Telsa SDU and VW Beetle question
Posted: Tue Aug 05, 2025 1:21 pm
Hi, I am considering upgrading my Beetle from a Hyper 9 setup to direct drive using a Tesla SDU with a drop-in board.
My questions are, if anyone is running this setup:
What voltage range you are running it at, and
What battery physical configuration have you used (capacity, module choice, cooling etc.)?
I'm in the UK so no chassis-chopping allowed - batteries would have to fit in boxes in the frunk and behind the rear seat. If I do this upgrade, I intend to add DC charging and the position of the required header tank for cooling is a potential concern, hence the question around how you may have configured your batteries.
Thanks in advance.
Thanks in advance.
