Battery preheating on ID.4 / MEB
Posted: Sat Mar 15, 2025 12:29 pm
by jagheterfredrik
Hello,
I’m looking into fixing battery preheating on my 2022 ID.4 and this forum is packed with great information.
My current thinking is to man-in-the-middle the LIN bus to the Z132 HV battery heater and turn it on for a X time. More info at
https://github.com/jagheterfredrik/meb-preheat/
Thought I ask the collective wisdom here: do you think it’s feasible?
Re: Battery preheating on ID.4 / MEB
Posted: Tue Mar 25, 2025 3:41 pm
by jagheterfredrik
I've built a harness, I thought the battery heater was the one documented in
the Wiki but it wasn't. It seems the ID.4 heater (1EE.963.231) is built by BorgWarner and has a slightly different LIN bus communication scheme.
Every 50ms a PID is polled, alternating between:
ID 15 (0x0F): 8 bytes, in my case 0, 190, 0, 0, 150, 64, 58, 60. My assumption is that it is feedback and the last three are temperatures -50. During a 15 second listen, only the fifth byte (150) value flip flopped between 150 and 151.
ID 28 (0x1C): 4 bytes, in my case 254, 252, 1, 248. I assume this is control but I don't think the heater was heating so not sure. This value remained constant.
Next up I need to force the heater to run using UDS output testing functionality to see what changes.
Posted: Wed Mar 26, 2025 8:54 am
by jagheterfredrik
I tried getting the car to heat the battery but CAN readouts show 0 amp draw from the PTC battery heater.
ID 28 haven't changed but ID 15 did interesting stuff when connected while first booting up the car.
The first recorded value of ID 15 was 0,189,0,0,135,58,54,55
The fifth byte (135) value ramped up to 154 (overshoot?) during 3 seconds to then quickly stabilize at 151 (same as yesterday). The coolant pump was briefly running at 40% according to OBD, I wonder if this is flow related? Not sure.
The three last bytes started rising slowly and does match outdoor temperature well (at offset -50), the two last bytes seem to match the "HV Battery PTC Temperature #1 and #2" as reported through OBD. I assume the 6th byte is some kind of PCB temperature.
Posted: Thu Mar 27, 2025 3:47 pm
by jagheterfredrik
Ok, I had to go to a DC fast charger to get the car to actually heat the battery.
ID 15:
Example while heating: 34 BE 00 00 86 4C 3D 42
Byte 1: Current (0.25*X in amps)
Byte 2: HV battery voltage (2*X in volt)
Byte 3,4: Status? Always 0
Byte 5: LV battery voltage (0.1*X in volt)
Byte 6, 7, 8: Temp heater, in, out. Offset -50
ID 28:
The BMS ramps up the heater over a couple of seconds, like this (LIN data in hex):
FE FC 01 F8 (what we saw earlier, when off)
FE FC 0D F8
FE FC 15 F8
FE FC 1D F8
FE FC 25 F8
FE FC F5 F8
FE FC FD F8
FE FC 05 F9
FE FC 1D FB (Stopped here, 99 in decimal, i.e. 1% per step)
From above we can deduce that we have a bit for on/off and 100 steps (7 bits) of duty cycle. I've added a LDF to my repo to describe it better.
I also discovered that the device implements UDSonLIN, using LIN diagnostics commands the BMS issues UDS Read Data by Identifier requests, e.g. reading ID F187 the heater returns "1EE963231 " and for F197: "J848 HV-PTC "
Posted: Thu Mar 27, 2025 5:17 pm
Next steps would of course by talking to the heater with an LIN adapter or controller of sorts.
Be cool to get it working and added to the list of heaters that work.
Posted: Fri Mar 28, 2025 10:40 am
by jagheterfredrik
I assembled a LIN responder that emulates the heater and the values I send match what the OBD reports. Unfortunately the BMS does not turn on the circulation pump, even with emulated current draw and big temperature deltas
Posted: Wed Apr 30, 2025 10:01 pm
by golfdubcrazy
Hi, great project.
couple things the id3 and id4 has two heaters one water cooled and one air heater. so need to check the Lin ids. also the the heaters cant run as the battery HV would be switched off.
but great to see the progress. i will test both ids ok the air PTC heater i have to see if that wakes up and reacts
Posted: Sun Mar 22, 2026 8:40 pm
by larsrengersen
Thanks for sharing this control info.
I implemented it in our LIN to CAN gateway and it works like a charm.
One finding from my end (relevant for EV Conversions): It self regulates when it reaches about 50 degrees.
So perfect and safe and sufficient for a battery heater (yet not suitable as an interior heater).
