How goes your progress ?
i would be slightly concerned with the high voltage wiring. have two split packs in parallel such a distance apart could possibly cause uneven loading on high load made worse when the battery try to balance afterwards. having wiring live outside times when the car isnt being used could also be dangerous if the wiring was to be damaged.
looking forward to seeing some more pics
