hello all. I am new to this forum. i have nissan note e motor (E57 call IPMSM motor). it is salvage part of nissan note e. i think similar motor is used by Nissan leaf. i have also battery pack of nissan note e rated 2kw at 320v. i want to make series hybrid of my own using old suzuki liana car, em57 motor will be attached with manual gear assemble of liana and a small 3 cylinder engine rated at 40hp will run the nissan note e second genertaor rated 15kw. which will supply to battery of 320v.
i need an inverter which i install to nissan leaf motor. which run motor. just paddle sesnor for speed, regen braking and cos sign sensor for position.
can any one guide me where to buy inverter plug and play to start using nissan note e motor (e57).
Nissan Note series hybrid
