At first I have to say sorry for my english, it is not the best... place ask, when I write strange things
What happend so far:
I bought a V6 Logic Board from Johannes and build it into a SDU.
I wired everything for a Benchtest with 2 Model S Batterymoduls (47Vdc).
I had a little bit trouble with the Precharge wiring and it takes a bit time until I noticed that the boost have to be higher for the 47V.
But finally the SDU was running and I was very happy.
I started welding a frame to put the SDU into my VW T3 bus. That tooks a lot of time - 3 months more or less.
Yesterday I wanted to test the SDU in the car, without the driveshafts!
I took 6 Batterymoduls with 140Vdc and changed all necessary parameters.
Now I can switch it on and precharge works.
For changing the mode from "waitstart" to "run" I puch my Startbutton and I can hear, that the main contactors switch on and immediately off again.
Then I have an overcurrent error...
I found this Solution:
viewtopic.php?f=10&t=1623
and the troubleshooting in the wiki, but it does not helped me so far.
What I tried to fix the Problem:
Changed ocurlim to -1200A
On Conn5 I tested fault A, B, C and HVLO: All 5V
I tried to test the voltage at R58 and R45. The Wiki says it should 1,65V.
My results: R45=0,33V and R58=3,30V
But does the troubleshooting count for th V6 SDU Board? Because the Wiki says the resistors are bottom right. The R58 is there, but the R45 is more or less in the center of the board. That irritates me.
I would be very happy, if somebody can help me with good ideas.
Another question: What is the different between HVLO and HVIL? Sorry, I am still learning.
Thanks in advance,
Ben
