Page 1 of 2
Nissan Leaf Stack not getting revs underload
Posted: Mon May 26, 2025 12:31 pm
by vitecd
We have a jet boat powered by the Niassan Leaf 2 gen motor, inverter, charger, and 24KWt battery. The whole system runs from ZombieVerter on my own PCB design, with the latest firmware downloaded from GitHub.
If the motor is disconnected from the jet, it can reach 10.5K revs without any problem. But connected to the jet on the water, it is limited to about 2500 revs, and from about 2300 revs it starts wobbling.
I wonder what is causing the problem? My vision is that the water is not providing enough load or unbalanced coupler to the jet.
What do you think?
The motor is connected to the jet through the cardan, about 30cm long.
Re: Nissan Leaf Stack not getting revs underload
Posted: Mon May 26, 2025 2:54 pm
Post your params so we can see what you have configured.
Also it would be good to get logs of the CAN and some spot values like:
-Potnom
-Speed
-UDC
-Amps
-Temps
Posted: Mon May 26, 2025 3:47 pm
by jrbe
On top of Tom's ask, is it a single cardan joint? What's the angle it's running at?
Posted: Tue May 27, 2025 12:30 am
by vitecd
jrbe wrote: Mon May 26, 2025 3:47 pm On top of Tom's ask, is it a single cardan joint? What's the angle it's running at?
It has two cardan joints, each end of the shaft. It has no angle between the jet and the motor, and about 5 degrees between the whole system to the floor
Posted: Tue May 27, 2025 12:45 am
by vitecd
tom91 wrote: Mon May 26, 2025 2:54 pm Post your params so we can see what you have configured.
-Potnom
-Speed
-UDC
-Amps
-Temps
The boat is stored far from my current location, but I have a few logs with some parameters.
I've configured just the pots parameters, udcmin=330 and switched CAN bus and Leaf units, car set to none.
The temperature was about 15-16 Celsius. I've started from 2 pots, tried 1 and had 100 revs higher, but wobbling as well.
Posted: Tue May 27, 2025 7:38 am
Can you log the normal CAN? I need to see all the traffic.
Again I need the full param set.
Posted: Wed May 28, 2025 1:04 am
by vitecd
It will take some time, dry weather is needed and a time to drop the boat into the river.
Posted: Wed Jun 25, 2025 5:25 am
by vitecd
tom91 wrote: Tue May 27, 2025 7:38 am Can you log the normal CAN? I need to see all the traffic.
Here they are
Posted: Wed Jun 25, 2025 5:27 am
by vitecd
Joint been balanced. Today we have a ride on the river, not much changed, same shaking/limitation around 2300 revs. Rotation by hand not a problem
Posted: Wed Jun 25, 2025 8:25 am
by J0hannes
vitecd wrote: Wed Jun 25, 2025 5:27 am Joint been balanced. Today we have a ride on the river, not much changed, same shaking/limitation around 2300 revs. Rotation by hand not a problem
-How have you implementes the motor side driveshaft flange?
-Support bearings?
-Have you aligned the forks of the driveshaft?
Posted: Wed Jun 25, 2025 8:33 am
by vitecd
I used part of the original reducer, but there was only one gear left. A hole was made, and a shaft was extended.
Without Jet connected, the motor is doing 10000 revs smoothly.
Posted: Wed Jun 25, 2025 11:29 am
by vitecd
Not sure if it's meaning anything
revs .05 scale, 2300 max
Posted: Wed Jun 25, 2025 12:33 pm
We will need logs of Potnom from zombie will doing this, there may be things limiting the torque request as its not flat out.
Edit your issue is: "udcmin": 360
This is limiting throttle, this should be shown by zombieverter and the potnom spotvalue
This is high for a 96s battery, change it to like 3.2 x 96 = 307V
Posted: Thu Jun 26, 2025 2:34 am
by vitecd
Sorry, does not make sense to me. Could you explain, please?
