CCS Plug
EV_Builder
CCS Plug
Post by EV_Builder »
Does somebody have acces to the actual plug?
Can you share some pictures and dimensions?
What i need is a small sketch of the debt/height of the part that tries to enter the old Filler spot but on sport cars its not allot of room there...
p.s. I bought the socket from an ID3 including the wiring etc
mikeselectricstuff
Re: CCS Plug
Post by mikeselectricstuff »
This is a Duosida plug - it's possible that others (e.g. liquid cooled) might be bigger
EV_Builder
Re: CCS Plug
I found this one!
So i guess the standard is 100x70mm...
it' s the DUOSIDA :D :P
Damien can you confirm these dimensions? i saw one in one of your movies... :lol: ;)
brainstorm
Re: CCS Plug
Post by brainstorm »
If one were to 3D print that plug (like other folks have done w/ Chademo:
where would one be able to source the internal metallic lugs and how are they welded (pressed) to which AWG cables?
Has thanked: 264 times
Been thanked: 717 times
Re: CCS Plug
brainstorm
Re: CCS Plug
Yeah, I've seen some models already, i.e: https://grabcad.com/library/tag/ccs
What I'm interested is about the female metal lugs on the CCS2 gun: are they commercially available at all (i.e as spares?). I believe those lugs are called "contact tubes" according to IEC 62196.
I'd really like to avoid grinding copper rods and doing nyckel electrolysis to avoid corrosion and whatnot, seems quite labor intensive:
CCSknowitall
Been thanked: 29 times
Re: CCS Plug
Post by CCSknowitall »
Some commercial cables do have replaceable contacts. They're not exactly hobbyist level prices, however.
Duosida plugs are relatively inexpensive on Aliexpress. I would suggest getting something with a cable though.
