Page 5 of 5
Re: VW eGolf hardware
Posted: Thu Nov 03, 2022 7:54 pm
by arthur8
arber333 wrote: ↑Thu Nov 03, 2022 7:37 pm
You could use modules in parallel and with BMS connected just by CAN bus. Use SimpBMS and wire your harness from the GTE wires.
But i use those cells in my sola array with JK BMS wired for 12S. Problem is not with BMS. Inverter requires minimum 48V to return back to battery, which is to much for 12S Liion. I would need 16S to keep battery at optimal charge/discharge states for my application. I already have a plan to use Mazda LiPo cells for that.
Thanks for the help.
Looks good! But there is any alternative to SimpBMS? I found it a bit expensive where i live. It would cost more than i paid for the entire gte battery.
Posted: Thu Nov 03, 2022 8:00 pm
arthur8 wrote: ↑Thu Nov 03, 2022 7:54 pm
I am developing a similar modular board with cheaper ESP32 chip. You may try to contribute by porting Teenys code to ESP32.
viewtopic.php?t=2256
Posted: Thu Nov 03, 2022 8:16 pm
by arthur8
arber333 wrote: ↑Thu Nov 03, 2022 8:00 pm
I have some experience with Arduino. Will take a look on this topic and do my best to help.
I was reading on another forum that those prismatic cells from golf GTE should to be always under pressure while charging/discharging (cannot find the forum link, but i read it some time ago). Is this true?
Posted: Thu Nov 03, 2022 10:40 pm
by eee291
They puff after just one cycle, even at low c rate (from experience)
I managed to make some 14s blocks out of them but with metal welded box, still works today.
Posted: Fri Nov 04, 2022 12:19 am
by arthur8
eee291 wrote: ↑Thu Nov 03, 2022 10:40 pm
Nice to know. Thanks.
Can you post some photos of your work? I'm thinking to do the same with my cells.
Posted: Fri Nov 04, 2022 7:00 pm
by Alibro
Sorry if I'm missing something here but for 14S couldn't you use an ebike BMS? The ANT BMS's are pretty good and allow you to monitor the pack via a mobile phone. Vorteck's VBMS software is only £10 and works great.
Posted: Fri Nov 04, 2022 7:27 pm
by arthur8
Alibro wrote: ↑Fri Nov 04, 2022 7:00 pm
Thanks for the help!
Yeah, i was thinking about using some external BMS. I was looking at the NEEY 4th generation. What do you think?
Actually i just need an balancer, i already have some arduino's monitoring my dc voltages for low/high voltage battery disconnect.
Posted: Sun Nov 06, 2022 8:40 am
by Alibro
arthur8 wrote: ↑Fri Nov 04, 2022 7:27 pm
I'm no expert in ebike BMS's so can't give proper advice but I've used a couple of cheap units from China and had no issues.
You could even try an active balancer to share the voltage across the pack rather than a passive BMS that just takes power from the highest cell.
Have a look through this thread
viewtopic.php?t=1603
Posted: Mon Nov 07, 2022 1:30 pm
by arthur8
Alibro wrote: ↑Sun Nov 06, 2022 8:40 am
Looks a good idea Alibro. Will read this topic.
I have ended up buying an active inductive balancer that i will review here when it arrives.
Thank you!
Posted: Mon Nov 07, 2022 1:31 pm
by arthur8
Friends,
Do you guys know what is the correct voltage for those lithium polymer cells from the golf gte?
Ive read that they are Lithium nickel manganese cobalt (NMC). And from what i've found they have a 3.7 V nominal voltage with a 4.2 V maximum while charging. The same as 18650. This is correct?
Thanks.
Posted: Tue Nov 08, 2022 7:39 pm
by Alibro
arthur8 wrote: ↑Mon Nov 07, 2022 1:31 pm
Friends,
Thanks.
Is this the same as yours?
https://www.secondlife-evbatteries.com/ ... amsung-sdi
Posted: Tue Nov 08, 2022 8:43 pm
by Bigpie
I have 2 Golf GTE packs, I charge to 4.15v. You can run SimpBMS on a Teensy with just a can transceiver for the GTE modules, it'll monitor the voltages and balancing.
Posted: Wed Nov 09, 2022 3:04 pm
by arthur8
Mine are made from Panasonic. There are exactly like this (not my photo):
Posted: Wed Nov 09, 2022 3:05 pm
by arthur8
Bigpie wrote: ↑Tue Nov 08, 2022 8:43 pm
Thanks for the feedback. Will charge them until ~4.00v.
Posted: Mon May 15, 2023 10:38 am
by bartek8118
Good morning,
I am trying to decode the checksum in CAN data frames in frames with voltages. Frame id 0x1B0-1C9. Does anyone of you know how the checksum is calculated?
greetings
Posted: Mon May 15, 2023 12:02 pm
by Bigpie
Posted: Tue Oct 24, 2023 4:19 pm
by Gwizard
EV_Builder wrote: ↑Thu Jun 02, 2022 8:40 am
In the small square section looks like some configuration to me?
Do you have closeup? What's printed on the small table?
Hi Have you noticed these resistors? Could these set the module ID's they are different on the two units in this photo
- image.png (125.77 KiB) Viewed 3351 times
Posted: Tue Oct 24, 2023 11:11 pm
by EV_Builder
I would say check it. I think it has todo with cells.
