Inverter Firmware v4.64.R
Has thanked: 461 times
Been thanked: 1780 times
I released a new version:
https://github.com/jsphuebner/stm32-sin ... ag/v4.64.R
  • Added MTPA and field weakening
  • Added syncadv parameter to compensate for phase lag
  • Disabled user_pwm code on BluePill
This is the first release that actively supports field weakening for synchronous motors and thus high speed operation.
Transitioning to regen is still a bit rough though.
johnspark
Has thanked: 59 times
Been thanked: 48 times
Re: Inverter Firmware v4.64.R
Post by johnspark »
So will this be ok with Prius motors?
Has thanked: 148 times
Been thanked: 370 times
johu wrote: Thu Nov 07, 2019 8:45 pm Transitioning to regen is still a bit rough though.
But we can turn regen off, cant we? I mean set it to 0 and it will produce no regen?
johnspark wrote: Thu Nov 07, 2019 9:01 pm So will this be ok with Prius motors?
Yes
arber333 wrote: Thu Nov 07, 2019 10:32 pm But we can turn regen off, cant we? I mean set it to 0 and it will produce no regen?
And yes :)
yaroslav
Has thanked: 14 times
Post by yaroslav »
Then I have such a question how to properly put this firmware on BluePill, after I load it and feed the power the engine starts to start itself without pressing the gas pedal?
