Porsche 986 (/996) CAN Messages
Posted: Sun Jan 11, 2026 11:43 am
I collected all information I found in the internet and got it compiled to one database. Have my car prepared for man in the middle between ECU and rest of the CAN network. As we have some more 986 conversions in the forum, please add. Especially ECU stats are interesting for me, to use all the LEDs in the cluster instrument.
CAN ID 0x280 – Engine_1 (ECU)
CAN ID 0x289 – EngineTemp (ECU)
Note: Instrument cluster temperature gauge uses non-linear / modified scaling (display behavior).
CAN ID 0x298 – Engine_2 (ECU)
CAN ID 0x2A8 – Vehicle Speed (ABS / PSM)
Likely dependent on ABS generation.
CAN ID 0x1A0 – ABS_1 (ABS / PSM)
Note: Start bit 48 is reused depending on system variant.
CAN ID 0x4E0 – EngineStat (ECU)
CAN ID 0x520 – Instrument Cluster 2
CAN ID 0x00C0 – Steering Angle Sensor
Signal Start Len Endian Type Factor Offset Unit Source Notes
Engine Speed (RPM) 16 16 Intel U16 0.25 0 rpm DBC, More infos, Teensy All sources agree
Throttle Position 40 8 Intel U8 0.390625 0 % DBC, More infos -
Pedal Position 1 32 8 Intel U8 1 - % DBC Not used in Teensy
Pedal Position 2 56 8 Intel U8 1 - % DBC Not used in Teensy
Coolant Temperature 8 8 Intel U8 0.75 -48 °C DBC, More infos Physical ECU value
Coolant Level Switch 16 1 Intel Bool 1 0 - DBC -
Cruise Control Active 22 1 Intel Bool 1 0 - DBC -
Inlet Air Temperature 8 8 Intel U8 0.75 -48 °C DBC, More infos -
Throttle Position 1 16 8 Intel U8 0.390625 0 % DBC, More infos Turbo? Unsure
Throttle Position 2 32 8 Intel U8 0.390625 0 % DBC, More infos Turbo? Unsure
Barometric Pressure 40 8 Intel U8 5 0 mbar More infos Turbo? Unsure
Vehicle Speed 56 8 Intel U8 ? 0 ? More infos Scaling unknown
Wheel Speed FL 1 15 Intel U15 0.01 0 km/h More infos Legacy definition
Wheel Speed FR 17 15 Intel U15 0.01 0 km/h More infos Legacy definition
Wheel Speed RL 33 15 Intel U15 0.01 0 km/h More infos Legacy definition
Wheel Speed RR 49 15 Intel U15 0.01 0 km/h More infos Legacy definition
Wheel Speed FL 0 16 Intel U16 0.005218 -1.6338 km/h DBC Newer ABS version
Wheel Speed FR 16 16 Intel U16 0.005218 -1.6338 km/h DBC Newer ABS version
Wheel Speed RL 32 16 Intel U16 0.005218 -1.6338 km/h DBC Newer ABS version
Wheel Speed RR 48 16 Intel U16 0.005218 -1.6338 km/h DBC Newer ABS version
Signal Start Len Type Factor Offset Unit Source Notes
TCS Intervention 0 1 Bool 1 0 - DBC, More infos -
MSR Request 1 1 Bool 1 0 - DBC -
ABS Intervention 2 1 Bool 1 0 - DBC, More infos -
ABD Intervention 3 1 Bool 1 0 - DBC, More infos -
FDR Intervention 4 1 Bool 1 0 - DBC, More infos -
ASR Control Mode 5 2 Enum - - - More infos Shift / downshift / inhibit
ABS Warning Lamp 8 1 Bool - - - More infos Offset unknown
Brake Warning Lamp 10 1 Bool - - - More infos Offset unknown
Brake Switch 11 1 Bool 1 0 - More infos -
Brake Switch (Inverted?) 12 1 Bool 1 0 - More infos Possibly inverted
Handbrake Switch 15 1 Bool 1 0 - More infos -
Vehicle Reference Speed 17 16 U16 0.01 0 km/h More infos Tire circumference dependent
TCS Intervention Slow 32 8 U8 0.39 0 % DBC, More infos -
TCS Intervention Fast 40 8 U8 0.39 0 % DBC, More infos -
Intervention Torque 48 8 U8 0.39 0 % More infos Conflicts with Lateral G
Lateral Acceleration (FDR) 48 8 U8 0.01 -1.27 g More infos FDR only
Check Engine Light 0 1 Bool 1 0 - DBC, More infos Also bit 1
Reduced Power 3 1 Bool 1 0 - DBC, More infos -
Fan Error 4 1 Bool 1 0 - DBC, More infos -
Fuel Used 16 16 U16 10 0 - DBC Scaling unclear
Boost Pressure 32 8 U8 10 0 - More infos Turbo only
Oil Temperature 40 8 U8 0.75 -48 °C DBC, More infos -
Ambient Temperature 24 8 U8 0.5 -40 °C DBC, More infos -
Oil Pressure 32 8 U8 0.04 - bar DBC, More infos -
Light Dimmer 8 8 U8 1 0 - DBC -
Counter / Unknown 40 8 U8 1 0 - More infos Unknown purpose
Steering Angle 4 12 Intel Signed 0.390625 0 ° More infos Older definition
Steering Angle 0 16 Intel I16 0.0773 -1.1668 ° DBC Higher resolution
