers on-board, 12v input, 2 GPIO and 1 UART. They are sold as ODO tampering devices.
Round 22 pin inverter connectors can be purchased on AliExpress, they are used for CVT transmissions on many Nissan vehicles.
Search for Yazaki part number 7283-8750-30 or just search for "Nissan stepless CVT connector"...
The one I bought in UK was £11 shipped from China via AliExpress and came with full set of wires already installed all the same colour as it happens but I can work with that.
I recently started project to convert Lotus Elise S1 with EM57 motor, 5SA0A inverter, probably CATL 52kwh pack and BMW i3 LIM CCS charging.
So far I have inverter and motor linked to Arduino and Leaf Spy Pro... I have set resolver offset and mostly cleared DTC's. Having some trouble clearing P318E, P3197 and U1000 DTC's.
Has anyone got any tip s on which CAN ID's I need to send total? I am attempting to send 50B, 11A, 1D4, 3B8 and 5EB currently.
Possibly I am incorrectly composing the messages? This is my first attempt at writing Arduino code, working with electric motors etc... I am a real newbie!
Update, I found error in my code now I have removed P3197. But still got others!
Update No.2, Now also sending 4B9 this has managed to remove P318E DTC form list. Now left with P31AD, U1000 and P0A2D (this one probably my dodgy wiring LoL)
Update No.3, Added send of 1F2. Mostly no more DTC's. However it looks like noise is creeping in causing intermittent U1000 and eventually P31AD. Need to add shielding to resolver wiring this may help. Didn't have shielding to hand when making up test wiring harness.
Update No.4, Motor spinning after some re-wiring of dodgy connections to resolver! Gearbox adaptor plate CAD in progress.
Thanks in advance of any input,
Jon
Jon
- Has thanked: 266 times
- Been thanked: 186 times
I'm continuing kelju's work on the openinverter adapter board for the gen 3 leaf inverter. It's mostly done but there are a few things that I'd like to verify before making some boards. I do not have a gen 3 inverter to check these things on, looking for some help with this.
Info is here currently,
viewtopic.php?p=61876#p61876
If anyone is willing to help with confirming pin out or sharing images of the inverter controls input harness it would be appreciated!
viewtopic.php?p=62196#p62196
Embraer145
- Has thanked: 3 times
Anyone use this engine with Zombie Verter? I'm running into issues with Firmware only being for Gen1, not the Gen2
- Has thanked: 455 times
- Been thanked: 1771 times
It runs with any generation
ted.walsh
- Has thanked: 20 times
- Been thanked: 20 times
I’d be interested to hear if ur still experiencing the same or have worked round it?Embraer145 wrote: ↑Thu Nov 09, 2023 4:38 am Anyone use this engine with Zombie Verter? I'm running into issues with Firmware only being for Gen1, not the Gen2
I’m having a problem where after a couple of miles the inverter slows me down to a crawl for a min or two and then I can accelerate hard again for another couple of miles.
ideas anyone?
That sounds like a cooling issue
Replying here to not clutter up the gen 3 development thread.
Have you logged temps while driving & accelerating? What's that looking like under normal driving & hard acceleration?
Do you have decent coolant flow / airflow for the radiator / cooling fan to kick on when needed?
ted.walsh
No, I havnt done any logging yet but an hoping get some can and zombie logs at our next race day which is about the only time I can test things properly with it being fitted to a boat.
I hear the comment about cooling but the stack is being fed from the stock race raw water pump that pumps water out of the lake , round the inverter, the motor then over the side. the coolant isn't 12deg so I'm sorta struggling with the idea it could overheat.
does anyone know if the inverter is 'expecting' a temp rise after a certain time? the problem its certainly very predictable in its execution.
Strange things happen. From looking at your pictures it's oriented 90° to how it would normally be, right?
What are the chances that an air pocket ends up stuck up top?
I'd be surprised if cool temps threw a limp mode.
ted.walsh
Yes, I have pondered that as well. putting in an air bleed at the now 'top' of the IGBT chamber, only a small pipe would be needed: the thing being there's quite a lot of water getting forced through the chamber, its not that itll be 'dry' at any point, mebbe an odd large bubble if I skip out or something but still cold coolant running over the vanes on the back of the IGBTs...
ted.walsh
As a further consideration, clearly my project isn't using a PDM, I don't need on board charging at granny rates and the 12v / 24v systems are supplied from on board lead acid batteries.
This made me think, does anyone run their 160kw without a PDM ? and what chance is there that im missing an important can message out of the PDM that is upsetting the Inverter?
all conjecture and epiphanies welcome!
Bringing this back from the dead- I'm about to embark on the 160kW upgrade to a 2015 LEAF. Trying to keep the stock PDM/VCM with the dala bridge. The one thing I haven't been able to find any definitive info on is the temp sensor on the ZE1; dala glosses over this in his github. Searching here and elsewhere on the web I get different results on whether or not it will be happy with nothing connected.
Will the ZE1 inverter be unhappy without anything connected? It's marked as an input on the wiring diagram, so I would assume this would cause an issue. Are you guys that are using a Nissan VCM spoofing it with a resistor, or wiring in a sensor? I am not sure but I'm thinking the AZE0 VCM/PDM will be happy as they are likely getting this data from somewhere else, unless it was in the original inverter and being converted directly to CAN.
TIA. If anyone here is interested I can post up results. Dala's github is awesome but I'm not finding many folks who have done the same thing.
I have no idea if the inverter cares about the coolant sensor, maybe just info for the VCU.
Just measured the coolant sensor on a 2019 110kW inverter 3.17kohms in ~15degC ambient. I would add a ~3k resistor to simulate a working sensor just in case.
link to some testing I did on my system for your info.
viewtopic.php?p=69184#p69184
I think dala covers it quick in his YouTube video of the conversation.
I can't imagine it's happy without the sensor.
