Nissan Leaf BMS Checksums
WillItBoost
Post by WillItBoost »
Could be a long shot, but has anyone tried modifying the stock BMS firmware?
I've modified the stock firmware and have a consult3 to flash it however I'm a little stuck calculating the two checksums located at 5FFFE:5FFFF and 3E000:3E003. I've got the 3E004:3E007 checksum sorted (3NA0C BMS)
I'm trying to modify the can messages to work with some of the more common off-grid inverters - without having to use a can bridge or battery emulator.
ginetto
Has thanked: 13 times
Been thanked: 9 times
Re: Nissan Leaf BMS Checksums
Post by ginetto »
