GS450h Oil Pump Controller Wiring?
Posted: Thu Apr 23, 2026 7:34 pm
Newbie here, but I've spent quite some time trying to find the answer to this issue.
I have:
- G1167-30020 Oil pump controller (bought on ebay from Europe, without connector) connected to
- 56010-HRA050 oil pump that I acquired already attached to
- 30910-30030 transmission.
Wiki docs (https://openinverter.org/wiki/File:Conn ... 312483.png)
show an 11 pin connector, but my controller only has 7 pins.
The two large pins are obviously the Grnd and 12V+, but the other pins are not numbered, so I don't know where to connect "Oil Pump PWM" from pin 30 on the Zombie VCU.
Can anyone confirm please?
Also, I am getting 5V and 1.05kHz on the Pin 30 from the VCU in run mode, does that sound correct? (Google seems to think the controller operates at 250Hz).
(Zombie VCU appears to be talking to the Inverter and the transmission with no errors so far.)
I have:
