Digging through the electronics modules from the battery, I found the precharge circuit. I found it interesting because it uses PTC thermistors.
The PTC's are C1412by TDK rated for 620V and 120ohm. The relay is V23700-C0001-A408 made by TE Connectivity 450V and 20A.
The PTC's are arranged in 2S7P making it a 34.3 ohm precharge resistor.
If there is a short on the HV when precharging the PTC's will dissipate 4700W @400V 11.7A. This will heat up the PTC's real quick, and that will lower the current. A normal resistor will not survive for long in this situation.
Pugeot E-208, Corsa E, etc. battery pack.
- manny
- Has thanked: 38 times
- Been thanked: 125 times
Re: Pugeot E-208, Corsa E, etc. battery pack.
PTC_ICL_Leaded_Disks_C1412_C1451_C75-525567.pdf- (319.85 KiB) Downloaded 497 times
- PSA battery (50kWh)
- Zombie VCU
- Has thanked: 264 times
- Been thanked: 717 times
EDIT: turned out with the closing loop I used I put red to white and black to black. Without realising when I wired it I assumed all TxN and RxN would be on same row but the flip TxN to second row. So with that fixed and wiring check I get 0x21 response
I am really struggling to get this functioning on the bench. Can someone please give me some insight into how to "terminate" the bus with these modules?
I have the M3/MAX BMS from Damien, https://github.com/damienmaguire/Tesla- ... M32_M3_Bms
I am spitting out the SPI as per data sheet and doing the UART chain init, however no RX Status 0x21 is recieved I keep just getting 0x11.
I have made sure SPI works by requesting other register info.
Could someone scope a working RX and TX pair for me to check if the signal is shaped properly.
I can even see the signal going into the module coming out. So in on pins 1+7 and out is 6+12.
Got it now to initialize the string and read out the single module voltages and temp registers.
Currently have a slight issue with the temp register so will dig through others example code to find what I am doing wrong.
Likely due to this:
Edit: I am using the Hyndai/KAI Arduino base code to port from.
Anyone written code to read the PSA modules? Otherwise I will write the code to do it and publish it to Damiens github once i got all read outs working.
Likely due to this:
This thread is a goldmine of information.
