Emergency Stop Wiring
modellfan
Been thanked: 45 times
Re: Emergency Stop Wiring
Post by modellfan »
Just do be clear, that I understood you correctly.
Wouldn't be it better to have a poll down e.g. 2kohms mounted inside the inverter , so that I externaly just need to interrupt the line?
Further more I am a bit worried, as it is the 5V supply line of the micor , then running in parallel to the HV cables, to get disturbance.
Has thanked: 455 times
Been thanked: 1771 times
You could pull it up internally with 1k or so and pull it down externally for emergency stop
modellfan
Post by modellfan »
Like shown in the picture? What do you think of cutting the rs232 traces of and connecting the HVIL emergency stop except?
modellfan
Post by modellfan »
I know chances are quite small , but how can I still protect the motor from a loose cable potentially destroying the sdu ?
EV_Builder
Post by EV_Builder »
Which cable? and if the chance is small why do it if the result is acceptable to the relationship of the occurrence?
