Tesla Small Drive Unit Support Thread
- Been thanked: 87 times
Re: Tesla Small Drive Unit Support Thread
Firstly, if you purchased the board from me it will come with parameters loaded. If not here is the set I use :
https://github.com/damienmaguire/Tesla- ... s_SDU.json
Patrick Hagemann here
About two months ago I bought a board from you (built up and tested).
The values for maximum current etc. are set to 5000A, so I was careful if the other parameters are correct.
Thx for the help.
Thx for the help.
The current sensor used on the small drive unit is the Melexis MLX91209.
https://www.mouser.ie/ProductDetail/Mel ... 4jl%2Fc%3D
The 7.3mV/mT version.
Hi Guys
New here and not sure if there is diagram for the front and rear small drive controller plug wires.
Thanks in advance Conrad
- Kevin Sharpe
- Been thanked: 4 times
- Lee Malo
current sensors from the manufacturer
When replacing a current sensor does it need to be programed ? The manufacturer states the sensor is programmable . Is the current sensor a drop in and solder or does it need to be programed ? Here is a link to Mouser stating it is programable - https://www.mouser.com/ProductDetail/Me ... DN4jl%2Fc=
I'ts drop in, just make sure you have it in the correct orientation.
- Lee Malo
Are both current sensors oriented the same way ?
They do not need programming and yes they both go in the same way.
Cheers mate
What contactor and pre are everyone using?
Cheers Conrad
Cheers Conrad
Does anyone have a link for a contactor and fuse supplier for one of these.
Cheers CG
Cheers CG
So a quick announcement on board pricing and lead times. Of late I have been experiencing untold problems with delays and quality from my pcb builder. Some customers have been waiting months for boards which is unacceptable. I have been working to resolve this and am pleased to announce that I have a new pcb maker signed up. Boards will be machine assembled and undergo AOI. This will let me have boards in stock almost all the time reducing lead times to a matter of days and resolving a lot of quality problems. Bad news is a slight price increase on drive unit boards from 500 to 600 euros for built and tested. Bare pcb pricing remains the same.
I wonder if anyone knows the size of bolts for the small driveunits to fit each of the motorbrackets?
Alfa Romeo 147 with Tesla FDU and Kia soul pack
- Kevin Sharpe
We've been running some tests on the VW Bus project (here) using a ~200V Toyota Prius battery. The integrated contactors, pre-charge components, and safety disconnect make this a recommended test tool for anyone using the SDU in a project
- Has thanked: 103 times
- Been thanked: 216 times
Same as in the parameter thread.
No compensation for the voltage? Makes the drive unit quite laggy down low.
Just busted my current sensor and if you can't tell from my question then I'll say it explicitly. I'm a noob.
My replacement current sensors will be getting here in a couple of days. Do I just pull out the old sensors from the "goo" and drop the new ones in? or is there something more involved?
Thanks!
Thanks!
Yes they go back into the goo. Just be aware of the orientation mark on the device.
- Lee Malo
when I replaced the sensor I took a few pics . This is how the 2 sensors are oriented in that camel snot . lol
Lee
Lee
Thanks!
Got em in. Should we refill the void in the "camel snot" left from pulling out the old sensors? The new sensors seem pretty secure as is.
Recommend everyone update to the latest software release here :
https://github.com/jsphuebner/stm32-sine/releases
For Tesla use : https://github.com/jsphuebner/stm32-sin ... 2_sine.bin
Also read and try to understand the parameters before powering up :
https://openinverter.org/docs/index.htm ... rs,24.html
A lot of the most common questions have already been answered in the support threads so try the search function first.
Hi all, I notice in V2/3/4 PCBs the following connections are warning as single pin, ie: pin 20 tacho-drive is not longer routed to anything - previously went to an ULN2003ADR
Single pin net ENC_Z_54 on IC1.P$54 at 525.04,466.23
Single pin net SPEED_OUT_25 on IC1.P$25 at 524.04,454.38
Single pin net TACHO_DRIVE on CONN2.20 at 542.92,567.05
Single pin net USER_PWM_62 on IC1.P$62 at 521.04,466.23
Are these functions deprecated and safely ignored?
Thanks all
Thanks all
Those functions are no longer required on Tesla boards and have been deleted.
