Any's volunteers
Free Kona 64kwh BMS for reverse engineering
- Zapatero
- Has thanked: 25 times
- Been thanked: 43 times
I have the BMS including the slave modules and the wiring harness. I'd like to donate it to someone who wants to play around with it.
Any's volunteers
Any's volunteers
paaa
- Has thanked: 2 times
- Been thanked: 13 times
Re: Free Kona 64kwh BMS for reverse engineering
If no-one else takes it it I will , would like to workout if it's possible to run. A kona pack with less than the full number of modules.
I'm interested, already using re-use kona modules to build affordable electric propulsion kits for small boats. Would be great to investigate the possibilities of re-using (some of) the bms components too.
mattiasclaesson
Still available? Was looking for a way to safely test the integration of the battery emulator project support for Hyundai/Kia batteries.
https://github.com/dalathegreat/BYD-Bat ... -For-Gen24
