Tesla SDU drop in board current gains [SOLVED]
- Peter
- Been thanked: 9 times
Hi Forum. Do I need to calibrate the current sensors in the latest drop on board? If the answer is ‘yes’ this I assume is with motor cables disconnected. Thanks. Peter
- Has thanked: 455 times
- Been thanked: 1771 times
Re: Tesla SDU drop in board current gains
It comes calibrated, hope you haven't loaded defaults.
- Peter
Hi Johannes. Thank you for your reply and help. Just in the process of re-assembling the inverter so thought to ask first, glad I did
Keep safe. Peter
Johaljaswant
Both contactor close first one on power on and second one at start signal.
With or without Hv Derate error current limit and also error throttle1.
But could be the possible reason.
Attached screenshot
Attached screenshot
Johaljaswant
Throttle1 issue is solve wiring problem.
Motor spin but still have currentlimit error.
Please advice any clue.
Using latest firmware? 4.96.R
Johaljaswant
Re: Tesla SDU drop in board current gains [SOLVED]
I update firmware and it’s work no more currentlimit error.
Thank you and Damien so much for providing great option for
EV conversions
I am average guy with basic knowledge but I done two conversion with yours logic boards And support
One with Tesla LDU and one with Tesla SDU.
Again thank you!
EV conversions
Again thank you!
That's what we want, very nice
Johaljaswant
1.Main contactor close at only UDCSW =0 while battery voltage is 365 V. If I put UDCSW =10 contactor does not close.
2. Tesla SDU Motor spin very fast when pedal just engaged . Pedal signal voltage is Fine 0.7 v to 3.8 v. So pedal does control speed.
Johaljaswant
Can you set udcnom=0 just to check.
Something is probably not right with your bus voltage measurement or precharge circuit
Johaljaswant
Did try with UDCNOM =0.
Motor does not spin.
No any error code store.
Main contactor engaged sound is different than before I’did not check precharge relay circuit yet.
Please advice
Please advice
Well, setting udcsw=0 on a HV pack will definitely weld your contactor and it will then sound different to say the least. Sorry I didn't catch that one before.
Johaljaswant
My car pre charge relay was gone. Change the pre charge relay.I test run, wheel up, on idle speed it is fine.
Also with pedal it run but still fast. But controlling the speed with pedal.
How I can make less aggressive .
My car has brake sensor as will. But car get ready Without pressing the brake,
It should be ready while brake on.
Please advice.
Attached parameters
Please advice.
Attached parameters
It is hard to control speed with the pedal, as the motor torque is controlled. Once the vehicle is on ground it will make more sense. If I understand correctly you only want the inverter to change to run mode when brake pedal is pressed?
Your parameters look ok but are different from standard. If you want to revert to standard parameters, look here: https://openinverter.org/parameters/view.html?id=15
Did your main contactor survive switching into a discharged capacitor?
Johaljaswant
Thank you ,I will try again with standard parameters.
Yes my main contactor survive ,also I confirm with multimeter, And Also sound fine now.
Yes I want my inverter should ready when brake pressed .
Thank you so much!
Thank you so much!
- mjc506
- Has thanked: 30 times
- Been thanked: 29 times
Have the +12v for your 'start' switch come from the brake light switch (assuming switched positive)?Johaljaswant wrote: ↑Sun Mar 07, 2021 2:49 pm Yes I want my inverter should ready when brake pressed .
Thank you so much!
Johaljaswant
Thank you!
I will make change to starting switch accordingly.
Thanks again for reply.
