[WIP] Saab 96
Posted: Sun Jan 04, 2026 11:13 am
Hi All,
Quick introduction from my side: I am based in the northern part of the Netherlands; Friesland for those that are familiar in the area. My background is Mechanical Engineering. I was introduced early to cars by a neighbor; restored a Saab 96 when I was 16 to 18 years old and owned and worked on a lot of other cars since.
For a while I did not have any hobby cars since I had two kids and worked on my house.
I have been driving a Leaf (2015) now for 5 years.
Now it is time again for a Saab and make it electric. My plan: a Saab 96 with a Leaf EM57 80kW stack.
The Saab in its current status: The rules for getting the car road legal in the Netherlands changed as of the first of Januari. Now I cannot get it road legal with the Leaf HV battery anymore; this would have been easiest. This is why I also purchased a VW ID3 HV battery with 9 modules; also inspired by the build of Johu with his Touran.
My current idea for the project:
1. Nissan Leaf stack EM57 80kW
2. HV battery:
4. CCS charging using FOCCCI
5. Cooling/heating:
I have the following steps in mind:
- Tear down the donor Leaf (2017)
- Get the Zombiverter with all leaf components alive in a test set-up (maybe first with the Leaf HV battery and later with the ID3 battery)
- Parallel design the new HV battery enclosure and model the motor into the Saab 96 bay
- Maybe check with local authority if plans can be accepted
- When this is all successful start cutting and welding in the car
Donor Leaf picked up:
2. HV battery:
- a. VW ID3 modules (8x)
b. BMS ?? use the one from VW ID3??
c. Make new enclosure
5. Cooling/heating:
- a. Heating/cooling with water in HV battery enclosure
b. VW water heater
c. Water pump from Leaf
d. Radiator and fan TBD
- a. Throttle from Leaf
b. Dash: speedometer and feedback on other parameters; TBD. I would like to keep the old look, but with all needed info of course