The current voltage at the time was 380V
Without Jet, the motor spins 10000revs easily and smoothly.
Posted: Thu Jun 26, 2025 12:08 pm
vitecd wrote: Thu Jun 26, 2025 2:34 am Without Jet, the motor spins 10000revs easily and smoothly.
Without load vs with load
Your CAN logs show the battery sagging down and thus the udcmin limiter kicking in, it kicks in before hitting udcmin as not to have an abrupt stop of of torque
Posted: Fri Jul 11, 2025 3:15 am
by vitecd
Some updates and questions. I've assembled... or reconnected?! another test bench, it is Nissan Leaf powered by ZombieVerter. During the connection testing, I mentioned two issues:
1. After PrechargeFail, negative contactor stays ON
2. After Power ON, PRECHARGE contactors stays ON.
Is it okay?
Posted: Fri Jul 11, 2025 7:30 am
vitecd wrote: Fri Jul 11, 2025 3:15 am After Power ON, PRECHARGE contactors stays ON.
This is fine
vitecd wrote: Fri Jul 11, 2025 3:15 am After PrechargeFail, negative contactor stays ON
Possibly this is not an issue.
I am planning to overhaul the whole HV contactor handling logic at some point to rework all this.
Posted: Sat Jul 12, 2025 1:43 am
by vitecd
Logs and settings attached. The system keeps jumping, around 3800revs
Posted: Sat Jul 12, 2025 10:15 am
You have a major problem in your High Voltage wiring or a really shit battery.
You running straight connection right, you do not have a resistor in series with your battery?
80V drop at 200A is ALOT
Posted: Sun Jul 13, 2025 1:27 am
by vitecd
Wow, thank you, it doesn't look great, I'm going to check connections and also will take a log from the original system.
Took a few ride on the Leaf hardware, switched to the Verter just after.
Logs attached.
Posted: Sun Jul 13, 2025 7:31 am
by vitecd
tom91 wrote: Sat Jul 12, 2025 10:15 am really shit battery.
Your truth, but... The Leaf system is running smoothly.
Posted: Sun Jul 13, 2025 9:24 am
So you what you are seeing is the battery sagging 80V and the zombieverter forcing a derate. You could tune it by allowing less max throttle and decreasing throttle ramps to have less oscillation under heavy load.
vitecd wrote: Sun Jul 13, 2025 7:31 amYour truth
The truth, the battery is not capable of providing the power being requested from the leaf inverter. The zombie reactes based on feedback and not based on limit mapping unless you set it up.
vitecd wrote: Sun Jul 13, 2025 1:27 am Took a few ride on the Leaf hardware, switched to the Verter just after.
Then just keep using the leaf hardware...
Posted: Sun Jul 13, 2025 9:50 am
by vitecd
tom91 wrote: Sun Jul 13, 2025 9:24 am Then just keep using the leaf hardware...
Prefer to tune the Verter, as it is more compact and flexible, just need to understand it more precisely.
I used the Leaf HW just to test the limits, and the Leaf HW reached 6800 revs
Let's go back to the beginning.
My original problem was motor wobbling and not reaching top revs. From the logs, we can see that the torque request is jumping up and down. Can anyone guess why? I've checked the logs from the boat, and the HV drops down just a few volts; it's not the case.
Please
Posted: Mon Jul 14, 2025 12:05 pm
by larsrengersen
vitecd wrote: Sun Jul 13, 2025 7:31 am Your truth, but... The Leaf system is running smoothly.
Smoothly?
A 400+ mV delta does sound like a weak pack or at least weak cell to me.
But if you are seeing a voltage sag of 80V at 300V that is not good.
Then you are allowing the inverter to draw way to much current.
So allow less current out and reduce the torque and current ramp up.
The power power you draw, the more voltage sag you will see. As Tom said.
You can try / test for yourself by very slowly and gently pushing the throttle down and slowly but surely let the RPM's increase. Then you will also be able to get that right with the Zombi.
