Page 1 of 1
[WIP] Porsche 986 Boxster
Posted: Sat Sep 13, 2025 3:03 pm
by Tomas
So Boxsters have been converted to electric by many people by now and most of them has gone with Tesla motor. I have chosen to go with a complete 160kW Leaf stack. Sure it does not have the power of a Tesla but it's still more than my car had with ice. Haven't got the battery yet but aiming for a 40kWh.
Have some more parts to remove before I mount the motor and all the other stuff
Re: [WIP] Porsche 986 Boxster
Posted: Sun Sep 14, 2025 10:10 am
by barracuda816
Nice Project. Are you going with the leaf battery?
Posted: Sun Sep 14, 2025 1:13 pm
by Tomas
barracuda816 wrote: ↑Sun Sep 14, 2025 10:10 am
Yes, that's my intention
Posted: Mon Sep 15, 2025 11:09 am
by Tomas
If anyone has files to 3D-print covers for gen 3 Leaf motor, inverter and pdm I'm interested as I have to split the units
Posted: Mon Sep 15, 2025 12:18 pm
by Jacobsmess
Gen 3 motor is the same as the gen 2 i believe so you can probably find those. I think Brat has dome some as well as EVLandcruiser and some others were posted on the DIYElectriccar forum
Posted: Mon Sep 15, 2025 4:29 pm
by ianlighting
Tomas wrote: ↑Mon Sep 15, 2025 11:09 am
Try this
viewtopic.php?t=6216
Posted: Tue Sep 16, 2025 12:57 pm
by Tomas
Trying to decide how I can mount the motor
Posted: Tue Sep 16, 2025 1:32 pm
by tom91
How are you going to control the Leaf Inverter?
The stock CAN control will not allow full speed in reverse, unless you flip the two phases and resolver wiring.
Posted: Tue Sep 16, 2025 2:36 pm
by Tomas
I haven't decided if I go with Zombieverter or Resolve-ev controller. I will flip the resolver wiring and as I split units the phase-swap will be easy
Posted: Wed Sep 17, 2025 11:29 am
by Tomas
Making the drivetrain electric shouldn't be that much trouble (at least I think so..) but the other bit, make a heater work and sending can bus signals to the car so all warning lights and things like that don't remains on is a bit harder. So if anyone have a nice solution or can point me in the right direction, I would be most thankful. I guess a Teensy or Ardinou can do It. I want a water heater (Preferably vag as they are easy to source here) so I can keep all the HV stuff in the back. The temperature can be set by a potentiometer if it makes it easier. The car was bought with engine and gearbox already removed so no possibilty to take can logs.
Posted: Wed Sep 17, 2025 2:43 pm
by tom91
What year of Boxster is it? Other have the CAN already working for the gauges for certain years.
Regarding Heater, if you run a Zombieverter this is easy. The biggest challenge will be how to tap into the heater dial. But as you say a simple extra Pot can be added to be used.
Posted: Wed Sep 17, 2025 4:27 pm
by Tomas
It's a 1997 that came with tiptronic automatic gearbox. It have climate control but I have ripped out the ac part. Mounting a pot would be easy tough
Posted: Thu Sep 18, 2025 1:27 pm
by Tomas
IF I make a switch for a Tesla SDU and use a BMW I3 battery (as I already have) what else do need? Charger/dcdc of course, can I use engovis BMS and chargeport controller?
Posted: Thu Sep 18, 2025 1:58 pm
by Bratitude
A replacement board for the sdu
Posted: Thu Sep 18, 2025 2:05 pm
by Tomas
Bratitude wrote: ↑Thu Sep 18, 2025 1:58 pm
Yes! But do I still want a zombie or just let the oi board do throttle input and contactor control
Posted: Thu Sep 18, 2025 4:55 pm
by tom91
You want Zombie to control the rest. It all depend on what you need controlling.
You want a heater - use zombie
You want DC fast charging - use zombie
You want fancy gear selector and logic - use zombie
You want vehicle integration via CAN - use Zombie
The zombie is a VCU so it manages all things and the higher level vehicle states and HV system state.
Posted: Fri Sep 19, 2025 2:15 pm
by Tomas
@tom91 would it be possible to add Boxster to zombie as a vehicle as it's a fairly common car to convert?
Posted: Fri Sep 19, 2025 4:17 pm
by tom91
Anything is possible, yes it is possible but will need someone that can do the testing and logging and feedback.
Need to get info from others who got it working in order to implement.
Posted: Tue Oct 07, 2025 4:05 pm
by Tomas
Swapped the Leaf gear for a Tesla Sdu. Got my hands on the last oi-board from Johannes. Will probaly go for a zombieverter also. Soon it's time to heat up my soldering iron
