I am looking at converting a 10 mtr motorhome with a V10 ICE on LPG and petrol coupled to a 6 sp Alison Auto.
I live in Australia, the place with a lot of nothing between major centres, so recharging facilities will be limited to the major highways for the foreseeable future, along with LPG being either not available or as expensive as petrol ... or worse .... and some regions limited to "opal" fuel https://en.wikipedia.org/wiki/Opal_(fue ... %20seeking. for those who are looking a tad confused already.
My idea was to use the GS450h inverter with the "ZombieVerter" feeding into the 6 sp Alison auto direct (no converter) and tuning the GS450 inverter/ZombieVerter to produce no more than the V10 that is connected to it at the moment.
With the V6 still connected, a modified starter motor to pull the starter gear into the ring gear on the flywheel (yes, it actually has one) to lock the input shaft for full EV mode, but unlock the starter gear from the ring gear to enable the V6 to be used as a drive unit for MG1 to charge the battery when needed and the added compression drag to combine with the regen from MG 1 and MG2 for regen braking .......
Clearly, I'm missing something important because it sounds too easy (in my head) to implement, so I'm looking to the wise folk here to tell me where I've missed the vital bits that make my idea impractical .....
T1 Terry
