How to setup a PC to edit and compile a bin that can be uploaded to the VCU or Mini board Topic is solved
ted.walsh
Has thanked: 20 times
Been thanked: 20 times
Post by ted.walsh »
Allright, I've hacked around with various code formats over the years, BASIC, DOS, BATCH, VB et al, I can probably hold my own at a Noobs convention and hack my way across the open plains of coding but FFS what development environment, what programme do i need to install on my PC to hack about with the source off Damiens GIT, compile it and then upload it to the VCU etc?. Can anyone just give me PDF on how to endanger myself so I can get on with it? please...
Has thanked: 480 times
Been thanked: 137 times
Re: How to setup a PC to edit and compile a bin that can be uploaded to the VCU or Mini board
Post by Jacobsmess »
I'm no coder, and someone will be along shortly to correct me but I believe it's all c/c++. Arduino IDE or similar should be all you need to look at the binaries (I think). Otherwise, the code is completely uploaded by the web interface, no other software required.
Also, please do not endanger yourself or anyone else (pot calling the kettle black here perhaps!)
Has thanked: 89 times
Been thanked: 481 times
https://github.com/crasbe/ZombieBuild will help with the VCU firmware building and also OI. Be aware and changes you make could result in unexpected behaviour, obviously.
ted.walsh
Post by ted.walsh »
Bigpie wrote: Thu Apr 18, 2024 6:41 am https://github.com/crasbe/ZombieBuild will help with the VCU firmware building and also OI. Be aware and changes you make could result in unexpected behaviour, obviously.
Thanks for your help on this BP,
can you tell me where I might find a source of stdint.h and its associated mates? there appear to be pointers in the STM32 making ref and throwing errors?
peterdiffey
Has thanked: 6 times
Been thanked: 6 times
Post by peterdiffey »
Hi Ted,
I just did my first Openinverter compile this very afternoon. From knowing nothing to firmware loaded took less that 1 hour.
I am assuming the VCU has a web interface, that allows you to upload the new firmware.
If you have a Raspberry Pi, it's a doddle
A very quick howto - assuming you have a raspberry pi with Raspian installed. and are doing an OpenInverter build
All done from the command line
sudo apt-get install git
mkdir zombbieverter
cd zombbieverter/
git clone https://github.com/damienmaguire/Stm32-vcu
cd Stm32-vcu/
sudo apt-get install *arm-none*
make get-deps
## Do all yer dodgy hacks and then
make
ls -al stm32_vcu.bin ## check for a sensible date on the new file ie a few secs ago
The first compile took about 2 minutes on a RPI 5, subsequent small code changes took about 3 secs.
getting it to the VCU board can be abit of a faff, I use a USB stick, plug it in to the RPi
sudo mkdir /z
dmesg | grep sd ## and note the last device - probably sda
sudo mount /dev/sda1 /z
cp stm32_vcu.bin /z
ls /z ## check it is really there
sudo umount /z ## to avoid possibly trashing the USB stick when you unplug it
Now you can plug in the USB stick to your laptop and upload the file to your VCU.
I was very surprised how easy it was, I can now get HV battery voltage out of the VCU via Canbus
Pete
Pete
ted.walsh
Post by ted.walsh »
I just went through this again on a new laptop and found a couple of things that would make it easier for future installs & big thanks for setting up the Git and links as they are very helpful.
Can I suggest the following.
your link to the windows docker installer doesn't have a windows intel version listed (yeah yeah yeah) however it can be found here https://docs.docker.com/desktop/install ... s-install/
add the instruction to "download ZIP" from the Git 'Code', unzip the contents into what will become the projects base folder and then run the SetupContainer.bat
thanks again.
TED
crasbe
Has thanked: 53 times
Been thanked: 163 times
Post by crasbe »
"AMD64" is the version for all x86_64 processors (including Intel), so the link to the Getting Started page is correct:
I could add the instructions how to download the zip archive, however I did not anticipate that that would be an issue.
The README is already updated.
